Broken main spar repai
Old June 1st 07, 02:33 PM posted to rec.aviation.soaring
Default Broken main spar repai
Does anybody has ever seen a fiberglass glider which was repaired
after a complete main spar damage at around 2m from the root-rib ?
Any emample, is it possible, how , how expensive ?
Old June 1st 07, 03:49 PM posted to rec.aviation.soaring
Bill Daniels
Almost any repair is posible in fiberglass. Spar repairs are not too
difficult. Get an estimate from a reliable shop.
I once saw a Diamont repaired after it was delivered to the shop in
wheelbarrows - no piece was bigger than 2 meters. So, yeah, it can be done.
I doubt that it was economical though. It was more a labor of love.
Bill Daniels
Old June 2nd 07, 01:39 PM posted to rec.aviation.soaring
JJ Sinclair
I have repaired a couple of broken spars (severed), but they were near
the tip, like 60" in. The only authorization I have ever seen was in a
Schleicher Repair manual which stated; 100:1 scarf angle at the tip
and 400:1 at the root. On a 15 meter bird with a 1/2 deep spar cap,
thats 200" or 16.6 feet (2/3 semi-span)! Of course the skin must be
removed to expose the spar cap. The other wing can be used to set the
jig and your work can be tested by sand bagging it to 5.3 G's. Is it
economically viable? NO!
JJ
aluminum rib, aluminum spar, holes drilled but screws broken off jls Home Built 13 January 3rd 07 08:06 AM
Seeking US Source for Main Wheel Tubes Chris OCallaghan Soaring 7 August 28th 04 03:46 PM
The main difference between Europe and USA noname Military Aviation 0 May 31st 04 03:23 AM
Bell 427 Main Rotor System Bob M Rotorcraft 7 March 19th 04 01:35 AM
Gazelle main rotor hub Goku Rotorcraft 3 March 13th 04 11:08 AM
