Hello group.
Is there a regualtion/description detailing how/where Nav/Strobe/ Position lights get mounted on the wing tip? I have Aeroflash lights and am ready to cut my fiberglass wing tip to mount them but am wondering if there are specific recommendations other than they should be seen from 360 degrees. Thanks for the help. Don.... |
![]() "DonMorrisey" wrote in message ups.com... Hello group. Is there a regualtion/description detailing how/where Nav/Strobe/ Position lights get mounted on the wing tip? I have Aeroflash lights and am ready to cut my fiberglass wing tip to mount them but am wondering if there are specific recommendations other than they should be seen from 360 degrees. I believe that the nav lights are only supposed to be seen from 180 degrees or so. At night, you should be able to determine the relative direction of an observed plane by the pattern of lights. Certainly there is a regulation somewhere, but if you just take a walk around the parking area at your local small airport, you will get the idea of where they go. Vaughn |
DonMorrisey wrote:
Hello group. Is there a regualtion/description detailing how/where Nav/Strobe/ Position lights get mounted on the wing tip? I have Aeroflash lights and am ready to cut my fiberglass wing tip to mount them but am wondering if there are specific recommendations other than they should be seen from 360 degrees. Thanks for the help. Don.... http://ernest.isa-geek.org/Delta/Exp...iment_LED.html Just a little ways down the page shows how the lights should be laid out. |
![]() "Ernest Christley" wrote in message ... DonMorrisey wrote: Hello group. Is there a regualtion/description detailing how/where Nav/Strobe/ Position lights get mounted on the wing tip? I have Aeroflash lights and am ready to cut my fiberglass wing tip to mount them but am wondering if there are specific recommendations other than they should be seen from 360 degrees. Thanks for the help. Don.... http://ernest.isa-geek.org/Delta/Exp...iment_LED.html Just a little ways down the page shows how the lights should be laid out. The actual rule on this for US registered aircraft, AFAIK, is Part 23; which is on line at: http://www.access.gpo.gov/nara/cfr/w...4cfr23_04.html The position lighting portion begins at 23.1383 Peter |
Thanks Peter and Ernest, that is exactly what I was looking for.
Don. |
Peter Dohm wrote:
"Ernest Christley" wrote in message ... DonMorrisey wrote: Hello group. Is there a regualtion/description detailing how/where Nav/Strobe/ Position lights get mounted on the wing tip? I have Aeroflash lights and am ready to cut my fiberglass wing tip to mount them but am wondering if there are specific recommendations other than they should be seen from 360 degrees. Thanks for the help. Don.... http://ernest.isa-geek.org/Delta/Exp...iment_LED.html Just a little ways down the page shows how the lights should be laid out. The actual rule on this for US registered aircraft, AFAIK, is Part 23; which is on line at: http://www.access.gpo.gov/nara/cfr/w...4cfr23_04.html The position lighting portion begins at 23.1383 Peter Those are the portions quoted on my webpage, but thanks for that link. I haven't found a reference where all the sections were seperated out into easily digestable pieces. |
DonMorrisey wrote:
Hello group. Is there a regualtion/description detailing how/where Nav/Strobe/ Position lights get mounted on the wing tip? I have Aeroflash lights and am ready to cut my fiberglass wing tip to mount them but am wondering if there are specific recommendations other than they should be seen from 360 degrees. Thanks for the help. Don.... Visibility should be 120 degrees per position. Left from nose counter clockwise to 120 degrees Right from nose clockwise to 120 degrees Rear the remaining 120. Must be visible from above and below as well. AC 43-13 or Part 23 would have the legal answer. Michelle |
Michelle P wrote:
DonMorrisey wrote: Hello group. Is there a regualtion/description detailing how/where Nav/Strobe/ Position lights get mounted on the wing tip? I have Aeroflash lights and am ready to cut my fiberglass wing tip to mount them but am wondering if there are specific recommendations other than they should be seen from 360 degrees. Thanks for the help. Don.... Visibility should be 120 degrees per position. Left from nose counter clockwise to 120 degrees Right from nose clockwise to 120 degrees Rear the remaining 120. Must be visible from above and below as well. AC 43-13 or Part 23 would have the legal answer. Michelle The side lights span 110 degrees. The rear covers 140. |
![]() "Ernest Christley" wrote in message ... Michelle P wrote: DonMorrisey wrote: Hello group. Is there a regualtion/description detailing how/where Nav/Strobe/ Position lights get mounted on the wing tip? I have Aeroflash lights and am ready to cut my fiberglass wing tip to mount them but am wondering if there are specific recommendations other than they should be seen from 360 degrees. Thanks for the help. Don.... Visibility should be 120 degrees per position. Left from nose counter clockwise to 120 degrees Right from nose clockwise to 120 degrees Rear the remaining 120. Must be visible from above and below as well. AC 43-13 or Part 23 would have the legal answer. Michelle The side lights span 110 degrees. The rear covers 140. I believe that the rear position light spans something like 180 to 190 degrees. Peter |
Peter Dohm wrote:
"Ernest Christley" wrote in message ... Michelle P wrote: DonMorrisey wrote: Hello group. Is there a regualtion/description detailing how/where Nav/Strobe/ Position lights get mounted on the wing tip? I have Aeroflash lights and am ready to cut my fiberglass wing tip to mount them but am wondering if there are specific recommendations other than they should be seen from 360 degrees. Thanks for the help. Don.... Visibility should be 120 degrees per position. Left from nose counter clockwise to 120 degrees Right from nose clockwise to 120 degrees Rear the remaining 120. Must be visible from above and below as well. AC 43-13 or Part 23 would have the legal answer. Michelle The side lights span 110 degrees. The rear covers 140. I believe that the rear position light spans something like 180 to 190 degrees. Peter Yeah, ya gotta have it span more'n 180° er ya couldn't tell which direction the observed plane was a goin'..(when it's flyin 90° to your line of sight) |
Hershey bar wing vs composite wing - how much drag? | Nathan Young | Home Built | 34 | March 29th 07 11:20 PM |
Irretating strobes noise | John Doe | Owning | 7 | December 22nd 05 01:52 PM |
High wing to low wing converts...or, visa versa? | Jack Allison | Owning | 99 | January 27th 05 11:10 AM |
Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 03:46 PM |
Strobes | Jim Kellett | Soaring | 18 | December 6th 03 12:49 PM |
