structural adhesive
Old May 29th 06, 09:27 AM posted to rec.aviation.homebuilt
Default structural adhesive
Hi everybody!
I am looking for a structural adhesive tape but I prefer a glue
(because I do not want thickness) to bond aluminium (with passivation
or anodization treatment) and steel. The bond have to resist to sea
salt fog, and temperature between -100°C +100°C.
I will appreciate any suggestions!
Thank you
Old May 29th 06, 05:45 PM posted to rec.aviation.homebuilt
circio0 wrote:
Hi everybody!
I suggest you change your design.
Unless you are going to attach very small pieces of one to
the other, so that differential thermal expansion is negligible,
no bonding method is going to work.
You could bolt or rivet the parts together and they'd
buckle or break.
FF
Old May 30th 06, 09:34 AM posted to rec.aviation.homebuilt
3M's AF42 seems strong bonding but it needs 60 min curing!!!! do you
know a faster method?
we are moving in the right way!
Thank you in advance
Adhesive removal [email protected] Soaring 8 May 2nd 06 02:37 PM
Plexiglas/canopy adhesive Michael Pilla Home Built 3 May 3rd 04 05:09 PM
structural stainless steel tank screws needed for PA-32-300 Dave Owning 11 October 1st 03 10:14 PM
Looking for sand paper rolls and adhesive Roger Halstead Home Built 9 August 8th 03 08:58 AM
Structural adhesive question BD5ER Home Built 1 August 3rd 03 06:03 AM
