VOR/DME approach radio calls
Old November 8th 04, 07:08 PM
Derek Fage
Default VOR/DME approach radio calls
Hi there,
Could somebody point me to the official FAA document that describes the
calls required for all stages of an VOR/DME approach including the hold
(beacon outbound / beacon inbound etc...)
Derek...
Old November 8th 04, 07:55 PM
Ron Natalie
Derek Fage wrote:
Hi there,
How about the AIM? 5-3-2, 5-3-3
Old November 8th 04, 08:03 PM
Ron Rosenfeld
On Mon, 8 Nov 2004 19:08:05 -0000, "Derek Fage"
Hi there,
Derek...
There is no listing of approach-specific calls.
There is one "regulation" concerning required radio calls in Title 14 of
the Code of Federal Regulations pertaining to small GA a/c:
91.183 IFR radio communications.
The pilot in command of each aircraft operated under IFR in controlled
airspace shall have a continuous watch maintained on the appropriate
frequency and shall report by radio as soon as possible—
(a) The time and altitude of passing each designated reporting point, or
the reporting points specified by ATC, except that while the aircraft is
under radar control, only the passing of those reporting points
specifically requested by ATC need be reported;
(b) Any unforecast weather conditions encountered; and
(c) Any other information relating to the safety of flight.
In a related but somewhat different category, there are rules requiring
ATC contact in different airspaces.
There are also "recommendations" in the Aeronautical Information Manual:
5-3-3. Additional Reports
a. The following reports should be made to ATC or FSS facilities
without a specific ATC request:
1. At all times.
(a) When vacating any previously assigned altitude or flight
level for a newly assigned altitude or flight level.
(b) When an altitude change will be made if operating on a
clearance specifying VFR-on-top.
(c) When unable to climb/descend at a rate of a least
500 feet per minute.
(d) When approach has been missed. (Request clearance for
specific action; i.e., to alternative airport, another approach, etc.)
(e) Change in the average true airspeed (at cruising altitude)
when it varies by 5 percent or 10 knots (whichever is greater) from that
filed in the flight plan.
(f) The time and altitude or flight level upon reaching a
holding fix or point to which cleared.
(g) When leaving any assigned holding fix or point.
NOTE-
The reports in subparagraphs (f) and (g) may be omitted by
pilots of aircraft involved in instrument training at military terminal
area facilities when radar service is being provided.
(h) Any loss, in controlled airspace, of VOR, TACAN, ADF, low
frequency navigation receiver capability, GPS anomalies while using
installed IFR-certified GPS/GNSS receivers, complete or partial loss of ILS
receiver capability or impairment of air/ground communications capability.
Reports should include aircraft identification, equipment affected, degree
to which the capability to operate under IFR in the ATC system is impaired,
and the nature and extent of assistance desired from ATC.
NOTE-
1. Other equipment installed in an aircraft may effectively
impair safety and/or the ability to operate under IFR. If such equipment
(e.g. airborne weather radar) malfunctions and in the pilot's judgment
either safety or IFR capabilities are affected, reports should be made as
above.
2. When reporting GPS anomalies, include the location and
altitude of the anomaly. Be specific when describing the location and
include duration of the anomaly if necessary.
(i) Any information relating to the safety of flight.
2. When not in radar contact.
(a) When leaving final approach fix inbound on final approach
(nonprecision approach) or when leaving the outer marker or fix used in
lieu of the outer marker inbound on final approach (precision approach).
(b) A corrected estimate at anytime it becomes apparent that an
estimate as previously submitted is in error in excess of 3 minutes.
b. Pilots encountering weather conditions which have not been forecast,
or hazardous conditions which have been forecast, are expected to forward a
report of such weather to ATC.
--ron
Old November 8th 04, 08:37 PM
Derek Fage
Thanks Ron,
I should have said that I'd looked through the AIM, but it does not really
"spell it out".
I was relly looking for something that documented the precise required calls
for entering the hold, calling beacon outbound (and whether you should say
"in the procedure" or "ready for the procedure" and then beacon inbound
etc..
I've found a few references on the internet using Google to search for
"beacon outbound", but these tend to be either flight reports or
"non-official" sources, and I was hoping for something a bit more "formal".
I must admit that seeing how the FAA are keen on regulations and
documentation, that this is an area that seems to be lacking in definitive
requirements.
Interestingly, even the AIM recomendations seem unusually vague on this
aspect of RT procedure.
In the absence of anything official, what about some input from the ATC
guys - what are you looking for (specifically with regard to the beacon
outbound and beacon inbound calls which I'm getting some conflicting
information on from talking to colleagues).
Regards,
Derek...
"Ron Rosenfeld" wrote in message
Hi there,
Derek...
frequency and shall report by radio as soon as possible-
1. At all times.
NOTE-
ILS
impaired,
NOTE-
above.
a
--ron
Old November 9th 04, 03:58 AM
Andrew Sarangan
"Derek Fage" wrote in news:418fc41a$1
@news.itconsult.net:
Hi there,
Derek...
What is special about a VOR/DME approach with respect to the radio calls?
You do all the approaches the same way - get an approach clearance, change
to advisory frequency, announce your arrival and cancel with ATC. If it is
a towered airport, you also need a landing clearance but you don't have to
cancel.
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old November 9th 04, 12:31 PM
Ron Rosenfeld
On Mon, 8 Nov 2004 20:37:30 -0000, "Derek Fage"
Common sense, and an attempt to minimize air time would be useful.
For example, you have been requested to report PT inbound:
"Foobar Approach, N12345 PT inbound"
--ron
Old November 12th 04, 02:44 AM
Chuck Forsberg
If practicing an approach under the hood in VFR wx to
an uncontrolled airport, give your position in terms
that VFR only pilots can understand. Many VFR pilots
don't know what an outer markers or intersections are,
let alone their locations. Same goes for the IFR missed
approach procedure.
Chuck Forsberg www.omen.com 503-614-0430
Developer of Industrial ZMODEM(Tm) for Embedded Applications
Omen Technology Inc "The High Reliability Software"
10255 NW Old Cornelius Pass Portland OR 97231 FAX 629-0665
Old November 12th 04, 04:31 AM
Steven P. McNicoll
"Chuck Forsberg" wrote in message
news
approach procedure.
Advisory Circular 90-42F "Traffic Advisory Practices at Airports Without
Operating Control Towers" provides examples of self-announce phraseologies
for various situations. It provides the following for practice instrument
approaches:
"STRAWN TRAFFIC, CESSNA TWO ONE FOUR THREE QUEBEC (NAME-FINAL APPROACH FIX)
INBOUND DESCENDING THROUGH (ALTITUDE) PRACTICE (TYPE) APPROACH RUNWAY THREE
FIVE STRAWN"
Old November 12th 04, 12:12 PM
Matt Whiting
news
approach procedure.
approaches:
FIVE STRAWN"
How does that help a VFR pilot who not only has no approach plates but
doesn't even know what the final approach fix is? I usually state where
I am in relatio to the field, so many miles at a given direction along
with altitude and then mention that I'm on a practice approach.
Matt
Old November 12th 04, 01:51 PM
Ron Natalie
Any time you are making reports on th CTAF it behooves you
to do so. Even IFR-savvy pilots may be unfamiliar with
intersection names unless they have committed that particular
approach to memory. "2 Mile final for runway 5" is much better
than "LOONY inbound" as a CTAF report.
However, we were talking about making reports to ATC.
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 04:03 PM
Approach Question- Published Missed Can't be flown? Brad Z Instrument Flight Rules 8 May 6th 04 04:19 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 11:13 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
