Holds when PT NA
Old April 8th 04, 02:58 AM
David Rind
Default Holds when PT NA
If an approach has a hold in lieu of a PT, but the chart says
"No PT", is the hold optional, or is it only available with ATC
authorization the way a PT would be in this situation?
I was looking at the ILS 2 approach into EEN, and there is a
segment at 4000' from an IAF at the GDM VOR marked No PT.
The intercept altitude for the ILS is 2600', which is a fairly
quick descent along the localizer (though certainly doable).
If you wanted to take a turn around the hold to descend, do
you need ATC authorization the way you would for a PT? I can't
tell from the wording in the AIM though perhaps I'm missing the
place where it is spelled out.
David Rind
Old April 8th 04, 06:51 AM
Richard Hertz
The NoPT is for that transition only (I assume you knew that). The GS
intercept altitude is not a huge descent from 4000 in my opinion. The
distance from CAHOW to SWANZ is just over 5 miles with 1400 ft to lose - my
math shows that is 280 ft per mile. Even at 120kts that is less than 500 ft
per minute...
NoPT means NoPT; you certainly can ask to go around - but you'd better talk
to someone if you intend to do so. (on a transition that is labeled NoPT)
"David Rind" wrote in message
David Rind
Old April 8th 04, 01:20 PM
Richard Hertz
Oops - that should be just over 500 ft per minute.
"Richard Hertz" wrote in message
et...
my
ft
per minute...
talk
David Rind
Old April 8th 04, 11:54 AM
Ron Rosenfeld
On Wed, 07 Apr 2004 21:58:36 -0400, David Rind
If you are on a segment that is marked NoPT, the hold can only be executed
with permission from ATC.
It's pretty clear in AIM 5-4-8 b.3.
When a holding pattern replaces a procedure turn, the holding pattern must
be followed, *except* when RADAR VECTORING is provided or when NoPT is
shown on the approach course.
(emphasis mine).
Old April 8th 04, 01:44 PM
Andrew Sarangan
David Rind wrote in news:c52bkn$hld$1
@reader1.panix.com:
The NoPT is for the GDM transition. For the CAHOW transition (from EEN)
you will be expected to do a PT (hold in this case). This all assumes a
non radar environment.
Old April 8th 04, 03:27 PM
Ron Rosenfeld
Would it not be more accurate to say "this all assumes" you are not in a
"radar vectors to final" situation?
Old April 8th 04, 11:29 PM
Andrew Sarangan
Ron Rosenfeld wrote in message . ..
Yes, of course. I had inadvertantly assumed radar environment to mean
radar vectoring. However, I can't think of any time when ATC did not
vector me in a radar environment unless I specifically requested a
full approach.
Old April 9th 04, 01:37 AM
Andrew Sarangan
Well, ATC has certain requirements in order to give you vectors to final.
And those requirements are not always met even in a "radar environment".
For example -- my home base.
What are those requirements? Are you talking about MVA?
Old April 9th 04, 08:28 PM
David Brooks
"Andrew Sarangan" wrote in message
om...
full approach.
Well, people are coming up with exceptions, although I understand what
you're saying. Here's another: you can be close enough on the far side of an
on-field VOR that you'll be let loose to do the full VOR approach. Last time
I did that at Paine field the tower controller remarked on how quickly I had
done the PT: it was a 90-270 but I had gone far enough out not to need a
slam-dunk.
-- David Brooks
Holds for currency requirements Paul Tomblin Instrument Flight Rules 8 March 12th 04 06:49 PM
