C85 Oil Leak
Old May 1st 07, 11:03 PM posted to rec.aviation.owning
Dick[_1_]
Default C85 Oil Leak
A small oil leak has shown up topside and immediately behind the nosebowl
on my Zodiac 601 HD powered with a C85. As near as can be seen, the
crankcase nipple connection and hose leading to the air/oil separator is not
"wet" or showing leakage. Neither the hose nor air/oil separator are
blocked.
There is extensive riveted baffling around the crank/prop flange area which
blocks a direct visual inspection.
Having heard about leaking crank front oil seals, is the replacement method
a total engine case split or some kind of split ring seal similar to old
chevy small blocks?
any help would be appreciated, thanks, Dick
Old May 2nd 07, 07:40 PM posted to rec.aviation.owning
Tri-Pacer
----- blocks a direct visual inspection.
method a total engine case split or some kind of split ring seal similar
to old chevy small blocks?
There is a split seal for Continentals with flanged crankshafts which
installs without too much trouble.
A few years back I replaced a seal on a C-85 without doing enough
troubleshooting. After replacement, the leak remained. it turned out the
crankcase vent line had been moved and was pressurizing the crankcase.
Cheers:
Paul
N1431A
KPLU
Old May 2nd 07, 11:00 PM posted to rec.aviation.owning
Dick[_1_]
Paul,
Thanks for the reply. I finally found a Continental Manual showing that
split seal used on my flanged crank.
But I have noticed lately that my air/oil separator is pushing almost
nothing out the drain hose to atmosphere. ie: lot cleaner than usual belly
G. Now I wonder about that crankcase being pressurized possibility.....The
one item I didn't check for blockage was the 90 degree fitting coming out
the case side.
Sure would rather unblock something than pull that spinner, prop and
baffling G.
Dick
"Tri-Pacer" wrote in message
Cheers:
Paul
N1431A
KPLU
Oil leak on top of the engine Jay Honeck Owning 31 February 12th 05 02:27 AM
Oil leak Gene Seibel Owning 10 January 4th 05 02:57 PM
oil leak question Dick Home Built 18 November 19th 04 03:14 PM
Oil leak mike regish Piloting 9 June 22nd 04 03:46 AM
Oil Leak in TR182 Michael 182 Owning 2 August 17th 03 07:13 PM
