Hershey bar wing vs composite wing - how much drag?
Old March 28th 07, 03:51 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Nathan Young
Default Hershey bar wing vs composite wing - how much drag?
I have a Cherokee 180, with the short hershey bar wing. While I love
the plane, I always wish it could go a bit faster, or use a bit less
fuel to get to my destination.
I have followed the composite homebuilding movement for many years,
and am amazed at the sleekness of a composite wing. The wings on most
composites tend to be the complete opposite of a Hersey bar wing:
high aspect ratio, low thickness, no rivets, no screws for fuel
tanks,smooth curves faired into airframe, and streamlined landing gear
structure.
So my question: How much drag does a wing on a Hersey Bar Cherokee
generate, and and hypothetically speaking, how much faster could the
plane go if it was retooled with a sleek, composite wing?
Old March 28th 07, 04:07 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Dave Butler
As a former PA28-180 owner, I can certainly agree with that.
structure.
I'm no aerodynamicist, but I have a usenet-opinion. I think at Cherokee
airspeeds the effect of the screw and rivet heads is probably unmeasurable.
I'm not sure whether you're using 'composite' to mean the material from
which the wing is constructed, or the blending of different airfoil shapes.
I don't think the construction material has any effect on the
aerodynamics, but 'composite' materials may make it more economic to
manufacture complex shapes, and may reduce the weight of the resulting
structure.
If you are referring to blended airfoil shapes, look at the difference
between the fat-wing Pipers and the Archer II, Arrow II, etc.
I'm not volunteering to do the research, but I think with a little (or a
lot) of googling you can find the NACO airfoil on which the
constant-chord fat-wing Piper wing is based, and the NACO report has a
lot of detail about the characteristics of that airfoil. I've looked it
up before, but I've lost the reference.
Not news to you I'm sure, but there is more to wing airfoil choice than
minimizing drag.
Old March 28th 07, 04:36 PM posted to rec.aviation.owning,rec.aviation.homebuilt
BobR
structure.
I can't remember if it was Kitplanes or SportAviation that had a
recent article on a Piper knockoff being produced as a kitplane in
South Africa. That might be a good starting point for the difference
in performance between the different planes as well as a discussion of
the differences in design and construction. Much of the difference
has to do with better airfoil designs being used but also weight
differences.
Old March 28th 07, 04:42 PM posted to rec.aviation.owning,rec.aviation.homebuilt
cavelamb himself
At these speeds I suspect surface condition is a small part of the
overall drag.
However!
If the new wing were a couple hundred pounds lighter, then you'd
see some inprovement in speed.
It takes power to stay aloft.
The heavier the plane, the more power is required just to stay up.
Lighter is mo' betta!
Richard
Old March 28th 07, 05:21 PM posted to rec.aviation.owning,rec.aviation.homebuilt
I have helped rig many sailplanes, both composite and conventional aluminum
construction. In almost every case the metal wing are lighter then the
composite. (1-35 and HP-18 aluminum wings are lighter then ASW-20, ASW-27,
and LS-6 composite wings.)
It is much easier to build a laminar flow airfoil and complex shaped wing
to fuselage transition using composite construction. These wing have a
better lift to drag ratio. The decrease in drag aerodynamic drag of the
wing and static drag decrease associated with the wing/fuselage transition
allow faster speeds.
http://www.soaridaho.com/
"cavelamb himself" wrote in message
news
overall drag.
However!
Richard
Old March 28th 07, 05:46 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Bill Daniels
Sailplanes are the key to understanding the advantages of composite
structures. Current sailplane design is several decades ahead of composite
airplane design in this area. Sailplane performance MUST come from
aerodynamics and structures since there is no other way to get it. (You
can't cover up a bad airframe design with more power)
Composites are indeed heavier than metal but if carbon fiber is used, not
that much heavier. The real payoff is in the extremely smooth surfaces that
promote natural laminar flow. The payoff is huge across the entire speed
spectrum but highest at the low speed end where the flow is less stable and
more likely to separate if the wing surfaces are rough.
The effect of weight and drag is easy to compute. Just divide the aircraft
weight by L/D ratio to get the drag. Weight has an effect but L/D has a
bigger effect. Slick, high aspect ratio wings are the future.
Bill Daniels
"Wayne Paul" wrote in message
wing to fuselage transition using composite construction. These wing have
a better lift to drag ratio. The decrease in drag aerodynamic drag of
the wing and static drag decrease associated with the wing/fuselage
transition allow faster speeds.
news
overall drag.
However!
Richard
Old March 28th 07, 06:25 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Robert M. Gary
structure.
A fast Cherokee is also known as a Mooney C model.
-Robert
Old March 28th 07, 07:40 PM posted to rec.aviation.homebuilt
Alphonse Le Creur[_4_]
"BobR" wrote in news:1175092590.355514.234030
@y80g2000hsf.googlegroups.com:
most
gear
structure.
differences.
Well, that airplane is "inspired" by the Commanche and it's really just
comparing apples and oranges since there are so many other differences
in the two airplanes, but having said that, it's better than comparing a
cherokee to a Cozy, for instance..
In any case, the Ravin Commanche is here
http://www.saravin.com/review.htm
ALC
Old March 28th 07, 08:12 PM posted to rec.aviation.homebuilt
BobR
most
gear
structure.
differences.
In any case, the Ravin Commanche is herehttp://www.saravin.com/review.htm
ALC- Hide quoted text -
- Show quoted text -
It's about as close a comparison as can be made. I am building the
KIS Cruiser which uses a hershey bar style wing as well but the
airfoil is different. The comparison from a performance standpoint is
much faster than the Commanche for the same power (180 hp). The
difference must be attributed to several differences beyond just the
wing, weight being the most obvious.
Old March 28th 07, 08:26 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Philippe Vessaire
You may take the other side of your question.
You choose a composite plane (ie Lancair) with the same engine.
You take the 75% cruising speed of the lancair (V-lancair)
You take the Cherokee 75% cruising speed (V-cher)
If you want the same speed for your plane, you need more HP
The formula is HP=180 * (V-lancair/ V-cher)³
You may do the reverse: how many HP the lancair need for the Cherokee
speed....
You know the cost of drag....
But don't think all drag is from wing, part of drag is from fuselage and
a roomy fuselage will generate more drag.
But the comfort is in roomy fuselage
By
Volem rien foutre al païs!
Philippe Vessaire Ò¿Ó¬
Hershey bar wing vs composite wing - how much drag? Nathan Young Owning 33 March 30th 07 08:47 AM
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 12:10 PM
composite wing, wing spars Dave Schneider Home Built 4 May 21st 04 06:35 AM
Fuel Dip Tube for Hershey-bar Wing Cherokees? Bob Chilcoat Owning 3 May 3rd 04 11:29 PM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 04:46 PM
