Problem: Ground Speed Estimate with Volkslogger and WinPilot
Old August 26th 03, 04:56 AM
RamyYanetz
Default Problem: Ground Speed Estimate with Volkslogger and WinPilot
I noticed the same problem with my winpilot/VL, although I don't think it has
anything to do with VL, since the ground speed is correct in the NAV box, but
incorrect only in the final glide display. I reported this problem to Jerry
last year, not sure if it was fixed in later releases.
Ramy
Is anyone else seeing the WinPilot/Volkslogger problem I am seeing?
Running WinPilot v3.019 Adv on an IPAQ 3635. GPS data is from a
Volkslogger. The GPS signal is also fed to a Cambridge LNAV.
Everything works fine except the WinPilot function to estimate task
completion time based on ground speed. This function is found on the
final glide display page (touching the chevrons on the left side of
the map, then pressing the MC button to let finish time computation
use the ground speed.
The WinPilot estimate of ground speed shown is something like 18-20
mph, instead of 50mph+ actual.
My NMEA mask for the Volkslogger is
- - X X X - - - -
Inspection of the NEMA sentances my Volkslogger is putting out all
look ok (short example below). GPGGA (fix data), GPRMC (speed data),
and GPRMB (track data) are all present.
Anyone else have this function working correctly with a Volkslogger
feeding WinPilot?
Bob
==================== Example NEMA Stream ==============
$PGCS,2,VL,175*30
First Time in IMC and vacuum problem Jon Kraus Instrument Flight Rules 51 January 8th 05 09:44 PM
Space Elevator Big John Home Built 111 July 21st 04 05:31 PM
Wing in Ground Effect? BllFs6 Home Built 10 December 18th 03 06:11 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
Antenna Ground Plane Grounding Fastglasair Home Built 1 July 8th 03 06:21 PM
