What is the best way to secure plastic tubing to aluminum pitot tubes.
The plastic hose will slide over the aluminum tube, though it requires quite a bit of push to get more than 1/2". Would a couple of spring clamps work, or is something more significant called for? |
![]() Ernest Christley wrote: What is the best way to secure plastic tubing to aluminum pitot tubes. The plastic hose will slide over the aluminum tube, though it requires quite a bit of push to get more than 1/2". Would a couple of spring clamps work, or is something more significant called for? Hi, Use a hair drier to warm the plastic tube and it will slide more easily. While the tube is still warm use a small tie wrap. Voilą! Regards, S6 |
Anything that might make the plastic tube "bunch up" so as to create a leak
path is a bad idea. Wire and clamps seem to do this. The solution is "castrating rings" (No kidding). See: http://www.agri-pro.com/Castrate.html#rings Roll one of these over the plastic tube after you slip it over the aluminum tube to get an air tight fit. Bill Daniels "Ernest Christley" wrote in message .. . What is the best way to secure plastic tubing to aluminum pitot tubes. The plastic hose will slide over the aluminum tube, though it requires quite a bit of push to get more than 1/2". Would a couple of spring clamps work, or is something more significant called for? |
On Sun, 22 Oct 2006 02:22:19 GMT, Ernest Christley wrote:
What is the best way to secure plastic tubing to aluminum pitot tubes. The plastic hose will slide over the aluminum tube, though it requires quite a bit of push to get more than 1/2". Would a couple of spring clamps work, or is something more significant called for? I put a twist of safety wire around it.... Ron Wanttaja |
![]() What is the best way to secure plastic tubing to aluminum pitot tubes. The plastic hose will slide over the aluminum tube, though it requires quite a bit of push to get more than 1/2". Would a couple of spring clamps work, or is something more significant called for? I put a twist of safety wire around it.... Do you go around it twice before twisting, to avoid "bunching" ? -- Jim in NC |
On Sat, 21 Oct 2006 23:24:01 -0400, "Morgans" wrote:
What is the best way to secure plastic tubing to aluminum pitot tubes. The plastic hose will slide over the aluminum tube, though it requires quite a bit of push to get more than 1/2". Would a couple of spring clamps work, or is something more significant called for? I put a twist of safety wire around it.... Do you go around it twice before twisting, to avoid "bunching" ? "You only go around once in life...." ....and so do my pitot/static safety wires. Maybe that explains my 150 knot cruise. :-) Ron Wanttaja |
![]() "Ron Wanttaja" wrote ...and so do my pitot/static safety wires. Maybe that explains my 150 knot cruise. :-) ********************************* Chuckle out loud Perhaps you got one of those wires twisted tooo tightly in the wrong place. Perhaps around your "truth tube", whatever that is! (get your mind out of the gutter-it was not meant "that" way!) -- Jim in NC |
Ron Wanttaja wrote:
On Sun, 22 Oct 2006 02:22:19 GMT, Ernest Christley wrote: What is the best way to secure plastic tubing to aluminum pitot tubes. The plastic hose will slide over the aluminum tube, though it requires quite a bit of push to get more than 1/2". Would a couple of spring clamps work, or is something more significant called for? I put a twist of safety wire around it.... I've got these non reusable clamps that I have on my soda lines (which are under pressure) in my kitchen. You have to have a little tool (looks like a pair of end nippers) to squeeze them on. |
Ron Natalie wrote:
Ron Wanttaja wrote: On Sun, 22 Oct 2006 02:22:19 GMT, Ernest Christley wrote: What is the best way to secure plastic tubing to aluminum pitot tubes. The plastic hose will slide over the aluminum tube, though it requires quite a bit of push to get more than 1/2". Would a couple of spring clamps work, or is something more significant called for? I put a twist of safety wire around it.... I've got these non reusable clamps that I have on my soda lines (which are under pressure) in my kitchen. You have to have a little tool (looks like a pair of end nippers) to squeeze them on. I hope your soda lines are of the type which is amenable with Scots whisky--?? |
jerry wass wrote:
I hope your soda lines are of the type which is amenable with Scots whisky--?? Put fizzy stuff in the whiskey? Are you daft. It does dispense tonic for the gin however. |
Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gear for B-17 setup | Juan Jimenez | General Aviation | 7 | September 19th 06 10:20 PM |
Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gear for B-17 setup | Juan Jimenez | Aviation Marketplace | 7 | September 19th 06 10:20 PM |
Proposed AD ECi connecting rods | Jim Burns | Owning | 8 | October 8th 05 04:27 PM |
Seeking US Source for Main Wheel Tubes | Chris OCallaghan | Soaring | 7 | August 28th 04 03:46 PM |
Rockets used in al-Rashid hotel match "aluminum tubes" rockets | Robb McLeod | Military Aviation | 7 | October 28th 03 07:49 AM |
