Seeking US Source for Main Wheel Tubes
Old August 25th 04, 10:21 PM
Chris OCallaghan
Default Seeking US Source for Main Wheel Tubes
I was disappointed by Desser Tire of Memphis Tennessee last week when
they sent me three 5.00-5 tubes with a valve unsuitable for my wheel
(interferes with landing gear strut). They assured me this was the
only available valve and would work for my sailplane. I've removed
them from my list of suppliers.
I am currently seeking a source for 5.00-5 short valve and double bend
valve tubes common to glider applications. My preference is for the
Michelin Airstop TR-67A with short 90-degree bend valve. My preference
would be for an intelligent supplier with dedicated to customer
service. Price is secondary. If you have a suggestion, please share.
Thanks.
OC
Old August 26th 04, 01:43 AM
Nolaminar
Does Seibert in Munster, German supply such items?
GA
Old August 26th 04, 03:37 AM
Neal Pfeiffer
Check http://www.eglider.org/catalog/subcat11.htm for one possibility.
njp
Thanks.
OC
Old August 26th 04, 03:08 PM
Thomas Knauff
We stock them.
Thomas Knauff
Knauff & Grove, Inc.
Schempp-Hirth Sailplanes
3523 South Eagle Valley Road
Julian, Pa 16844
Phone (814) 355 2483
Fax (814) 355 2633
www.eglider.org
"Neal Pfeiffer" wrote in message
m...
njp
Thanks.
OC
Old August 27th 04, 06:21 PM
Chip Bearden
Had a similar problem with them trying to get tail dolly tubes. At
that time they stocked several different valve stem types but it took
a few phone calls to sort it out. My spare main tubes came from them
but that was a few years ago.
In an emergency it is fairly easy to modify the stem by cutting it,
sleeving it with brass model tube, and silver soldering. Had to do
that once when I forgot to remove the stem extender.
Probably easier to support your favorite glider parts dealer.
Easier still is replacing the tail dolly tube/wheel with a solid
rubber wheel from Home Depot. It's not TSO'd, but hopefully you'll
never take it with you in flight.
Chip Bearden
Old August 28th 04, 03:51 AM
Eric Greenwell
Or, for a particularly heavy tail like my ASH 26 E, I replaced the
entire caster unit, wheel and all, with a heavier duty one from Harbor
Freight. It was $10, so I bought a spare. I couldn't find a suitable
solid one, as they were either too hard and didn't roll well over cracks
and bumps, or didn't have sufficient load capacity (the problem with the
original tube and tire).
Eric Greenwell
Washington State
USA
Old August 28th 04, 03:46 PM
Chris OCallaghan
Received some particularly useful information via email.
TOST replaces the stock valve on the tubes they use in their wheel
assemblies. There is no indication of the change on the tube; however,
the valve is marked. When ordering, it is important to note the valve
imprint (as opposed to the stamp on the tube itself). I should note
that the original tube (the one I replaced) developed a leak along the
seam of the vulcanized, non-standard valve. I plan to inspect these
tubes carefully in future before putting a new one into service.
For my Ventus 2bx, the valve is marked as follows:
Alligator
TR88eq
Made in Germany
This is the short valve stem with a 90-degree bend. The double bend
long stem valve from the Nimbus 3 tube also works, though clearance
with the gear strut is marginal.
Many thanks to PSU, who kept me in the contest at Uvalde by lending me
his spare.
Thanks all for your help.
VW-1 C-121J landing with unlocked nose wheel Mel Davidow LT USNR Ret Military Aviation 1 January 19th 04 05:22 AM
Tailwheel endorsement John Harper Piloting 58 December 12th 03 01:48 PM
The Little Wheel in Back Veeduber Home Built 6 September 8th 03 10:29 AM
