Hawai Airport Piston Engine indentification question ...
Old February 19th 07, 09:28 PM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
DONOTREPLY
Default Hawai Airport Piston Engine indentification question ...
Can someone identify this radial aeroplane piston engine?
http://y23stockpic.free.fr/200608-ha...27_074431.html
As photographed on Hawaii's Oahu Airport ...
Really interesting info:
http://en.wikipedia.org/wiki/Radial_engine
Old February 19th 07, 10:15 PM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
weasel
Looks like a 9-cylinder Wright R-1820 Cyclone (G?) rather severely cut-
away.
(wouldn't bet the farm on it tho')
Wes
Old February 20th 07, 09:08 PM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
guy
On 19 Feb, 22:15, "weasel" wrote:
On Feb 19, 1:28 pm, "DONOTREPLY" wrote: Can someone identify this radial aeroplane piston engine?
away.
Wes
definitely looks like a 9 cylinder cylinder single row radial....
if the OP thought the radial link was interesting look at
http://en.wikipedia.org/wiki/Rotary_engine
guy
Old February 21st 07, 01:35 AM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
Blueskies
"DONOTREPLY" wrote in message oups.com...
: http://y23stockpic.free.fr/200608-ha...27_074431.html
: As photographed on Hawaii's Oahu Airport ...
: Really interesting info:
: http://en.wikipedia.org/wiki/Radial_engine
what the heck is the deal with the rest of the pictures in that series?
Old February 22nd 07, 05:17 AM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
Flash
Definitely a double-row unit. Just look carefully at the ignbition leads
where they come off the mainn. A pair to the front cylinder, then a pair to
the rear - - count them, and you'll go for an 18-cylinder setup (Oh yeah, I
relize we can't see ALL of them, but from top to bottom of one side - looks
abought right ?)
Flash
"guy" wrote in message
away.
Wes
guy
Old February 22nd 07, 07:08 AM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
Tim Ward[_1_]
"Flash" wrote in message
k.net...
to
I
looks
abought right ?)
Flash
away.
Wes
guy
Also, somewhere in the general vicinity is a plaque that says it is an
R2800.
Or there was in April, 2006.
Old February 22nd 07, 10:40 PM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
weasel
On Feb 19, 2:15 pm, "weasel"
away.
Wes
My bad-
Yes, it's an R-2800, Pratt&Whitney 18 cylinder radial.
(It would've been nice if the second row was visible!!)
Wes
Old February 22nd 07, 11:27 PM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
Morgans[_2_]
"weasel" wrote
My bad-
Indeed.
It looks like the view of the picture in question, with the angle given,
makes it difficult to get depth of the engine.
If it was a straight on view, the offset of a couple second row cylinders
could have been seen and made it easy to identify the engine.
If the view had been taken at a 90 degree angle from the shaft, then the
second row could have been identified from the offset of crank main throws.
It has always been my view that technical pictures should be taken with
straight views, like a 3 view drawing. It is much easier to take
measurements from a 3 view, if you are interested in taking measurements for
reproducing the object as a model, or whatever.
Angles like the picture given are best left for artistic presentations, as
was probably intended.
Question: Piston Cooling and Altitude [email protected] General Aviation 1 August 5th 06 12:02 AM
Learning piston engine basics [email protected] Owning 9 December 24th 05 09:19 PM
Lancair Columbia 400: The World's Fastest Certified Piston Single Engine Aircraft! David Ross Aviation Marketplace 0 August 24th 04 07:13 PM
How to ACCURATELY measure fuel/gas in a single-engine piston aircraft? NoSpam Piloting 31 January 9th 04 01:45 AM
Piston engine 101 Course? [email protected] Owning 9 October 28th 03 02:35 PM
