TBO and airworthiness
Old April 11th 07, 05:12 AM posted to rec.aviation.owning
Jim Stewart
Default TBO and airworthiness
Does an engine past TBO make an aircraft
non-airworthy? I can't seem to find a
straight answer on the web.
Old April 11th 07, 04:35 AM posted to rec.aviation.owning
There have been articles on avweb on the subject; search there for
details.
Short answer, for Part 91, no.
Jim Pennino
Remove .spam.sux to reply.
Old April 11th 07, 02:06 PM posted to rec.aviation.owning
Matt Barrow[_4_]
"Jim Stewart" wrote in message
TBO is a manufacturers recommendation, it has noting to do w ith
airworthiness. Some aircraft are not airworthy 100 hours after TBO, while
some run well past the number.
http://www.avweb.com/news/savvyaviator/187037-1.html
The Savvy Aviator #4: Debunking TBO
Engine TBO (time between overhauls) seems to be one of the most
misunderstood concepts in aviation maintenance. There are lots of
TBO-related old wives tales that are widely believed by owners and mechanic
alike, and they can cost owners a great deal of money. Mike Busch endeavors
to clear up these misconceptions, and explain what TBO really means.
Old April 11th 07, 06:39 PM posted to rec.aviation.owning
Jim Stewart
Thanks. I really appreciate the link.
Old April 11th 07, 10:38 PM posted to rec.aviation.owning
Capt. Geoffrey Thorpe
"Matt Barrow" wrote in message
So, does anyone know if TBO is based on B-10, B-50, B-90, or - what???
Geoff
Old April 12th 07, 01:00 AM posted to rec.aviation.owning
karl gruber[_1_]
What is B-10, B50 etc?
Karl
Always top post
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message
Geoff
Old April 12th 07, 01:25 AM posted to rec.aviation.owning
"karl gruber" wrote in message
Karl
Always top post
B-10, B-50... are the expected hours at which 10%, 50%, etc. are expected
to fail. The "B" is from "bearing" - the orignal theorys were developed to
predict the life of ball bearings, but the termanology is now used for
everything. The Weibull distribution is usually used to "fit" durability
data and determine these values.
If TBO is B-10, then, in most cases, it would seem silly to overhaul at TBO,
if it is B-90, then it would be optimistic to expect to make TBO...
Or, TBO could be a number that some engineer pulled out of the air (to put
it politely).
Geoff
Old April 12th 07, 02:42 PM posted to rec.aviation.owning
Matt Barrow[_4_]
Karl
Always top post
to predict the life of ball bearings, but the termanology is now used for
TBO, if it is B-90, then it would be optimistic to expect to make TBO...
it politely).
I don't think TBO is a projected or average expected "point of failure". I
believe they'd call that "Expect Life Expectancy".
Old April 17th 07, 05:05 PM posted to rec.aviation.owning
Andrew Gideon
On Wed, 11 Apr 2007 06:06:53 -0700, Matt Barrow wrote:
There are lots of
mechanic alike, and they can cost owners a great deal of money.
What's amazing is that some owners are almost religious about this. That
is, it matters not what articles you put before them counting their
beliefs. They still believe.
- Andrew
Old April 11th 07, 05:38 PM posted to rec.aviation.owning
Robert M. Gary
Assuming you can find an IA willing to sign an annual then no.
-Robert
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Restricted Airworthiness Brad Mallard Aviation Marketplace 1 May 20th 04 05:18 PM
Airworthiness Cert Still Valid? Carl Orton Owning 12 February 13th 04 10:21 PM
Teaching airworthiness Roger Long Piloting 28 October 2nd 03 09:08 PM
Airworthiness certification of an experimental Ace Pilot Home Built 0 July 16th 03 03:26 PM
