Would appreciate any feedback as I am considering buying
Stuart KInnear |
On May 2, 3:21 am, "Stuart Kinnear" wrote:
Would appreciate any feedback as I am considering buying Stuart KInnear for my money, if youve got an experimental glider, go for the Dynon 10A flight display. the power draw is low and you get a lot more info than just an AI. If you are looking for something certified then you got to stick with a Attitude Indicator. Lots of avionics and instrument shops sell them. www.oxaero.com is glider oriented and has TruTraks for about a thousand bucks. |
On May 2, 5:52 am, wrote:
for my money, if youve got an experimental glider, go for the Dynon 10A flight display. the power draw is low and you get a lot more info than just an AI. The spec at Dynon says 8 watts, which translates to 670 mA, which doesn't sound low to me, at least for a glider. Or is the actual draw less than the spec? Admittedly a lot less than a mechanical gyro, but not something I could run continually for any time. I tried to find the current draw of the TruTrak units, but couldn't. I think they're better, but does anyone know for sure? |
On May 2, 11:03 pm, wrote:
On May 2, 5:52 am, wrote: for my money, if youve got an experimental glider, go for the Dynon 10A flight display. the power draw is low and you get a lot more info than just an AI. The spec at Dynon says 8 watts, which translates to 670 mA, which doesn't sound low to me, at least for a glider. Or is the actual draw less than the spec? Admittedly a lot less than a mechanical gyro, but not something I could run continually for any time. I tried to find the current draw of the TruTrak units, but couldn't. I think they're better, but does anyone know for sure? I don't have the numbers but the TruTrak drain is very low. I am running my TruTrak from the same 7AH battery as my transponder and it is good for at least 6 hours. You can also add an on/off switch and turn it on only when it may be needed, as it starts instantly. Ramy |
I couldn't find the current draw of the TruTrak on line either, however I
remember when installing it that it draws just under .120 amps (120 milliamps). I have mine switched so it's only on when needed. bumper "Ramy" wrote in message ps.com... On May 2, 11:03 pm, wrote: On May 2, 5:52 am, wrote: for my money, if youve got an experimental glider, go for the Dynon 10A flight display. the power draw is low and you get a lot more info than just an AI. The spec at Dynon says 8 watts, which translates to 670 mA, which doesn't sound low to me, at least for a glider. Or is the actual draw less than the spec? Admittedly a lot less than a mechanical gyro, but not something I could run continually for any time. I tried to find the current draw of the TruTrak units, but couldn't. I think they're better, but does anyone know for sure? I don't have the numbers but the TruTrak drain is very low. I am running my TruTrak from the same 7AH battery as my transponder and it is good for at least 6 hours. You can also add an on/off switch and turn it on only when it may be needed, as it starts instantly. Ramy |
I tried one a year ago but eventually had to pull it out because it
wouldn't stay calibrated. The lightness of the glider seemed to make it too sensitive to bumps, and when I pulled out of thermals it would be off kilter. Sometimes it would do the same flying straight and level. The dealer worked with me to try all the various software settings for sensitivty and calibration to make it work but couldn't. ymmv/2NO |
I was looking at the same issue a while back and among others ran
across the MGL system: http://www.mglavionics.co.za/singles.html It looks very interesting, Craggy Aero is selling this one along with the TruTrack system (http://www.craggyaero.com/solidstate.htm). I don't have any experience with it, anyone like to comment on the MGL system? There was a similar thread a while back which you can find here (with no info on the MGL system): http://groups.google.com/group/rec.a...15eb8e7bcde380 Markus |
That's the one I tried unsuccessfully last year.
Which one?
"Tuno" wrote in message oups.com... That's the one I tried unsuccessfully last year. |
artificial horizon | DavidH | Home Built | 14 | March 14th 07 07:47 AM |
Artificial horizon pinout? | [email protected] | Home Built | 3 | July 16th 06 02:02 PM |
Artificial Horizon testing | Rory O'Conor | Soaring | 6 | April 5th 05 11:48 PM |
New artificial horizon - Sigmatek or R.C. Allen? | David Herman | Owning | 7 | November 13th 04 01:38 PM |
Artificial Horizon/Autopilot Connection | Jay Honeck | Owning | 2 | September 7th 03 05:07 PM |
