Hawai Airport Piston Engine indentification question ...
Old February 19th 07, 09:28 PM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
DONOTREPLY
Default Hawai Airport Piston Engine indentification question ...
Can someone identify this radial aeroplane piston engine?
http://y23stockpic.free.fr/200608-ha...27_074431.html
As photographed on Hawaii's Oahu Airport ...
Really interesting info:
http://en.wikipedia.org/wiki/Radial_engine
Old February 19th 07, 10:15 PM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
weasel
Looks like a 9-cylinder Wright R-1820 Cyclone (G?) rather severely cut-
away.
(wouldn't bet the farm on it tho')
Wes
Old February 20th 07, 07:16 PM posted to rec.aviation.homebuilt
JP[_1_]
"weasel" wrote in
egroups.com...
away.
Wes
No, that is not a Wright Cyclone. The engine in the picture is a double
cylinder row type, but it's difficult to notice at first. Look the lower
cylinder at seven o'clock and you'll see the front cylinder row push rod
arrangement in front of the cylinder. Look the cylinder left side of it, at
8 o'clock and you'll see the push rod tubes behind the cylinder. That's the
rear cylinder row.
How about some version of Pratt & Whitney R-2800:
http://www.enginehistory.org/P&W/R-2800-32W.jpg
Just ignore the supercharger unit and look the front part of the engine.
JP
Old February 20th 07, 11:15 PM posted to rec.aviation.homebuilt
Morgans[_2_]
at 8 o'clock and you'll see the push rod tubes behind the cylinder. That's
the rear cylinder row.
I don't see it. I vote for single row.
Jim in NC
Old February 20th 07, 11:26 PM posted to rec.aviation.homebuilt
JP[_1_]
"Morgans" wrote in
That's the rear cylinder row.
Jim in NC
The black push rod cover tubes are visible in the picture. A double-row.
I happen to own a small spare part inventory for this engine type (also for
P&W R-1830 Twin Wasp). Trust me. It's the R-2800 Double Wasp.
JP
Old February 20th 07, 09:08 PM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
guy
On 19 Feb, 22:15, "weasel" wrote:
On Feb 19, 1:28 pm, "DONOTREPLY" wrote: Can someone identify this radial aeroplane piston engine?
away.
Wes
definitely looks like a 9 cylinder cylinder single row radial....
if the OP thought the radial link was interesting look at
http://en.wikipedia.org/wiki/Rotary_engine
guy
Old February 22nd 07, 05:17 AM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
Flash
Definitely a double-row unit. Just look carefully at the ignbition leads
where they come off the mainn. A pair to the front cylinder, then a pair to
the rear - - count them, and you'll go for an 18-cylinder setup (Oh yeah, I
relize we can't see ALL of them, but from top to bottom of one side - looks
abought right ?)
Flash
"guy" wrote in message
away.
Wes
guy
Old February 22nd 07, 07:08 AM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
Tim Ward[_1_]
"Flash" wrote in message
k.net...
to
I
looks
abought right ?)
Flash
away.
Wes
guy
Also, somewhere in the general vicinity is a plaque that says it is an
R2800.
Or there was in April, 2006.
Old February 22nd 07, 10:40 PM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
weasel
On Feb 19, 2:15 pm, "weasel"
away.
Wes
My bad-
Yes, it's an R-2800, Pratt&Whitney 18 cylinder radial.
(It would've been nice if the second row was visible!!)
Wes
Old February 22nd 07, 11:27 PM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
Morgans[_2_]
"weasel" wrote
My bad-
Indeed.
It looks like the view of the picture in question, with the angle given,
makes it difficult to get depth of the engine.
If it was a straight on view, the offset of a couple second row cylinders
could have been seen and made it easy to identify the engine.
If the view had been taken at a 90 degree angle from the shaft, then the
second row could have been identified from the offset of crank main throws.
It has always been my view that technical pictures should be taken with
straight views, like a 3 view drawing. It is much easier to take
measurements from a 3 view, if you are interested in taking measurements for
reproducing the object as a model, or whatever.
Jim in NC
Angles like the picture given are best left for artistic presentations, as
was probably intended.
Hawai Airport Piston Engine indentification question ... DONOTREPLY Piloting 7 February 22nd 07 11:27 PM
Learning piston engine basics [email protected] Owning 9 December 24th 05 09:19 PM
Lancair Columbia 400: The World's Fastest Certified Piston Single Engine Aircraft! David Ross Aviation Marketplace 0 August 24th 04 07:13 PM
How to ACCURATELY measure fuel/gas in a single-engine piston aircraft? NoSpam Piloting 31 January 9th 04 01:45 AM
Piston engine 101 Course? [email protected] Owning 9 October 28th 03 02:35 PM
