Arrow annual woes
Old June 15th 06, 01:07 AM posted to rec.aviation.owning
Default Arrow annual woes
Our 1979 Arrow IV is in the shop for its annual inspection. As usual, the
inspection itself went smoothly, but it uncovered some maintenance items
that will run into several AMUs. Here are the top three uglies:
1) The inspection part of Piper Service Bulletin 1161 resulted in
identification of cracks in both affected wing ribs. That's the bad news.
The good news is that the cracks are in locations that will allow the use of
the Piper repair kits, which Piper stocks. Jack Allison has posted on this
NG his horror story of replacing the ribs when the cracks precluded use of
the repair kits, so in a way we feel lucky. Cost estimate for the SB
compliance with the repair kits is about 1.3 AMU, including parts and the
initial inspection.
2) The hydraulic power pack has to be replaced or overhauled. We can't feel
too bad about this one because it's the original (1979) unit. 27 years is a
more than reasonable service life. A rebuilt replacement goes for 0.8 AMU,
which is about the cost of overhauling ours. We will do a swap in order to
avoid downtime for an overhaul.
3) The biggie! The support structure under the wing walk is cracked in
several places and needs to be replaced. This is apparent from a slight
"oilcanning" of the wing skin in the wing walk area when we step on it.
Repair will necessitate removing the right wing, a bunch of drilling to
remove the old structure, replacing it with a new assembly (cost unknown)
and replacing the wing. our mech estimates (roughly) the job will take
about 24 hrs of labor and cost, with parts, around 2 AMUs. It's not really
a safety issue as the structure only supports and reinforces the wing walk
-- it is not part of the primary wing structure. But left unrepaired the
outer skin could crack, resulting in a much bigger repair job. Our shop has
never done this job before but one of the assistant A&Ps has, and the
estimate is largely based upon his knowledge. Have any of you other
PA-28/PA-32 owners had this problem?
The rest of the identified maintenance items are the usual collection of
individually minor items -- a seal here, a gasket there -- but of course
collectively they typically add up to about 1 AMU.
Glad this is going to be split 3 ways!
-Elliott Drucker
Old June 15th 06, 01:21 AM posted to rec.aviation.owning
I empathize with your pain.
Annuals on older aircraft seem to be one big craps game where we owners
hope, at best, to walk away from the table only one AMU down. Rarely does
that appear to happen.
Peter
Old June 15th 06, 02:29 AM posted to rec.aviation.owning
The first annual we had on our '79 "J" model Mooney (Please no flames
about what an annual is or isn't) was a little over 9 AMU's... This year
was a little less than 5 AMU's. We felt lucky... Next year we'll shoot
for 2.5...
The biggie for us this year was a 1.9 AMU fuel servo replacement. I must
say that 43H runs noticably better with the new servo... Other than that
we were pretty squawk free... The thing that I noticed is that a bunch
of little squawks can run into an AMU or two quickly...
Sorry to hear about your pain...
Jon Kraus
'79 Mooney 201
4443H @ UMP
Old June 15th 06, 02:08 AM posted to rec.aviation.owning
I had leaks in the hydraulic pack of my Arrow IV when I bought it. I have an
excellent A&P that suggested that it might only be the seals, and you can
replace the seals for far less than the cost you mentioned.
Do you have electric trim, and if so how is it working. Mine works
intermittently. The clutch always catches, but the motor sometimes doesn't
have enough power to move the trim. I was wondering if this was typical for
the Arrow IV.
The wing walk area on my plane gives just a little, but I notice it. I step
lightly, and hope for the best. 2 AMUs seems high, but what do I know?
news:ex1kg.13606$OL2.9653@trnddc06...
of
this
initial inspection.
feel
a
AMU,
to
really
has
-Elliott Drucker
Old June 15th 06, 02:45 AM posted to rec.aviation.owning
the Arrow IV.
I never use the electric trim on any airplane I fly.
I like to feel the resistance increase or decrease as I set it to the
correct spot.
The autopilot uses the electric trim, so checking it is part of each
preflight.
Old June 15th 06, 04:24 AM posted to rec.aviation.owning
for the Arrow IV.
Yes, our has electric trim. I use it all the time, and it works fine. Once
while flying in extremely cold air (-29 C as I recall) it got very slow, but
all of the controls were feeling quite stiff that day. Our AP is only
single axis, so the electric trim is only engaged by the pilot.
-Elliott Drucker
Old June 15th 06, 02:46 AM posted to rec.aviation.owning
In article ex1kg.13606$OL2.9653@trnddc06,
Is the Arrow wing one piece (like a Mooney) or two (like an RV)?
Old June 15th 06, 04:29 AM posted to rec.aviation.owning
On PA-28 airplanes, including the Arrow, the wing spar sections bolt onto
the fuselage carry-through section. Apparently, removing a wing is not that
big a deal. I presume there must be a hard point under the fuselage where
the weight of the plane can be supported while the wing is removed, since
the main gear mount on the wing, or else it might be necessary to use slings
from an overhead.
-Elliott Drucker
Old June 15th 06, 03:39 AM posted to rec.aviation.owning
really
has
This problem has been discussed extensively in the Cherokee Chat, on the
Cherokee Pilots Association website. There are literally dozens of guys
there who have been down this road, and can (and will) answer any of your
questions.
In fact, tomorrow we're heading to their three-day convention, which is
this coming weekend. It is held annually at Tan-Tar-A resort, in Osage
Beach, MO. This year's keynote speaker is none other than Phil Boyer, AOPA
president.
It's a great organization. If you want to know ANYTHING about Cherokees, I
recommend joining this group.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Annual and rib replacement complete Jack Allison Owning 13 May 10th 06 04:00 AM
Fun weekend buying an Arrow (long) Jack Allison Owning 44 April 20th 05 12:29 PM
Christmas Annual - long drivel Denny Owning 23 December 31st 04 08:52 PM
Annual Report Final. "Long" NW_PILOT Owning 20 October 28th 04 07:20 PM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 03:41 PM
