Plexiglas/canopy adhesive
Old May 2nd 04, 12:22 AM
Michael Pilla
Default Plexiglas/canopy adhesive
"Eugene Wendland" wrote in message
What is the adhesive that is used to install the windscreen/canopy to their
respective frames. I'm replacing the canopy on my Pazmany Pl-2. At
present, I have about fifty screws attaching each half of the Plexiglas to
the sliding canopy. Rather than risking drilling and tightening all those
screws in the Plexiglas, I think a more modern approach would be the
adhesive found in Glastars, Glasairs, etc.
Does anyone know the commercial name of this product?
Regards
Eugene
http://home.cogeco.ca/~pl2/paz.html
There was an article in Sport Aviation back a few months that described
using SikaFlex for adhering the canopy for a Van's RV-4, IIRC.
Try this, for starters:
http://www.sikaindustry.com/ind/ipd-tds_msds.htm
I did a Google search back when the article came out and there was plenty of
info on the various varieties of SikaFlex including some excellent tutorials
on priming, adhering to aluminum, powder coated frames, etc.
Michael Pilla
Old May 2nd 04, 12:56 AM
JFLEISC
There was an article in Sport Aviation back a few months...
And as usual I got my copy not one week after I replaced the canopy on my RV-4.
If I ever do another one it will be with glue. I think the only trick would be
coming up with a good clamping system...or dozens of them all around edge.
Old May 2nd 04, 02:02 AM
Kyle Boatright
their
Regards
Eugene
Lexel is a product that can be found at Lowe's, Home Depot, Ace Hardware,
etc. It is a sealant that is plexi friendly, and *might* work for your
application. You should be able to find a tube locally (or do some internet
research) to figure out if it has the strength you're looking for.
KB
Old May 3rd 04, 05:09 PM
Stu & Kathy Fields
I just finished making the doors for my Safari in which I glued (Sikafles)
the Lexan to 3/8" 4130 tubing. So far..So good. The proof will be how they
last over the arishow circuit this summer. I do however, have 4
penetrations of the Lexan occurring at the hinges and two latches so even if
the the Sikaflex doesn't work as advertised, the door is not going to got
get my tail rotor....
Stu Fields Safari pilot
"Michael Pilla" wrote in message
their
Regards
Eugene
of
tutorials
Michael Pilla
Bonded aluminum aircraft structures asennad Home Built 9 December 31st 03 02:58 PM
Looking for sand paper rolls and adhesive Roger Halstead Home Built 9 August 8th 03 08:58 AM
Structural adhesive question BD5ER Home Built 1 August 3rd 03 06:03 AM
