My top surface mylar seems to have lost some of it's curvature, because
it doesn't quite touch the aileron and flaps when they are in positive positions. Does anyone know a way to put the curve back into the mylar without removing it? It's so well adhered and smoothly installed, I'd like to leave it on if at all possible, but I think it may be degrading my climb while thermalling. The mylar is almost 12 years old. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Eric, I would think that mylar that is 12 years old would have lost its
flexibility. It gets pushed up with upward aerleron or negative flap settings and tends to stay there or very slowly flex back down to "neutral". So going to positve settings will be difficult. I don't know how you could put "life" back into the old plastic, but I would be interested to hear. BT "Eric Greenwell" wrote in message news:JfBYg.3919$5v5.3761@trndny08... My top surface mylar seems to have lost some of it's curvature, because it doesn't quite touch the aileron and flaps when they are in positive positions. Does anyone know a way to put the curve back into the mylar without removing it? It's so well adhered and smoothly installed, I'd like to leave it on if at all possible, but I think it may be degrading my climb while thermalling. The mylar is almost 12 years old. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Eric,
The Mylar is originally curved by passing the strip through a set of curved, heated rollers. Complicated enough, all by itself (g) . . . to do the chore with the Mylars still attached to the plane is beyond my admittedly limited experience. bumper "Eric Greenwell" wrote in message news:JfBYg.3919$5v5.3761@trndny08... My top surface mylar seems to have lost some of it's curvature, because it doesn't quite touch the aileron and flaps when they are in positive positions. Does anyone know a way to put the curve back into the mylar without removing it? It's so well adhered and smoothly installed, I'd like to leave it on if at all possible, but I think it may be degrading my climb while thermalling. The mylar is almost 12 years old. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
bumper wrote:
The Mylar is originally curved by passing the strip through a set of curved, heated rollers. Complicated enough, all by itself (g) . . . to do the chore with the Mylars still attached to the plane is beyond my admittedly limited experience. I am interested in finding out more about this roller process? Any pictures or detailed descriptions available? For my projects in the past, I successfully made my own curved Mylar strips in 5ft sections Udo |
A friend of mine tried to make his own curving machine, using
a length of steel pipe and a propane torch. We had great fun watching as he burned his fingers and leaped about yelling "Ouch ! Ouch !" and made all manner of wavy plastic, but it did get a bit scary when he almost set his shop afire. After that he ordered new pre-curved mylar from Germany. See ya, Dave PS: I'm sure Bumper could do better ! But not as entertaining. PPS: Pipe is the wrong idea; as you pass the myler through it heats the edges and not the area needing the curve... PPPS: Bumper already knew that. bumper wrote: The Mylar is originally curved by passing the strip through a set of curved, heated rollers. Complicated enough, all by itself (g) . . . |
Unless you've ot a *really* long oven, that leaves you with
a lot of small pieces, no ? Its a lot nicer (and easier to apply with proper technique) to have longer strips, no ? Best Regards, Dave KM wrote: Dave, Here is what I do.I buy the 7 mil sheets (I figure it provides less friction than the 10 mil) and roll it up inside of a peice of carpet roll tube.Then I bake it at about 160 in the oven for 30 minutes.Then cut it into strips and use scotch 665 double sided tape to adhear it to the wings and 3M 850 mylar tape for the safety strip.I can do top and bottom of my flaps ailerons and tail a couple times over for about 50 bucks.I replace it every 3 to 5 years and I have never had a problem.This does seem a little less entertaning than your buddys method, but it works fine. K Urban |
After 12 years the adhesive tape used to hold the seal in place has
deteriorated to the point that your original seal installation may be unsafe. I've seen approx. 10 years seal installations where the adhesive is about to release the seal. A small tug on the seal itself and the seal may slip away from the adhesive. A lost seal inflight is something we all must avoid at all cost. Control surfaces can stop working after a total or partial separation. I think 7-8 years is max any seal installation should be trusted because of the potential loss of adhesion. Also,the seal itself has deteriated from UV ( why it has lost the heat induced curvature) and although is safe with regard to its physical intregrity, new ones would look a whole lot nicer and a new seal with new adhesive, a lot safer. I think seal installations on gliders can be potentially the weakest link in our sport. A failed seal can kill you and we should all be aware of time limiations. This winter I am reprofiling my wings and quess what, my seals will be replaced after 5 years. bob fidler "Eric Greenwell" wrote in message news:JfBYg.3919$5v5.3761@trndny08... My top surface mylar seems to have lost some of it's curvature, because it doesn't quite touch the aileron and flaps when they are in positive positions. Does anyone know a way to put the curve back into the mylar without removing it? It's so well adhered and smoothly installed, I'd like to leave it on if at all possible, but I think it may be degrading my climb while thermalling. The mylar is almost 12 years old. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
| Glider transponder on? | Sam Spade | Instrument Flight Rules | 5 | September 15th 06 06:45 AM |
| Aerodynamics of carrying water | Gene Whitt | Soaring | 54 | October 19th 05 08:24 PM |
| Bad publicity | David Starer | Soaring | 18 | March 8th 04 04:57 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| I wish I'd never got into this... | Kevin Neave | Soaring | 32 | September 19th 03 01:18 PM |
