Filling with nitrogen
Old December 4th 06, 04:30 PM posted to rec.aviation.owning
scott moore
Default Filling with nitrogen
Hi,
I am considering purchase of a nitrogen fill system. I don't have power
at my tiedown, and filling the tires with a 12 volt portable compressor
is a pain due to having to park the car near the tire, move to the
other side, etc. I figgured a nice nitrogen tank system would give me
a power free solution and fill the tire with the best possible kind
of gas.
I found a fill system online:
http://www.aircraftspruce.com/catalo...trogenTire.php
My only question is why it says "no struts". That would seem to me
to be one of the best uses of this system, that I can top off my
strut, which is forever going low (on a Cessna). Is there a reason
for this restriction, and is there a system that can do struts?
Thank you.
Scott Moore
Old December 4th 06, 04:47 PM posted to rec.aviation.owning
scott moore
scott moore wrote:
Hi,
of gas.
Thank you.
Scott Moore
Another point on this, I note that the same company is selling a
hand pump for both tire and strut use:
http://www.aircraftspruce.com/pdf/20...l/Cat07578.pdf
This is completely confusing to me, why would just pumping air into
the strut be ok, but nitrogen not ok?
Scott Moore
Old December 4th 06, 04:51 PM posted to rec.aviation.owning
Gig 601XL Builder
"scott moore" wrote in message
scott moore wrote:
Hi,
of gas.
Thank you.
Scott Moore
Scott Moore
It's just a WAG but it maybe certification issues.
Old December 4th 06, 05:28 PM posted to rec.aviation.owning
Jay Masino
On your first "tank" solution, I suspect that the mentioned "pressure
reducing single stage regulator" doesn't go up to the pressures
neccessary for struts (usually atleast 150 psi).
I have a strut pump, as well as a high pressure tank that I use for my
struts. I only consider the pump as a backup. Nitrogen is best. I
think that it's a waste of time in a tire.
--- Jay
Jay Masino "Home is where My critters are"
http://www.JayMasino.com
http://www.OceanCityAirport.com
http://www.oc-Adolfos.com
Old December 4th 06, 05:42 PM posted to rec.aviation.owning
scott moore
--- Jay
May I ask, where did you get the high pressure setup for struts?
Scott Moore
Old December 4th 06, 06:59 PM posted to rec.aviation.owning
J. Severyn
Scott Moore
This works just fine for struts:
http://www.aircraft-tool.com/shop/de....aspx?PageNo=1
John Severyn
@KLVK
Old December 4th 06, 07:14 PM posted to rec.aviation.owning
Jay Masino
In my case, I sorta' "inherited" it from a airport old timer that lost
his medical and was getting out of aviation. My strut pump came from
Bogart (the same people that sell the Piper battery box mod and copper
cable mod)
--- Jay
Old December 4th 06, 09:56 PM posted to rec.aviation.owning
Capt. Geoffrey Thorpe
Hi,
of gas.
Thank you.
Scott Moore
A $40 ten gallon air tank is way more than enough for tires.
Geoff
Old December 4th 06, 11:28 PM posted to rec.aviation.owning
Fly
Expensive.
My set up costs:
Bottle of Nitrogen is about $100
A set of victor guages that the refirgeration guys use is about $110. 0-600
PSI on the low side.
$13 for the gooseneck to fit the schrader valve and $25 to have a long
hi-pressure hose made.
Keep in mind that it a takes high pressure to force the schrader's needle
valve open.
Kent Felkins
Tulsa
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message
Hi,
of gas.
Thank you.
Scott Moore
Geoff
Old December 5th 06, 02:22 AM posted to rec.aviation.owning
Steve Schneider
Geoff
Agreed. I have a 5 Gallon tank (purchased for about $20 at Kragen) which
I take home to fill using my compressor about once or twice a year. With
no power in the hangar, this little tank works great to top off the
tires. It works well enough that I haven't bothered to keep track, but
I'd guess that I can put 2-5 lbs in all three tires for some 5 to 10
occasions before I'd need to refill the tank.
Steve
Military falls on hard times in filling key jobs, report says Otis Willie Naval Aviation 1 November 26th 05 02:00 PM
Filling Holes AKperson Owning 1 July 20th 05 03:54 PM
filling Oxygen tanks Bruce McFadden Piloting 40 January 3rd 05 03:25 AM
Filling oxygen tanks Bruce McFadden Owning 49 December 28th 04 11:41 PM
172 Nosewheel Struts Leak Nitrogen jls Owning 4 April 9th 04 06:28 PM
