Hi,
Does anybody know portable expanders to plug 4 intercoms into an builtin 2 place-Intercom. I sometimes rent aircrafts having only a two-place Interkom but would like also to speak with the passengers. |
Ingo,
Does anybody know portable expanders to plug 4 intercoms into an builtin 2 place-Intercom. I sometimes rent aircrafts having only a two-place Interkom but would like also to speak with the passengers. The solution is to plug a portable 4-place-intercom into the pilot side of the built-in intercom and plug all headsets into the portable. The disadvantages a - A built-in PTT on the copilot side will not work - The built-in PTT on the pilot side will work, but everybody speaking on the intercom circuit at the time will get transmitted. -- Thomas Borchert (EDDH) |
Thomas Borchert wrote: Ingo, Does anybody know portable expanders to plug 4 intercoms into an builtin 2 place-Intercom. I sometimes rent aircrafts having only a two-place Interkom but would like also to speak with the passengers. The solution is to plug a portable 4-place-intercom into the pilot side of the built-in intercom and plug all headsets into the portable. The disadvantages a - A built-in PTT on the copilot side will not work - The built-in PTT on the pilot side will work, but everybody speaking on the intercom circuit at the time will get transmitted. Be careful! You may get interference when you transmit or you may get interference on one of the intcoms from feedback. |
John,
Be careful! You may get interference when you transmit or you may get interference on one of the intcoms from feedback. How? Also: Just switch off the interal intercom. -- Thomas Borchert (EDDH) |
Thomas Borchert wrote: John, Be careful! You may get interference when you transmit or you may get interference on one of the intcoms from feedback. How? Also: Just switch off the interal intercom. Originally, I thought it was due to the sidetone, so I tried turning off one, then they other. It didn't help. I never did figure out what the cause was. |
John,
Originally, I thought it was due to the sidetone, so I tried turning off one, then they other. It didn't help. I never did figure out what the cause was. Weird. Might be faulty wiring. -- Thomas Borchert (EDDH) |
Ingo Wolf wrote:
Hi, Does anybody know portable expanders to plug 4 intercoms into an builtin 2 place-Intercom. I sometimes rent aircrafts having only a two-place Interkom but would like also to speak with the passengers. I just use a 4 place portable. Your options are to plug it into the copilot position, or just bypass the onboard intercom entirely and plug all the headsets into the the portable and then the portable plugs into the pilot jacks. |
| Thread Tools | |
| Display Modes | |
| Good panel mount COM radio and intercom w/push-to-talk? | John Huebbe | Home Built | 10 | November 27th 04 08:58 PM |
| Funky place to store your fuel? | BllFs6 | Home Built | 5 | August 23rd 04 02:27 AM |
| FS: Soft Comm ATC-4Y 4 place portable intercom | Jaysen Underhill | Instrument Flight Rules | 0 | December 11th 03 10:41 PM |
| FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 | Jaysen Underhill | Instrument Flight Rules | 0 | September 4th 03 05:41 AM |
| For Sale: Sigtronics SPA-400 TSO panel mount intercom 4 place | Snowbird | Aviation Marketplace | 0 | August 25th 03 04:01 PM |
