Artificial Horizon/Autopilot Connection
Old September 7th 03, 02:44 PM
Jay Honeck
Default Artificial Horizon/Autopilot Connection
So my AI has been going whacky for several months now -- falling over on its
side, then erecting, and so on.
We finally realized that, with night-flying season nearly upon us, we'd
better replace that boat anchor with an instrument we can trust. Although
we don't fly IFR, we DO occasionally fly at night, and in rural Iowa, that
can be essentially IFR. So, I asked my A&P to order the correct one for me,
cuz I couldn't see a model number or any identifying marks on the face.
Well, it turns out my autopilot is connected to the back of this instrument
with a multi-prong plug, necessitating (of course!) the more expensive AI.
This also explains (I hope) why my autopilot has been acting erratic, so I'm
looking forward to fixing two problems with one purchase. (Ha! Wake up,
Jay!)
We ended up ordering a rebuilt unit from the Gyro House, in northern
California. You pay $1100, and they credit you $600 when they receive your
old one back in the mail. Even though I told them there was no rush, the
instrument arrived within two days -- before my shop was even ready to
install it. It was shipped in a gigantic box, with two huge pieces of foam
holding the instrument in the middle of a marshmallow-like suspension. So
far, I'm very impressed with their helpful attitude on the phone, and their
quick service. I hope it will be installed Monday or Tuesday.
Question: Does anyone know why the old autopilots were hooked up to a vacuum
instrument? This seems like the height of folly, since a vacuum pump
failure takes down EVERYTHING, as opposed to the newer units that work off
the electric turn & bank.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old September 7th 03, 02:57 PM
Dan Luke
to a vacuum instrument? This seems like the height of folly, since
a
vacuum pump failure takes down EVERYTHING, as opposed to
the newer units that work off the electric turn & bank.
Autopilots come in two species: rate-based and attitude-based. Yours
is attitude-based, as are many modern autopilots, especially the high
end ones. Rate-based autopilots like my S-Tec 50 tend to be simpler
and cheaper. The fact that they continue to work after a vacuum
failure is a happy coincidence of the fact that turn coordinators are
electric.
Dan
C172RG at BFM
Old September 7th 03, 05:07 PM
garyPQ
Sure Jay, he attitude gyro tells the autopilot which way is "up." It is used
for pitch AND roll control in a position-based system, like Century (nee
Mitchell or Edo-Aire) and King.
For instance, in roll, the autopilot will use the gyro angle to cancel the
heading error. For instance, if you are 10 degrees off the selected heading,
the autopilot will roll in 10 degrees of bank until the heading select error
starts to decrease. On heading, the bank angle becomes zero.
As you said, the vacuum is one of the least reliable systems, but electric
gyros are very expensive, while vacuum powered ones are simpler, and more
robust. And attitude information was required in these systems.
S-tec avoided the attitude gyro necessity, by using RATE based systems and
pressure transducers.
--Gary
"Jay Honeck" wrote in message
news:4DG6b.381210$Ho3.57121@sccrnsc03...
its
Although
me,
instrument
I'm
Jay!)
your
foam
their
vacuum
Jay Honeck
Iowa City, IA
Pathfinder N56993
ISRAELI TORTURE CONNECTION: WHO IS JOHN ISRAEL? MORRIS434 Military Aviation 0 May 12th 04 09:16 PM
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ----- hithUOFT8mSo Aardvark G. Bandersnatch, CPE, RCA, IBM, LSMFT Naval Aviation 4 April 3rd 04 03:17 AM
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ----- hithUOFT8mSo Aardvark G. Bandersnatch, CPE, RCA, IBM, LSMFT General Aviation 4 April 3rd 04 03:17 AM
Headset with mobilephone connection Mads Home Built 2 January 8th 04 06:51 AM
PC connection for GPS 90 wanted Jim Weir Owning 4 September 2nd 03 10:01 PM
