Why is a standard hold right turns?
Old June 27th 04, 12:35 AM
Roy Smith
Default Why is a standard hold right turns?
It has always struck me odd that a standard landing pattern is left
turns and a standard hold is right turns. Having a left patterns for
landing makes a bit of sense, since the pilot is on the left side of the
cockpit and has a better view of the runway making left turns.
But, for IFR holds, there doesn't seem to be any advantage to one way or
the other. Why did they pick right turns to be standard?
Old June 27th 04, 12:50 AM
Matt Whiting
To balance the wear on the control surfaces. :-)
Matt
Old June 27th 04, 01:39 AM
C J Campbell
"Roy Smith" wrote in message
Um, if you are holding over an airport then you are holding on the opposite
side from the traffic pattern?
Old June 27th 04, 01:43 AM
Bob Gardner
Minimum holding altitude is 2000 agl, according to FAAO 7130.3...hard to
conflict with traffic in the pattern at that altitude.
Bob Gardner
"C J Campbell" wrote in message
opposite
Old June 28th 04, 03:52 AM
Greg Esres
On Sat, 26 Jun 2004 17:43:15 -0700, "Bob Gardner"
My copy says "MHA's are determined by the National Flight Procedures
Office." It also says
2-11. ALTITUDE LEVELS.
....Holding at 2,000' and below requires use of the appropriate pattern
for 2,000'....
Anyway, a local approach has a hold at 2,000 MSL, which is about 1,500
AGL.
Old June 28th 04, 06:24 AM
for 2,000'....
AGL.
You're right; there is no 2,000' floor. It's policy to have controlled
airspace at least 300 feet below the MHA. That is normally accomplished with
Class E 700 AGL airspace. That means, in theory, the MHA could be as low as
1,000 AGL, except no one would design to that assumption. But, 1,200 AGL is
certainly possible because 200 feet is the assumed adverse obstacle height
where no higher obstacles are recorded in the digital obstacle file.
Old June 27th 04, 01:45 AM
Steven P. McNicoll
opposite
Seems rather weak to me. If the weather is good enough for pattern work
there wouldn't seem to be much need to hold.
Old June 27th 04, 02:26 AM
Randy at Home
link.net...
| opposite
Unless you're anywhere near ORD. Then, if someone waters their house plants,
enough water vapor could be injected into the atmosphere through evaporation
to cause delays and holds for hours (I'm only marginally joking here).
Old June 27th 04, 02:28 AM
Steven P. McNicoll
"Randy at Home" wrote in
message
.cable.rogers.com...
house plants, enough water vapor could be injected into the
atmosphere through evaporation to cause delays and holds for
How much pattern work is conducted at ORD?
Old June 27th 04, 02:34 AM
Randy at Home
link.net...
| message
Oh, I know. None. But I couldn't resist. Sorry, Steven. I've been through
there twice a week for the past 16 months and have been on-time less than 20
times. ATC is continually, and inappropriately, blamed.
IFR hold short line at uncontrolled airports? Peter R. Instrument Flight Rules 30 June 9th 04 04:47 AM
Hold at VOR for 2v2 Doug Instrument Flight Rules 21 May 27th 04 11:42 PM
Hold "as published"? John Clonts Instrument Flight Rules 83 November 13th 03 03:19 PM
Random Hold Generator... Tina Marie Instrument Flight Rules 0 November 5th 03 04:21 PM
Need Hold Harmless Waver for Ultralight or Experimental Sale Larry Smith Home Built 9 August 19th 03 02:47 AM
