Ignition switch settings
Old March 3rd 07, 04:09 PM posted to rec.aviation.piloting
Tony Cox
Default Ignition switch settings
Here's a question that until yesterday I'd have thought was
obvious.
Cessna-style (and no doubt other) ignition switches have five
settings -- Off/Right/Left/Both/Start. When you're on the "Right"
setting, does it mean you are firing on the right magneto or
does it mean the right magneto is grounded?
Old March 3rd 07, 04:34 PM posted to rec.aviation.piloting
Orval Fairbairn
In article .com,
obvious.
Right magneto is "hot" (ungrounded). The "OFF" position grounds both
mags.
Old March 3rd 07, 06:12 PM posted to rec.aviation.piloting
Tony Cox
On Mar 3, 8:34 am, Orval Fairbairn wrote:
In article .com,
obvious.
mags.
That was my understanding too, but after arguing the
point with two very experienced pilots yesterday, I
wondered how prevalent the contrary view might be.
Old March 3rd 07, 08:07 PM posted to rec.aviation.piloting
mags.
Most pilots don't understand much about aircraft systems,
and many who have automobile maintenance experience don't understand
magnetos. They make a lot of assumptions and sometimes harbour many
misconceptions. A magneto's primary winding is grounded to kill it, so
when the key is in the R position, the L magneto is grounded, and vice
versa. Even the terminals on back of the switch are labelled R and L
and when the appropriate positions are selected, the other terminal is
grounded. Can confuse someone trying to test the switch itself unless
they know what the principles are.
Another misconception: that the magneto is somehow connected
to the aircraft's electrical system. They're afraid to turn off the
master switch in flight lest it kill the engine.
Dan
Old March 3rd 07, 11:53 PM posted to rec.aviation.piloting
Peter Dohm
mags.
I know from personal experience that a lot of pilots continue to have
serious misconceptions about such things, but it still bothers me. This is
the sort of thing that is part of every run-up, and therefore should have
been part of the aircraft systems knowledge requirement to get the
license--not necessarily the grounding issue, but which magneto actually
fires its set of plugs.
Old March 4th 07, 01:11 AM posted to rec.aviation.piloting
Travis Marlatte
"Peter Dohm" wrote in message
mags.
is
I don't get the connection. Why would the licenced pilot need to know which
mag and which set of plugs is firing on Left or Right key position? Know why
the mag check is important and what to watch for during the mag check, yes.
Old March 3rd 07, 08:16 PM posted to rec.aviation.piloting
Andrew Sarangan
obvious.
Very good question. If we use the logic that "Both" means both magneto
circuits are open, and "Off" means both magneto circuits are closed,
that would imply that "Right" means the right magneto is open (and
hence firing).
But I am sure an A&P should be able to give a more authoritative
answer.
Old March 3rd 07, 11:21 PM posted to rec.aviation.piloting
Jon Woellhaf
And I've been trying to learn for years why R is on the left and L is on the
right.
Old March 4th 07, 12:49 AM posted to rec.aviation.piloting
right.
I wonder. Maybe because the ancient systems used two toggle
switches labelled "L" and "R" and they were connected to their
respective mags. When you turned off the L switch, you were running on
the R mag. It was self-evident. Our two Citabrias still have this
setup and I bet American Champion is still building them that way.
When Bendix came up with the combination starter/mag switch, the
internal mag-shorting contacts were set up in the same order but now
they had to label them opposite so that you knew which one you were
sparking on.
I'd rather have the toggles in my Jodel but it makes the
airplane so much easier to steal. If you can get in you can go.
Dan
Old March 4th 07, 01:52 AM posted to rec.aviation.piloting
Peter Dohm
right.
sparking on.
Very true. But I've known pilots who thought that might be very usefull if
they lost their key at a remote fishing hole...
Peter
(It is an amusing thought)
Nav radio settings in FMC Mxsmanic Piloting 5 January 10th 07 08:39 PM
74 Archer ignition switch question Mike Noel Owning 9 September 10th 06 10:46 PM
Ignition switch, what happen when Left or Right is selected Martin B Piloting 41 May 21st 05 04:55 AM
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 08:07 PM
Just Ordered: An Ignition Switch and Oil Filter from ACS Larry Smith Home Built 30 October 22nd 03 07:41 AM
