Back in January, I posted my concern about the oil in my 172RG (Lyc. O-360)
turning black just two or three hours after being changed. My regular mechanic said no to worry, the crud probably came from oil that didn't get drained from the oil cooler and associated plumbing. Still concerned, I took the bird to Teledyne Continental's shop across the Bay in Fairhope for an evaluation of the engine. They reported that compressions were good, crankcase pressure was ok and borescope examinations revealed nothing unusual in the cylinders. Relieved, I concluded that my mechanic was probably right. I resolved not to worry about it. Now I've got another airplane with an engine (Lyc. TIO-540) that is very similar, at least in its cylinders and bottom end. I had the oil and filter changed as soon as I got it because the oil was black. 15 hours later, the oil is just barely showing enough contamination to make the dipstick easy to read. So now I'm wondering: what was really going on in the first airplane's engine? What could have been getting the oil dirty so quickly yet not show up in the TC shop's examination? -- Dan T-182T at BFM |
From Sac Sky Ranch:
1. Blowby of combustion gases past the piston ring belt. Accompanied by high oil temperature and increased oil flow out engine breather. Check engine compression. 2. Excessive oil temperatures. (any carbon deposits in the screen or filter?) 3. Contamination of oil. Jim "Dan Luke" wrote in message ... Back in January, I posted my concern about the oil in my 172RG (Lyc. O-360) turning black just two or three hours after being changed. My regular mechanic said no to worry, the crud probably came from oil that didn't get drained from the oil cooler and associated plumbing. Still concerned, I took the bird to Teledyne Continental's shop across the Bay in Fairhope for an evaluation of the engine. They reported that compressions were good, crankcase pressure was ok and borescope examinations revealed nothing unusual in the cylinders. Relieved, I concluded that my mechanic was probably right. I resolved not to worry about it. Now I've got another airplane with an engine (Lyc. TIO-540) that is very similar, at least in its cylinders and bottom end. I had the oil and filter changed as soon as I got it because the oil was black. 15 hours later, the oil is just barely showing enough contamination to make the dipstick easy to read. So now I'm wondering: what was really going on in the first airplane's engine? What could have been getting the oil dirty so quickly yet not show up in the TC shop's examination? -- Dan T-182T at BFM |
"Jim Burns" wrote: From Sac Sky Ranch: 1. Blowby of combustion gases past the piston ring belt. Accompanied by high oil temperature and increased oil flow out engine breather. Check engine compression. Borescopes and compressions were ok, but I still think it was something like this that was going undetected. But what? oil temperatures. (any carbon deposits in the screen or filter?) Oil temp. was monitored on the JPI engine analyzer with a high alarm setting of 215 deg. F. Never had an alarm. 3. Contamination of oil. That's what my regular mechanic said. -- Dan T-182T at BFM |
As an aside IO540... our Aztec engines run hot. With the Piper oil temp
probe located just after the cooler and the JPI probe located ahead of the #1 cylinder, the Piper oil temp rarely hit 200 but the JPI's will show 230 and if we climb out too steeply they'll bust the 235 alarm. I changed the oil and filters in ours last night and noted about 1/2 dozen carbon particles in the sump screens of each engine with a few small chunks in the filters. 66 hours on filter changes. Oil had 33 hours on it and was brown, definitely not black. Jim "Dan Luke" wrote in message ... "Jim Burns" wrote: From Sac Sky Ranch: 1. Blowby of combustion gases past the piston ring belt. Accompanied by high oil temperature and increased oil flow out engine breather. Check engine compression. Borescopes and compressions were ok, but I still think it was something like this that was going undetected. But what? oil temperatures. (any carbon deposits in the screen or filter?) Oil temp. was monitored on the JPI engine analyzer with a high alarm setting of 215 deg. F. Never had an alarm. 3. Contamination of oil. That's what my regular mechanic said. -- Dan T-182T at BFM |
On Jul 13, 9:11 am, "Jim Burns" wrote:
As an aside IO540... our Aztec engines run hot. With the Piper oil temp probe located just after the cooler and the JPI probe located ahead of the #1 cylinder, the Piper oil temp rarely hit 200 but the JPI's will show 230 and if we climb out too steeply they'll bust the 235 alarm. I changed the oil and filters in ours last night and noted about 1/2 dozen carbon particles in the sump screens of each engine with a few small chunks in the filters. 66 hours on filter changes. Oil had 33 hours on it and was brown, definitely not black. Jim "Dan Luke" wrote in message ... "Jim Burns" wrote: From Sac Sky Ranch: 1. Blowby of combustion gases past the piston ring belt. Accompanied by high oil temperature and increased oil flow out engine breather. Check engine compression. Borescopes and compressions were ok, but I still think it was something like this that was going undetected. But what? oil temperatures. (any carbon deposits in the screen or filter?) Oil temp. was monitored on the JPI engine analyzer with a high alarm setting of 215 deg. F. Never had an alarm. 3. Contamination of oil. That's what my regular mechanic said. -- Dan T-182T at BFM- Hide quoted text - - Show quoted text - I have never understood why the manufacturer would plumb the oil temp sender after the cooler, it gives a false reading. If the cooler was very efficient it could shed 50+ degrees. So lets say the after cooler temp was 220 degrees after a long climb out during hot weather, that would mean the actual oil temp in the pan of the motor was 270+. Funny the FAA lets the certified planes get away with it plumbed that way. |
"Dan Luke" wrote in message ... "Jim Burns" wrote: From Sac Sky Ranch: 1. Blowby of combustion gases past the piston ring belt. Accompanied by high oil temperature and increased oil flow out engine breather. Check engine compression. Borescopes and compressions were ok, but I still think it was something like this that was going undetected. But what? oil temperatures. (any carbon deposits in the screen or filter?) Oil temp. was monitored on the JPI engine analyzer with a high alarm setting of 215 deg. F. Never had an alarm. 3. Contamination of oil. That's what my regular mechanic said. -- Dan T-182T at BFM Lets see 2 or 3 Compression Rings? is the Oilier (2 Scrapers And An Expander) above or below the wrist pin? If it is above the wristpin depending on piston design the 2nd or 3rd lower compression ring land is probably slightly bent or tollerances to tight and binding the oilier witch will not show on a leak down test but will cause lots of blow-by and or heat when operating at a higher rpm. many other things are possible. |
On Jul 13, 7:39 am, "Dan Luke" wrote:
"Jim Burns" wrote: From Sac Sky Ranch: 1. Blowby of combustion gases past the piston ring belt. Accompanied by high oil temperature and increased oil flow out engine breather. Check engine compression. Borescopes and compressions were ok, but I still think it was something like this that was going undetected. But what? Did you get any compression numbers from the shop? I've found that what TCM considers to be "OK" compressions, wouldn't necessarily be considered OK by a lot of mechanics. A friend had a cylinder in the 50s a couple of years after a TCM factory overhaul and they considered it "OK". John Galban=====N4BQ (PA28-180) |
"John Galban" wrote: Borescopes and compressions were ok, but I still think it was something like this that was going undetected. But what? Did you get any compression numbers from the shop? I've found that what TCM considers to be "OK" compressions, wouldn't necessarily be considered OK by a lot of mechanics. A friend had a cylinder in the 50s a couple of years after a TCM factory overhaul and they considered it "OK". Compressions were all in the 74-78 range, about the same as at annual a few months before. -- Dan T-182T at BFM |
| Thread Tools | |
| Display Modes | |
| dirty oil | Dan Luke | Owning | 46 | March 15th 07 03:25 PM |
| Dirty Laundry | [email protected] | Piloting | 6 | October 18th 06 11:36 PM |
| dirty bird | The Weiss Family | Owning | 9 | November 9th 04 06:14 PM |
| "Dirty Tricks" and "Both Sides Do It" | Leslie Swartz | Military Aviation | 19 | March 29th 04 07:11 PM |
| Vic Tatelman's Pictures of "Dirty Dora", "Dirty Dora II" and the Surrender Mission | Adam Lewis | Military Aviation | 0 | February 3rd 04 04:39 PM |
