Hold "as published"?
Old September 17th 03, 11:34 PM
John Clonts
Default Hold "as published"?
Flying to Burnet, Texas (BMQ) the other day:
"Houston Center, 7nz request vectors-to-final Burnet GPS-01, or else request
direct JIBAJ for the GPS-19"
"7nz, you're number three, cleared direct Burnet, expect further clearance
2125"
I didn't understand what he was telling me to do once I got there.
About 5 miles from Burnet:
"Center, 7nz, unclear my instructions when I get to Burnet"
"7nz, fly the hold as published"
I read that back, but then looked on my enroute, and there was no hold. I
looked on my approach plates (GPS-1 and GPS-19) and there was no hold there.
By this time I'm just about to crossing KBMQ.
"Center, 7nz, sorry I see no published hold"
"7nz, sigh then fly heading 270, vectors to Burnet"
I then eventually flew one missed approach (GPS-19) then a successful
approach (GPS-1).
Afterwards it dawned on me that the published hold that he was talking about
was the hold depicted on the BMQ NDB-1 approach plate. The NDB is on the
field, but my mind had been in "gps" mode since I don't have ADF in this
plane.
So my question (finally!) is: was that proper of Center to assign me that
hold "as published"?
Cheers,
John Clonts
Temple, Texas
N7NZ
Old September 18th 03, 01:22 AM
Newps
It's legal but confusing. If it ain't on the enroute chart or the chart
of the approach you are going to be doing it makes no sense to pull a
holding pattern out of your ass from some other approach.
Old September 18th 03, 01:58 AM
Bob Gardner
I would apply the "when in doubt" rule and enter a standard pattern, holding
at the fix inbound on the course on which you approach the fix, and then
argue it out with the controller. Seems pretty clear that he did not want
you to proceed beyond the fix.
Bob Gardner
"John Clonts" wrote in message
request
2125"
there.
approach (GPS-1).
about
plane.
Cheers,
John Clonts
Temple, Texas
N7NZ
Old September 18th 03, 02:26 AM
JerryK
Sounds like you did the correct thing. It is going to ATC awhile to adopt a
GPS mindset.
Old September 18th 03, 02:54 AM
Steven P. McNicoll
request direct JIBAJ for the GPS-19"
2125"
there. By this time I'm just about to crossing KBMQ.
approach (GPS-1).
about was the hold depicted on the BMQ NDB-1 approach plate. The
NDB is on the field, but my mind had been in "gps" mode since I don't
have ADF in this plane.
When the pattern is charted, all holding instructions may be omitted except
the charted holding direction and the statement "as published". He should
have said "hold southwest as published", not "fly the hold as published".
It would probably have also helped if he had previously said "cleared direct
Burnet NDB", and not just "cleared direct Burnet".
Old September 18th 03, 02:55 AM
Steven P. McNicoll
"Bob Gardner" wrote in message
news:ky6ab.488979$Ho3.82818@sccrnsc03...
holding at the fix inbound on the course on which you approach the fix,
and then
I like to apply the "when in doubt, clarify" rule as my standard.
Old September 18th 03, 02:59 AM
Robert Henry
Actually, I think they have the mindset, but don't understand the ergonomic
factors that can be encountered trying to use it.
For example, I've twice been cleared to random 5-letter fixes which do not
appear on enroute charts that turn out to be IF's for ILS approaches. These
clearances were issued en route, 60-100 miles away from the airport, well
before an expected approach had been specified. Actually, both approaches
ended up being visuals. I don't know every 5 character permutation of
"wip-pee" intersection and which one applies - running through the guesses
takes some serious knob time. Yet there's always a certain irritation
(noted by the poster as well) in the response to the request for
clarification, the spelling in my example.
Maybe a screenshot of a Garmin 430 with intersections and data fields
represented on the 100nm scale will help to convey the problem.
Bob
PP-ASEL-IA, A/IGI
"JerryK" wrote in message
news:_Y6ab.487139$YN5.330405@sccrnsc01...
a
GPS mindset.
Old September 18th 03, 03:33 AM
John R. Copeland
Heh!
I was once cleared to a lat/lon point 300 miles away from my St. Louis =
departure!
Turned out to be a VORTAC location that I'd actually filed to.
Somebody was foolin' with me.
I told clearance delivery I'd read back the clearance, soon as I found =
that lat/lon point.
---JRC---
"Robert Henry" wrote in message =
news:9s7ab.18898$pe.10355@lakeread06...
Actually, I think they have the mindset, but don't understand the =
ergonomic
=20
For example, I've twice been cleared to random 5-letter fixes which do =
not
appear on enroute charts that turn out to be IF's for ILS approaches. =
These
clearances were issued en route, 60-100 miles away from the airport, =
well
before an expected approach had been specified. Actually, both =
approaches
"wip-pee" intersection and which one applies - running through the =
guesses
=20
=20
=20
Bob
PP-ASEL-IA, A/IGI
=20
Sounds like you did the correct thing. It is going to ATC awhile to =
adopt
a
GPS mindset.
=20
Old September 18th 03, 03:48 AM
Bob Gardner
That's what he tried to do, as I understand it, but he was right on top of
the fix at the time. Gotta do something while seeking clarification.
Bob Gardner
ink.net...
and then
want
Old September 18th 03, 04:04 AM
Steven P. McNicoll
news:k98ab.487586$YN5.331114@sccrnsc01...
After being told, "7nz, you're number three, cleared direct Burnet, expect
further clearance
2125", he said he didn't understand what he was supposed to do once he got
there. That was well before he reached the NDB.
Screw hold repair in fabric? Brian Huffaker Home Built 11 May 29th 04 03:07 AM
Need Hold Harmless Waver for Ultralight or Experimental Sale Larry Smith Home Built 9 August 19th 03 03:47 AM
Need a Waiver/ Hold Harmless Agreement for UL / Experimental Sale Richard_Tonry Home Built 2 August 17th 03 01:58 PM
