just out of interest: pressure pattern navigation
Old June 28th 06, 01:31 PM posted to rec.aviation.piloting
Default just out of interest: pressure pattern navigation
.... when using pressure pattern nav techniques, what's a standard way for
working out groundspeed for flight planning purposes? Do you take the
forecast curved route and divide it up into segments and average it out?
TIA
Old June 28th 06, 03:19 PM posted to rec.aviation.piloting
Plane & Pilot Magazine | Feature Articles | Revisiting
Pressure ... Initiated in 1943, pressure-pattern navigation
is attributed to Dr. John Bellamy. His so-called "Bellamy
Drift" was used widely during the late 1940s, ...
www.planeandpilotmag.com/content/
pastissues/2001/mar/revisiting.html - 37k - Cached - Similar
pages
Flying Magazine - You want to put them where? The
relationship between barometric pressure and wind drift is
enshrined in the so-called Bellamy Drift, named for John
Bellamy, a civil engineer and ...
www.flyingmag.com/article.asp?section_
id=12&article_id=602&page_number=2 - 24k - Cached - Similar
pages
[PDF] AFI 11-2C-130 Volume 3, Checklist 5 File Format:
PDF/Adobe Acrobat - View as HTML
Whiz Wheel Formula for finding Bellamy Drift:. ZN. =.
DCA. Grnd Dist. 57.3. PRESSURE PATTERN ALTITUDE CHANGE.
FORMULA METHOD ...
www.e-publishing.af.mil/pubfiles/
af/11/afi11-2c-130v3cl-5/afi11-2c-130v3cl-5.pdf - Similar
pages
"xerj" wrote in message
standard way for
you take the
average it out?
| TIA
Old June 28th 06, 11:53 PM posted to rec.aviation.piloting
Thanks for those Jim. I'd seen a couple of them before. The thing is that
unless I'm missing something, there isn't an explanation of WHEN you'll
arrive. There's an explanation of HOW and WHERE, but I'm wondering how you
work out time and fuel planning when using the pressure pattern method.
"Jim Macklin" wrote in message
news:aewog.49771$ZW3.4494@dukeread04...
pages
pages
FORMULA METHOD ...
pages
standard way for
you take the
average it out?
| TIA
Old June 29th 06, 02:14 AM posted to rec.aviation.piloting
Since I have only read about it and have not really had an
opportunity to check it out, consider the Bellamy drift is
based on the average crosswind, I do believe you can also
derive the average tail/headwind and apply that to the
expected trip distance.
The USAF Navigtation manual has a section on these
techniques.
If you look at the
http://www.e-publishing.af.mil/pubfi...-130v3cl-5.pdf
you will see steps for rules of thumb.
Note the original links below are broken and are repaired.
http://www.planeandpilotmag.com/cont...evisiting.html
http://www.flyingmag.com/article.asp...age_numbe r=2
The thing is that
of WHEN you'll
wondering how you
pattern method.
| "Jim Macklin" wrote
in message
navigation
"Bellamy
Similar
| pages
is
Similar
| pages
| FORMULA METHOD ...
Similar
| pages
a
| standard way for
Do
| you take the
and
| average it out?
| | TIA
why high to low, look out below? [email protected] Piloting 28 November 14th 05 02:13 AM
Attn: Hydraulic experts - oil pressure relief fix? MikeremlaP Home Built 7 November 6th 04 08:34 PM
Attn: Hydraulic experts - oil pressure relief fix? MikeremlaP Home Built 0 November 2nd 04 05:49 PM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 05:18 AM
