NDB Holds
Old October 27th 06, 10:35 PM posted to rec.aviation.ifr
Alan Burke
Default NDB Holds
Hi,
I'm studying for my IR and having some trouble in calculating the outbound
times. Has anyone got any easy way of calculating the times.
Old October 27th 06, 10:59 PM posted to rec.aviation.ifr
Jose[_1_]
Default NDB Holds
What I do in real life is to time the inbound, and then whatever the
error is on the inbound, I apply it to the outbound the opposite way.
It may take a couple of turns to get it right since the relationship is
not linear, but for small wind speeds compared to aircraft speeds, it
seems to work well enough.
Time outbound one minute. Time inbound. Say it's forty seconds.
That's twenty seconds too little, so next time go outbound a minute and
twenty seconds. Time the inbound. Say it's fifty-five seconds. Next
time go outbound another five seconds - that is, go out a minute and
twenty-five seconds. Iterate until happy.
If interested, the actual formula is:
(where v is velocity, t is time, and d is distance)
v = d / t
or
d = v t
The two distances (along the inbound course) will be the same, to first
order, so set them equal.
d = (v1)(t1) = (v2)(t2)
Rewrite v1 as v+w and v2 as v-w (where w is wind speed)
Rewrite t1 as t and t2 as t+d
(where d is the difference between one minute (t1) and the inbound.)
We end up with
(2w)/(v-w) = d
If I didn't mess anything up. (this doesn't take the crosswind's effect
on the half circle sizes into effect).
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old October 27th 06, 11:09 PM posted to rec.aviation.ifr
Mark Hansen
Default NDB Holds
On 10/27/06 14:35, Alan Burke wrote:
Hi,
Alan,
See Jose's answer for the timing. All I wanted to add was that you
should guestimate the crosswind correction before entering the hold,
and apply this on the first leg. Otherwise, the crosswind may really
mess with the timings.
Remember to adjust for the crosswind on the inbound leg as well ;-)
I would have guessed your question would have been more like "how do
you tell when to *begin* timing on the outbound leg".
.... perhaps that's still coming ;-)
I hope that you'll post more about your IR adventures. I sure would like
to read about them and participate in answering questions, etc.
Best Regards,
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old October 28th 06, 02:14 AM posted to rec.aviation.ifr
Sam Spade
Default NDB Holds
Hi,
Keep in mind, as you progress with this, that the "rule" is to not
exceed one minute inbound to the NDB.
Old October 28th 06, 07:33 AM posted to rec.aviation.ifr
Alan Burke
Default NDB Holds
Thanks guys for the response. What I suppose I am asking if how do you work
out the times (pre-planning) of the hold. I.e if you know the wind direction
and speed for the hold, I've worked out the single drift and in my notes it
says to work out the timings use 75% of the head / tail wind factor.
This is where I get stuck. How do you work that out??
"Sam Spade" wrote in message
Hi,
outbound times. Has anyone got any easy way of calculating the times.
Keep in mind, as you progress with this, that the "rule" is to not exceed
Old October 28th 06, 02:59 PM posted to rec.aviation.ifr
Roy Smith
Default NDB Holds
Don't try to "work it out". Your primary job is to fly the airplane, not
work out complex geometry problems.
As you're approaching the hold, take a WAG (Wild Assed Guess) at wind
strength. In most common trainers, you'll be holding at about 90 kts. A
really big headwind component on your outbound leg would be 30 kts, making
your outbound groundspeed 60, and your inbound groundspeed 120 (double your
outbound).
So, that's pretty much an upper limit, and gives you your first WAG: with a
really honking headwind outbound, fly the outbound leg for 2 minutes.
Estimate down from the with a moderate headwind outbound, try 1.5
minutes. With little or no wind, try 1 minute. With a moderate tailwind
outbound, try 50 seconds, and with a really honking tailwind outbound, try
40 seconds. If you're trying to get things any more accurate than that,
you're doing way too much work.
It's better to fly your first outbound leg a little bit long rather than a
little bit short. If you under-estimate how long to fly outbound, by the
time you complete your inbound turn, you can be almost on top of the NDB
and not have enough time to re-intercept the inbound bearing before you
reach station passage. When that happens, you tend to just keep getting
more and more confused and lost.
But, the real way to do NBD holds is to tear that piece of crap ADF out of
the panel and train in a GPS-equipped airplane. If your school doesn't
have GPS in their trainers, find another school.
Old October 28th 06, 03:03 PM posted to rec.aviation.ifr
Thomas Borchert
Default NDB Holds
Alan,
my notes it
Hmm. Why not 100 percent? The way I would do it is to figure out the
percentage the head/tail wind is of my IAS (TAS, if you want to get
precise). Then, I would correct 1 minute by that percentage. From your
notes, your supposed to take 75 percent of that percentage.
In reality, this takes way too much brain power away from controlling
the aircraft. Make intelligent guesses. E.g. your holding speed is 90
knots, your wind component is an estimated 10 knots, so you try a 10
seconds correction.
Thomas Borchert (EDDH)
Old October 28th 06, 04:24 PM posted to rec.aviation.ifr
Sam Spade
Default NDB Holds
Thomas Borchert wrote:
Alan,
my notes it
seconds correction.
At 90 knots it all is just b.s. to try to placate some anal instructor
or check airperson. The holding pattern protected airspace is designed
for a jet aircraft.
Old October 31st 06, 07:10 PM posted to rec.aviation.ifr
Kusi (us-ppl, sep, d.-ir)
Default NDB Holds
Alan Burke wrote:
Hi,
Just finished mine over here in Germany. We were supposed to learn it,
however our flying clubs' Pipers have 2 GNS 430, with the excellent
"pictures"...
Anyway: Here is an easy method, if you have lets say 3+ miles to go in
a 100kts airplane:
Time: Subtract/Add the Wind-speed in seconds from/to your 1 min as
follows:
Wind angle 30° full speed. Wind angle 30..60° half speed. Wind angle
60° no correction.
Example: Wind 300/20, Course 290°. Wind angle=10°, that is "full
speed" so ADD 20seconds (20kts) to your 1 min.
By the way, that works with VORs as well.
Of course, in the real world, in a small plane...who gives a f* ?
You'll stay almost always in the protected area, no matter what heading
you fly.... ;-)
Cheers,
Kusi
Academy holds memorial dedication for Navy's Blue Angels Otis Willie Naval Aviation 0 May 27th 06 04:01 AM
timing holds [email protected] Instrument Flight Rules 16 February 17th 05 12:18 AM
Holds when PT NA David Rind Instrument Flight Rules 19 April 9th 04 08:28 PM
Holds for currency requirements Paul Tomblin Instrument Flight Rules 8 March 12th 04 06:49 PM
Yokota holds memorial service for NCO Otis Willie Military Aviation 0 August 15th 03 09:22 PM
