Thin 3/8" wrench
Old November 11th 06, 01:31 AM posted to rec.aviation.homebuilt
RST Engineering
Default Thin 3/8" wrench
That's WRENCH, not wench you dirty minded garlic guzzling cigar chomping old
pharts.
I've got a very thin (0.050") 3/8" wrench that has been in my toolbox since
Eisenhower. Over the years, it has rounded its jaws off to the point where
it is fairly useless. The maker of the wrench, one H.H. Smith in Brooklyn
NY no longer makes this tool.
Other than taking an ignition wrench and grinding it down, does anybody have
a source for stamped thin metal wrenches?
Old November 11th 06, 06:03 AM posted to rec.aviation.homebuilt
Dave[_5_]
Try a bike shop. I have a couple of thin wrenches that I picked up in
conjunction with biking - though I don't recall the reason why those
particular ones were chosen (maybe they were cheap). The ones I have
are metric - inch equivalents may not be readily available. OTOH I have
often used the closest metric size on inch-size nuts (whatever I can
lay my hand on first).
Dave Johnson
Old November 11th 06, 06:15 AM posted to rec.aviation.homebuilt
clare at snyder.on.ca
Dave Johnson
You sure you are not talking about a "tappet wrench"? Made for
adjusting valves on old flat-head engines, they are quite thin.
Posted via a free Usenet account from http://www.teranews.com
Old November 12th 06, 12:02 AM posted to rec.aviation.homebuilt
Dave[_5_]
I'm sure. Some years ago I was out biking without tools, and needed to
adjust something. There happened to be a bike store nearby, and the
sheet metal wrenches were what I bought. I believe that they are made
thin to be as light as possible - intended to be carried along while
biking.
Dave Johnson
Old November 12th 06, 01:50 AM posted to rec.aviation.homebuilt
biking.
Dave Johnson
You are looking for a bike wrench - (useless as most of them are)
Old November 13th 06, 12:34 AM posted to rec.aviation.homebuilt
JKimmel
biking.
Dave Johnson
The thin wrenches used on bicycles are called "cone wrenches". They are
used to adjust wheel bearing races.
J Kimmel
www.metalinnovations.com
"Cuius testiculos habes, habeas cardia et cerebellum." - When you have
their full attention in your grip, their hearts and minds will follow.
Dave[_5_]
biking.
Dave Johnson
Old November 11th 06, 07:48 AM posted to rec.aviation.homebuilt
flybynightkarmarepair
http://www.etoolcart.com/index.asp?P...OD&ProdID=7153
Old November 16th 06, 05:24 PM posted to rec.aviation.homebuilt
Peter Dohm
old
pharts.
since
where
have
I don't know where to buy a good one; but if you do have to grind down an
ignition wrench, which is quite likely, be sure to use plenty of coolant!
Otherwise the result is a very soft wrench, which is little better than
those stamped and punched things that are sold for emergency repair of
bicycles. :-(
Peter
Old November 17th 06, 04:48 AM posted to rec.aviation.homebuilt
Cy Galley
They make some very nice thin tool steel wrenches for Bikes. And they are
NOT for emergency use. Check at your local bike shop and look at the bikes
for $5 to 10 thousand dollars.
Cy Galley - Webmaster www.qcbc.org
"Peter Dohm" wrote in message
old
pharts.
since
where
Brooklyn
have
bicycles. :-(
Peter
Flight wrench question R.H. Piloting 14 June 25th 06 04:48 PM
FAA Fat Man on thin Ice StopPoliticallyCorrectTyranny Piloting 1 August 22nd 05 03:00 AM
Wrench size for KI214 & KI201 OBS knob Roy Page Owning 7 March 11th 05 11:07 PM
Descending through a thin icing layer Wyatt Emmerich Instrument Flight Rules 70 December 31st 03 06:17 AM
Thin flexible solar panels Eric Greenwell Soaring 11 November 28th 03 05:35 PM
