Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aviation Marketplace
Restricted Airworthiness
Old May 18th 04, 12:52 PM
Brad Mallard
Default Restricted Airworthiness
I am looking to upgrade from my Cessna 150 to a 172. I have found one I
like and not too expensive. While I was pulling up some data on the plane, I
found that it has multiple Airworthiness Certificates. One of these says
standard, and one says restricted. Does anyone now what this means?
Brad
Old May 20th 04, 05:18 PM
Juan Jimenez
"Brad Mallard" wrote in
I like and not too expensive. While I was pulling up some data on the
plane, I found that it has multiple Airworthiness Certificates. One of
these says standard, and one says restricted. Does anyone now what
this means?
Brad
Could be that at one time it was modified to do some specific task, like
airborne mapping, photography, something like that, and required mods that
would also require a restricted airworthiness certificate. Then they
removed the mods and restored the aircraft to its original configuration
and the standard airworthiness certificate would apply.
You had better have a knowledgeable person go through the logs with a fine
tooth comb to make sure they are accurate and good to go.
Juan
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Sport Pilot has left the OMB building. Juan Jimenez Home Built 15 July 20th 04 05:20 PM
CAAC in China had approved below 116kg aircraft sold in China without airworthiness cetificate Luo Zheng Home Built 0 June 27th 04 03:50 AM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
Airworthiness certification of an experimental Ace Pilot Home Built 0 July 16th 03 03:26 PM
