Tire inflation with Nitrogen or ?
Old April 11th 07, 05:59 PM posted to rec.aviation.homebuilt
Default Tire inflation with Nitrogen or ?
Michelin recomends inflating tires with nitrogen. What about Argon? I
got a bottle of argon I use in Mig welding aluminum. Isn't argon
better than Nitrogen? What about the common 75% Argon and 25% CO2
welding mixture?
Old April 11th 07, 10:01 PM posted to rec.aviation.homebuilt
Scott[_1_]
What about hydrogen? It's lighter than air and will boost lift at the
same time
Scott
welding mixture?
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Old April 11th 07, 10:47 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
same time
Scott
Little bitty molecules will leak out faster.
Old April 11th 07, 11:07 PM posted to rec.aviation.homebuilt
Dan[_2_]
Gig 601XL Builder wrote:
same time
Scott
Not as fast as helium which has a smaller molecule. For a good time
partially fill the tyre with water.
Dan, U.S. Air Force, retired
Old April 12th 07, 01:08 PM posted to rec.aviation.homebuilt
Blueskies
"Dan" wrote in message ...
: Not as fast as helium which has a smaller molecule. For a good time
: partially fill the tyre with water.
: Dan, U.S. Air Force, retired
And then let it freeze ;-)
Dan, not USAF, still working....
Old April 12th 07, 03:31 PM posted to rec.aviation.homebuilt
Dan[_2_]
Works rather well for the kick off in a football game
Old April 12th 07, 02:19 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
the same time
Scott
True but only because H runs in pairs.
Old April 12th 07, 11:44 AM posted to rec.aviation.homebuilt
Scott[_1_]
Ya, but...you can use a match to find the leak
Scott
same time
Scott
Scott
Old April 11th 07, 11:04 PM posted to rec.aviation.homebuilt
Dan[_2_]
same time
Scott
The nice thing about filing tyres with hydrogen is one can easily
find leaks with a lighted match.
Old April 12th 07, 03:54 AM posted to rec.aviation.homebuilt
Roger[_4_]
On Wed, 11 Apr 2007 21:01:12 +0000, Scott
same time
Leaks out like crazy.
Scott
welding mixture?
www.rogerhalstead.com
Filling with nitrogen scott moore Owning 21 December 8th 06 07:48 PM
Tire tread wear vs inflation pressure Ben Jackson Owning 22 October 6th 06 04:35 AM
FS: New 1-26 Tire Slick Soaring 0 April 20th 04 01:27 AM
172 Nosewheel Struts Leak Nitrogen jls Owning 4 April 9th 04 06:28 PM
Tire inflation pressure Paul Lee Home Built 80 November 19th 03 07:56 AM
