here's the configuration:
SL30 talking to a TKM MC60 VOR/GS indicator. On the SL30, the left-right indicator displays correctly when in cruise and it detects a VOR. On the MC60, the left-right displays correctly when in cruise and it detects a VOR. On the MC60, the glideslope indicator displays correctly when on approach. But...on approach, there's no left-right indicator on the MC60. Bench testing and in-aircraft testing by a Garmin shop shows no problems with either radio or VOR/GS indicator. But I still don't have the left-right on the MC60 when on approach. Anyone got any suggestions? |
Looking at the SL30 manual, doesn't seem to be any difference
in the needle signal for the LOC versus VOR. There is a line that comes high when you are tuned to LOC (it's variously used to kick autopilots into APR mode or to toggle the GPS / COM annunciator). You don't have a GPS in there do you? |
On 06 Jul 2007 05:09:39 GMT, Blanche wrote:
Ron Rosenfeld wrote: On 06 Jul 2007 02:09:09 GMT, (blanche cohen) wrote: here's the configuration: SL30 talking to a TKM MC60 VOR/GS indicator. On the SL30, the left-right indicator displays correctly when in cruise and it detects a VOR. On the MC60, the left-right displays correctly when in cruise and it detects a VOR. On the MC60, the glideslope indicator displays correctly when on approach. But...on approach, there's no left-right indicator on the MC60. Bench testing and in-aircraft testing by a Garmin shop shows no problems with either radio or VOR/GS indicator. But I still don't have the left-right on the MC60 when on approach. Anyone got any suggestions? Some problem with the interface/connection/wiring between the two? Are they designed to work together? Have they ever worked together? According to TKM (and unofficially, Garmin/Apollo tech) there should be no problems. Since the GS works, and the L/R works when cruising, it seems that they do play well together. I think it's a trip to a different Garmin shop to have them follow/check the wiring. This one didn't want to do that. In fact, the comment was "I don't know what else to do. It may just be an intermittent wiring problem". Which sealed the fate of that shop. They don't want to deal with "small change" customer (like me) when they have twins that want 530s, entire entertainment centers, etc. Fine. My checkbook will go someplace else. Well, since they are designed to work together, and both units do so, then clearly the problem has to be in how they are hooked up, as I wrote. Reminds me of another story -- I had an intermittent problem with the CDI on my HSI. There was a "converter" between my KX155 and my HSI (NSD360). IT was mounted in a very difficult to get at spot so was, of course, the last thing checked. PRoblem turned out to be bad solder joints inside the converter -- in other words, it came that way from the factory. Unfortunately, by the time we diagnosed this, it was years out of warranty. But the fix was simple. --ron |
| C172N Flap indicator problem | onesto | Owning | 0 | July 2nd 06 11:47 AM |
| Seems a little strange- | Capt.Doug | Piloting | 20 | January 30th 05 03:30 AM |
| Strange one about the 296 | kage | Piloting | 0 | June 13th 04 02:42 AM |
| Strange one??? | Big John | Piloting | 15 | March 4th 04 01:25 AM |
| Does anyone think it's strange... | Badwater Bill | Home Built | 24 | August 7th 03 04:44 PM |
