Pinout for the 25-pin connector on my TERRA TRT-250 analog switch button transponder.
and I have the referencemanual for the King KT76 - 78 (a) if someone have questions... Tor Rene Norway Got my pin-diagram from Juan Jimenez today, THANX This is how it looks: TERRA TRT-250 TRANSPONDER *17 - A2 *5 - A1 *15 - B1 *2 - B2 *14 - B4 *18 - C4 *16 - A4 *3 - C1 *4 - C2 *9 - D4 *1 - SUPPRESSION OUT *8 and 20 - SWITCHED POWER OUT *6 - EXT. DME SUPPRESSION IN *7 and 19 - POWER IN 12 VDC *11 and 21 - POWER GROUND *12 and 24 - REMOTE GROUND Cabel lengths: RG-58A/U - max 9 ft. RG-8A/U - 17 ft. Last edited by Turaga : November 3rd 06 at 06:29 PM. |
![]() This is how it looks: TERRA TRT-250 TRANSPONDER *17 - A2 *5 - A1 *15 - B1 *2 - B2 *14 - B4 *18 - C4 *16 - A4 *3 - C1 *4 - C2 *9 - D4 *1 - SUPPRESSION OUT *8 and 20 - SWITCHED POWER OUT *6 - EXT. DME SUPPRESSION IN *7 and 19 - POWER IN 12 VDC *11 and 21 - POWER GROUND *12 and 24 - REMOTE GROUND Cabel lengths: RG-58A/U - max 9 ft. RG-8A/U - 17 ft. |
Turaga wrote:
Got my pin-diagram from Juan Jimenez today, THANX ![]() This is how it looks: TERRA TRT-250 TRANSPONDER *17 - A2 *5 - A1 *15 - B1 *2 - B2 *14 - B4 *18 - C4 *16 - A4 *3 - C1 *4 - C2 *9 - D4 *1 - SUPPRESSION OUT *8 and 20 - SWITCHED POWER OUT *6 - EXT. DME SUPPRESSION IN *7 and 19 - POWER IN 12 VDC *11 and 21 - POWER GROUND *12 and 24 - REMOTE GROUND Cabel lengths: RG-58A/U - max 9 ft. RG-8A/U - 17 ft. -- Turaga Turaga, Did you know there is an old AD on those?http://www.airweb.faa.gov/Regulatory...3?OpenDocument |
"Earls61" wrote in message oups.com... Turaga, Did you know there is an old AD on those?http://www.airweb.faa.gov/Regulatory...3?OpenDocument If you have a TRT-250 with Mod 5 or a TRT-250D with Mod 2 it has the fix required by the AD. Gerry |
"Gerry Caron" wrote in message ... "Earls61" wrote in message oups.com... Turaga, Did you know there is an old AD on those?http://www.airweb.faa.gov/Regulatory...3?OpenDocument If you have a TRT-250 with Mod 5 or a TRT-250D with Mod 2 it has the fix required by the AD. Gerry Beat me to it. ![]() And the way to check the mod is to look for the label with the serial number, the mod level is determined by looking at which number has been taken off the sticker, or marked. -- Posted via a free Usenet account from http://www.teranews.com |
Check your email, I already responded to the email you sent me.
Anyone else who wants this... http://www.bd5.com/trt250-250d_wiringdiagram.pdf It's a wide page, just tape the two together for the full drawing. The diagram is for both the 250 and the 250D. "Turaga" wrote in message ... Do anyone have it. Need the piout for the 25-pin connector on my TERRA TRT-250 analog switch button transponder. Weekend is getting close, and I was planning of put in order my transponder for regardless flying inside the controllzone this weekend... ![]() By the way, I have the referencemanual for the King KT76 - 78 (a) if someone have questions... Tor Rene Norway -- Turaga -- Posted via a free Usenet account from http://www.teranews.com |
On Fri, 3 Nov 2006 12:18:06 +0000, Turaga
wrote: Do anyone have it. Need the piout for the 25-pin connector on my TERRA TRT-250 analog switch button transponder. Weekend is getting close, and I was planning of put in order my transponder for regardless flying inside the controllzone this weekend... ![]() Here are some links you might find useful: Rob- |
"Rob Cherney" wrote in message ... On Fri, 3 Nov 2006 12:18:06 +0000, Turaga wrote: Do anyone have it. Need the piout for the 25-pin connector on my TERRA TRT-250 analog switch button transponder. Weekend is getting close, and I was planning of put in order my transponder for regardless flying inside the controllzone this weekend... ![]() Here are some links you might find useful: Rob- Nice! -- Posted via a free Usenet account from http://www.teranews.com |
On Wed, 8 Nov 2006 00:56:26 -0400, "Juan Jimenez"
wrote: Nice! Oops. Second link should have been: ftp://24.227.190.27/Publications/Ter...ble/250DMM.PDF Rob- ________________________________________ Rob Cherney Ellicott City, Maryland |
| Wanted pinout for KT78 transponder. | [email protected] | Owning | 1 | February 21st 06 05:34 AM |
| Operation without a transponder | flyer | Piloting | 11 | September 14th 04 09:48 AM |
| PINOUT NEEDED - ARC Transponder | log | General Aviation | 1 | August 31st 04 04:14 AM |
| Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 04:09 PM |
| More on transponder petition | Ian Cant | Soaring | 1 | February 27th 04 07:37 PM |
