Glider transponder on?
Old September 14th 06, 05:41 PM posted to rec.aviation.ifr
Sam Spade
Default Glider transponder on?
On August 28th, Hawker biz jet and a glider collided south of Reno,
Nevada at 16,000 feet. Fortunately, everyone survived. The Hawker was
IFR and flying a STAR into KRNO. Following is an excerpt from the
NTSB's preliminary report (LAX06FA277A):
"The glider was equipped with a panel mounted communication radio,
global positioning system (GPS) unit, and a transponder; however, the
pilot did not turn on the GPS and transponder. The transponder's
activation is not required for glider operations (for more details see
14 CFR Part 91.215). According to the glider pilot, he did not turn on
the transponder because he was only intending on remaining in the local
glider area, and because he wanted to reserve his batteries for radio
use. The glider was equipped with two batteries (one main and one
spare), however, due to the previous glider flights, the pilot was
unsure of the remaining charge in the battery."
I'd be interested in opinions about the legal conclusion the NTSB makes
in their preliminary report as to whether the glider pilot did, or did
not, have to have his transponder turned on:
"The transponder's activation is not required for glider operations (for
more details see 14 CFR Part 91.215)."
My take on 91.215 is that the NTSB is wrong. It was elective to install
a transponder in the glider, but because it was installed it had to be
on unless it was broken
Old September 14th 06, 07:06 PM posted to rec.aviation.ifr
Steven P. McNicoll[_1_]
"Sam Spade" wrote in message
IFR and flying a STAR into KRNO. Following is an excerpt from the NTSB's
"The glider was equipped with a panel mounted communication radio, global
positioning system (GPS) unit, and a transponder; however, the pilot did
not turn on the GPS and transponder. The transponder's activation is not
required for glider operations (for more details see 14 CFR Part 91.215).
According to the glider pilot, he did not turn on the transponder because
he was only intending on remaining in the local glider area, and because
he wanted to reserve his batteries for radio use. The glider was equipped
with two batteries (one main and one spare), however, due to the previous
glider flights, the pilot was unsure of the remaining charge in the
battery."
I'd be interested in opinions about the legal conclusion the NTSB makes in
their preliminary report as to whether the glider pilot did, or did not,
My take on 91.215 is that the NTSB is wrong. It was elective to install a
transponder in the glider, but because it was installed it had to be on
I believe a report on this accident indicated the transponder was not
"certified". I don't know what was meant by that, but if it means the
transponder wasn't maintained in accordance with FAR 91.413 then the pilot
would be in violation if he had turned it on.
Old September 15th 06, 05:45 AM posted to rec.aviation.ifr
Sam Spade
battery."
If that were the case, then the transponder would have had to been
placarded as inoperative. That is inconsistent with the excerpt from
the NTSB preliminary I posted.
Old September 14th 06, 07:09 PM posted to rec.aviation.ifr
Jim Macklin
I think you are correct.
south of Reno,
The Hawker was
from the
however, the
transponder's
details see
not turn on
in the local
batteries for radio
and one
pilot was
the NTSB makes
did, or did
operations (for
elective to install
it had to be
Old September 14th 06, 11:23 PM posted to rec.aviation.ifr
Bill[_4_]
According to a person in the area who knows about this...
most of the flights far out last the battery capacity.
So they are off for a good portion of the flight.
Bill H.
south of Reno,
The Hawker was
from the
however, the
transponder's
details see
not turn on
in the local
batteries for radio
and one
pilot was
the NTSB makes
did, or did
operations (for
elective to install
it had to be
Old September 15th 06, 02:15 AM posted to rec.aviation.ifr
John Godwin
Probably because the glider was not originally certificated with an
engine-driven electrical system.
Has a glider ever been found using the transponder radar track? Eric Greenwell Soaring 14 February 3rd 05 02:41 PM
Bad publicity David Starer Soaring 18 March 8th 04 03:57 PM
glider transponder Chris Marren Soaring 6 December 5th 03 10:39 PM
I wish I'd never got into this... Kevin Neave Soaring 32 September 19th 03 12:18 PM
