OK, my mechanic says I need a compass.
I told him the mountains haven't hardly moved at all, but he was unmoved as well. Tom, were you able to stop yours leaking ? Enquiring minds want to know, Thanks, Best Regards, Dave |
Dave,
I've been using a small PZL now for 3 years with no leaks. It's actually my second one - the first also didn't leak, but the window got all blurry (UV, moisture, bugs, plants in the liquid?) so I had to replace it. But it didn't leak either. I do mount mine a bit differently, against the face of the panel, without using the supplied mount. Don't know if that makes any difference. And it actually came in handy once when the visibility was so bad here in S IL that I had to fly a compass heading to make it home. Nice to have to crosscheck the magic boxes. Kirk |
Ya gotta love it. My compass needs "Depends".
Thanks ! See ya, Dave 5Z wrote: wrote: Tom, were you able to stop yours leaking ? Yes. I followed Bumper's advice from a different thread and got some Loctite Depend 330. I built a fillet around the threaded back and so far it's holding up. I also made sure to only fill it enough so the air bubble doesn't show in a normal attitude. -Tom |
Also, what's the correct fluid ?
To avoid fogging the window or worse ? Thanks Tom ! A great memory: Vaunted glider-guider demonstrating instruments to Dave and friends in our infancy: "Here lads is how you how you top off a compass. Make sure you've got the right type of fluid. Here we use type XYZ, carefully filling with a syringe". Hard to recall which was more amazing - the numbers gently floating off the compass ball more or less intact like some weird power-point animation, or the look on said vaunted glider-guider's face... Remember Todd - you were there, right ? 5Z wrote: wrote: Tom, were you able to stop yours leaking ? Yes. I followed Bumper's advice from a different thread and got some Loctite Depend 330. I built a fillet around the threaded back and so far it's holding up. I also made sure to only fill it enough so the air bubble doesn't show in a normal attitude. -Tom |
![]() wrote: Also, what's the correct fluid ? To avoid fogging the window or worse ? I used compass fluid ordered from Aircraft Spruce: http://www.aircraftspruce.com/catalo.../repairkit.php Still have most of the quart left after filling the compass several times, so pint should do ya! -Tom |
Hi Tom - Two more questions:
Yours was definitely leaking out the threads in the back ? Loctite 330 costs more than our gliders. From the Loctite product data it looks like good-ole Loctite 243 is more appropriate in any case - What am I missing here ? Thanks for the help ! Best Regards, Dave 5Z wrote: wrote: Tom, were you able to stop yours leaking ? Yes. I followed Bumper's advice from a different thread and got some Loctite Depend 330. I built a fillet around the threaded back and so far it's holding up. I also made sure to only fill it enough so the air bubble doesn't show in a normal attitude. -Tom |
Not familiar with Loctite 330. How does it compare with Aviation Permatex
for this use? -- Hartley Falbaum "bumper" wrote in message ... The problem with regular epoxy is that when cured it is relatively hard and brittle. Thermal expansion and contraction of the epoxy may not be the same as the plastic being glued. Loctite "Depend 330" when cured remains flexible and bonds well to a variety of materials. It will, for instance, bond metal directly to fiberglass with no lay-up of FRP over the metal required. Useful stuff to have around, but it does have a limited shelf life, so the large "economy" size ain't. bumper "5Z" wrote in message ups.com... wrote: Hi Tom - Two more questions: Yours was definitely leaking out the threads in the back ? Yes. I'd put it on the dash of the car on a paper towel and let the winter sun heat it up, then look for damp spots. Tried to figure out some kind of tool to open it up and look for O ring to replace, etc, but all attempts at opening failed, as I didn't want to break it. Loctite 330 costs more than our gliders. From the Loctite product data it looks like good-ole Loctite 243 is more appropriate in any case - What am I missing here ? Probably any decent epoxy stuff will do the trick. Bumper's into exotic tools & such... ![]() I roughed up the gap with a Moto-Tool first. -Tom |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
PZL compass repair | 5Z | Soaring | 16 | November 30th 05 11:40 PM |
Calibrate? Repair? Adjust? | RST Engineering | Owning | 3 | April 4th 05 01:41 PM |
Strange compass behavior | me | Owning | 10 | February 14th 04 04:24 AM |
Bubble Face Compass Repair | Gene Hetsel | Restoration | 1 | January 9th 04 04:59 AM |
