Help understanding Aspen VOR/DME approach
Old August 6th 06, 12:02 AM posted to rec.aviation.ifr
SimGuy
Default Help understanding Aspen VOR/DME approach
The plate is here-
http://www.airnav.com/depart?http://.../05889VDGC.PDF
While trying to fly the approach in the sim I flew to the MAP with
relative ease but had trouble getting low enough to make the runway
without getting too hot. Looking at the plate it seems a drop of 2380'
must be made between MAFMU and the runway in a lateral distance of
1.4NM, this is a descent angle of 15 degrees!
Could someone please confirm this or help with my interpretation of
the chart. I am a PP beginning instrument training.
TIA
Old August 6th 06, 12:11 AM posted to rec.aviation.ifr
Sam Spade
SimGuy wrote:
The plate is here-
TIA
It is circling only minimums because of the steep descent angle.
It is a form of "Let the buyer beware."
Old August 6th 06, 12:13 AM posted to rec.aviation.ifr
Paul Tomblin
In a previous article, said:
The plate is here-
Well, yes, if you don't see the runway until the MAP and then want to land
on the runway ahead, you will have a very steep descent. But there are
two factors mitigating that:
- you might see the runway earlier and
- it's a circling approach, so you can circle around airport to descend if
you need to.
Paul Tomblin http://xcski.com/blogs/pt/
I used up all my sick days, so I'm calling in dead.
Old August 6th 06, 12:18 AM posted to rec.aviation.ifr
Sam Spade
The plate is here-
you need to.
At Aspen, circling around the airport is very risky business.
Old August 7th 06, 01:26 AM posted to rec.aviation.ifr
Blanche Cohen
Unless you're at 20,000 ft. Ok, maybe 18K.
Old August 7th 06, 02:10 AM posted to rec.aviation.ifr
Sam Spade
But, those altitudes are in Class A airspace. ;-)
17,000 feet will provide legal en route (and circling ;-) altitude for
the entire 48 states.
Old August 7th 06, 01:40 AM posted to rec.aviation.ifr
Jim Carter[_1_]
-----Original Message-----
Posted At: Saturday, August 05, 2006 6:19 PM
Posted To: rec.aviation.ifr
Conversation: Help understanding Aspen VOR/DME approach
Subject: Help understanding Aspen VOR/DME approach
The plate is here-
http://www.airnav.com/depart?http://204.108.4.16/d-
tpp/0608/05889VDGC.PDF
2380'
to
land
are
descend
if
you need to.
No kidding!! Isn't that why we all learned steep-turns-about-a-point?
Even the 360-overhead would be thrilling at Aspen.
Old August 7th 06, 02:13 AM posted to rec.aviation.ifr
Sam Spade
If a pilot is going to do those types of maneuvers at Aspen, then he or
she better have the right airplance and be very familiar with the airport.
Those two factors always greatly improve the safety margin. But, that
becomes, more or less, a special-qualification circumstance, as opposed
to "plain old TERPS."
Old August 7th 06, 12:42 PM posted to rec.aviation.ifr
Denny
Just for grins fly the sim approach in the Baron, without circling...
It can be done but you need to be determined...
denny
Old August 6th 06, 12:53 AM posted to rec.aviation.ifr
SimGuy
On Sat, 5 Aug 2006 23:13:21 +0000 (UTC),
The plate is here-
you need to.
Even if the runway is spotted well before the MAP, say at, ALLIX, it's
a very steep descent. At 100kts it is 1140fpm.
I'm not an expert, but this looks like a tough approach; the MA looks
challenging too. Would it even be possible in a 172 or would it would
too under-powered? I imagine you would want something with plenty of
extra oomph.
OLV GPS 36 approach question A Lieberma Instrument Flight Rules 59 August 15th 06 12:32 AM
procedure turns revisited [email protected] Instrument Flight Rules 37 June 20th 06 03:39 AM
VOR/DME approach radio calls Derek Fage Instrument Flight Rules 12 December 8th 04 11:36 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 04:03 PM
