Microair Mic Problem
Old July 18th 06, 02:54 AM posted to rec.aviation.soaring
Jack[_4_]
Default Microair Mic Problem
Working with a friend on his radio problem and his mic seems to be
overdriving. He's sure it's an electret mic, and it's an older Microair
radio. I seem to recall having to use an r-c network across the mic of
another radio last year in Houston on a club glider, but I didn't make
notes and don't remember the values of the resistor or capacitor. The
other possibility is to turn down the mic gain at the pot on the side
of the radio... Suggestions... Experience....
Thanks in advance.
Jack Womack
Old July 18th 06, 03:06 AM posted to rec.aviation.soaring
Mal[_1_]
http://www.mrsoaring.com/squealing_mikes.htm
HTH
Old July 18th 06, 04:40 AM posted to rec.aviation.soaring
BTIZ
"Mal" wrote in message
HTH
Is MicroAir still in business? IT so, they have the worst customer support
program ever. They have failed to answer repeated attempted contacts for
support on their 760 radio. We are replacing it with a Becker.
I find it surprising that mrsoaring is supporting such a company. But then
again, it looks like they are on the same continent.
BT
Old July 19th 06, 04:47 AM posted to rec.aviation.soaring
Mike I Green
I have a Microaire Transponder. It failed after about 9 months. No
problem getting it fixed and it is going strong for the past 2 years.
Their radio may be another story.
mg
HTH
BT
Mike I Green
mg
HTH
BT
Old July 19th 06, 05:14 AM posted to rec.aviation.soaring
Greg Arnold
mg
Seems like it is the luck of the draw on the Microair radio. I have one
that worked fine for several years, but I recently replaced it with
another brand because its ergonomics aren't the best.
Old July 19th 06, 02:32 PM posted to rec.aviation.soaring
David Kinsell
mg
Our club has three in use, one actual failure in maybe 10 years of
total time. Excellent transmit quality with amplified Telex dynamic
mikes. I'd sure try one of those to see how they work. Make sure
you don't use the external Microair amplifier.
I agree on the ergonomics, not the best for a club environment.
-Dave
Old July 18th 06, 05:00 AM posted to rec.aviation.soaring
We have a Microair in our glider. It has never worked properly in
spite of a round-trip to Oz. We have given up on it, and now use hand
helds.
Cheers anyway, Charles
Old July 18th 06, 11:34 AM posted to rec.aviation.soaring
Mal[_1_]
Erie Aviation (USA) is now our up and running Warranty Centre in the
USA.
All Warranty work can be sent to Erie Aviation via the following:-
"The preferred inbound shipment method is either UPS or FedEx to this
address:
Erie Aviation, Inc.
1607 Asbury Road
Erie, PA 16505
email:
If that is not possible and you need to use the US Postal Service, you
must use the following address:
Erie Aviation, Inc.
P.O.Box 8283
Erie, PA 16505
Please note that shipments through the US Postal Service will likely
add one day to our turn-time.
Shipments will be returned using FedEx, so please provide a physical
return address that is NOT a Post Office Box."
. MODE S
Mode S is still in the pipelines for Microair Avionics with Research
and Development we are expecting to have our Mode S transponder available in
2007. Euro Control also has a website with FAQ's that may be of assistance.
They can be found at
http://www.eurocontrol.int/corporate...age/index.html
. Public Statement - T2000SFL Transponders
Microair T2000SFL Transponders
Over the past 6 months Microair has received reports of intermittent
operation of T2000SFL Transponder, and in particular poor Mode C response.
Microair has analysed these reports and the operational issues seem to
be associated with areas in which radar sites capable of Mode S are
operating.
Microair has decided to publish a Service Bulletin which will
require operators of T2000SFL's to have their transponders upgraded if they
are operating in Mode S environment.
This Service Bulletin must receive the approval of CASA before it can
be released.
The Service Bulletin will require the replacement of an existing
circuit board and the installation of an additional digital filter. It
should be possible for your local Service Provider to embody this Service
Bulletin.
Please check regularly with this website for more details regarding
this pending Service Bulletin.
Microair
March 2006
. Sun n Fun Travel Log - From Jim Stone (USA)
Ongoing Arrow alternator/charging problem Chuck Owning 6 December 22nd 04 01:18 AM
Mooney Engine Problem in Flight - Advise Paul Smedshammer Owning 17 December 21st 04 06:39 AM
Heater problem fixed! Jim Burns Owning 14 December 17th 04 10:38 PM
Microair vs Becker Ian McPhee Soaring 0 August 30th 03 09:45 PM
Problem: Ground Speed Estimate with Volkslogger and WinPilot RamyYanetz Soaring 3 August 26th 03 03:06 PM
