Flight download
Old June 19th 07, 02:07 AM posted to rec.aviation.soaring
Steve Freeman
Default Flight download
Recently purchased a glider with an LNAV/GPSNAV Model 20 system. Does
anyone know of a simple and easy way to download the flight data
after a flight. I was hoping there might be something on the market
that would let you use a flash card or SD card etc. without having to
drag the laptop out to the field each time I fly. Any suggestions?
Old June 19th 07, 02:41 AM posted to rec.aviation.soaring
Marc Ramsey[_2_]
Any of the older iPaqs will do the job using a Cambridge-supplied
utility, I'm partial to the 38xx models, myself (if you get one of the
earlier models, make sure you get a flash card sleeve with it). You can
get them for around $100 on eBay. Get a mount, cable, 12V to 5V
converter, plus one of the free glide/navigation programs (GPS_LOG or
XCSoar), and you'll have a 21st Century cockpit for about $250 total 8^)
Marc
Old June 19th 07, 03:42 AM posted to rec.aviation.soaring
Steve Freeman
Marc
I realize that is a workaround option but I am looking for a solution
using the in cockpit equipment I currently have. I am happy with the
info while flying just looking for an easier way to get the data out
at the end of the day.
Old June 19th 07, 03:55 AM posted to rec.aviation.soaring
Marc Ramsey[_2_]
The GPS-NAV uses a proprietary serial protocol for download, so you're
stuck with using a laptop, desktop, or PDA running suitable software...
Marc
Old June 19th 07, 04:52 AM posted to rec.aviation.soaring
David Kinsell
Marc
Is it easy to remove the recorder? I unscrew one thumbscrew, disconnect
a couple of cables, and take the thing home at the end of the day to
download there. Just takes a 12-14 volt supply or battery.
-Dave
Old June 19th 07, 12:49 PM posted to rec.aviation.soaring
My glider also has the GPS-NAV 20. Works well. At first, I used to
take it home at the end of each flight. That was not a big deal. The
unit is attached with velcro.
Later, I bought an iPAQ. Now, I download to the iPAQ, and then take
the iPAQ home.
Either way, you'll be taking something home.
Raul Boerner
LS6B - DM
Old June 19th 07, 02:30 PM posted to rec.aviation.soaring
Steve Freeman
A PDA sounds like a reasonable solution. Do you know if a Palm will
work. I have gone through all of the Cambridge Aero pages on their
website and cannot find any links to software to use to download the
data. Any suggestions?
AA77 9/11 Pentagon - Flight Data DOWNLOAD link [email protected] Naval Aviation 0 June 5th 07 08:10 AM
Using a Pocket PC to download Themi flight logs Paul Remde Soaring 5 September 14th 04 07:29 AM
Download Thijs Wolters Simulators 26 June 24th 04 03:36 PM
Lazair in flight movies to download web Home Built 0 March 11th 04 02:36 AM
Cambridge 302 problem: "Could not get FAT.(A)" while trying to download flight logs Jason Armistead Soaring 5 July 13th 03 02:36 PM
