dirty oil
Old January 28th 07, 03:02 PM posted to rec.aviation.owning
Dan Luke
Default dirty oil
The oil in my Lyc. O-360 F1A6 is black only two hours after being changed.
What could be causing this? Compressions were in the 70s at annual in
September.
Dan
C172RG at BFM
Old January 28th 07, 04:09 PM posted to rec.aviation.owning
Mike Noel
Default dirty oil
Sounds like some serious blow-by into the crankcase. If you don't have an
oil separator on the breather, I would expect also to see a very dirty
belly. How about having a mechanic re-check the compression and look at
the inside of the cylinders?
Best Regards,
http://photoshow.comcast.net/mikenoel
I'm a uniter, not a divider. - GWB, 1999.
"Dan Luke" wrote in message
September.
Dan
C172RG at BFM
Old January 28th 07, 11:44 PM posted to rec.aviation.owning
Rip
Default dirty oil
September.
Have you changed the TYPE of oil, by any chance? Going from a mineral
based AD oil (like Phillips XC) to a semisynthetic (like Exxon Elite or
Aeroshell), can flush out deposits that have been accumulating for a
long, long time. If so, things will improve with further oil changes,
but you may want to change the oil and filter again soon.
Rip
Old January 29th 07, 10:04 AM posted to rec.aviation.owning
Default dirty oil
That is true when going from a non detergent oil to a detergent oil.
Phillips XC is an ashless dispersant oil, as are most aviation oils.
Only the straight mineral oil (ie. break-in oil) is not an AD oil. I
don't think avaition oils are considered detergent oils. Marvel
Mystery Oil is effectively a detergent oil and can loosen deposits
that have built up. Word is MMO works if you use it from the start of
an overhaul run to keep valves from sticking. If you put it in an
engine with 1000 hrs on it, you risk the danger of loosening the
deposits that have built up, and possibly blocking small oil
passsages.
Bud
September.Have you changed the TYPE of oil, by any chance? Going from a mineral
Rip
Old January 29th 07, 12:20 PM posted to rec.aviation.owning
Dan Luke
Default dirty oil
Nope. Aeroshell W100 Plus, same as always.
Dan
C172RG at BFM
Old January 29th 07, 10:33 AM posted to rec.aviation.owning
Default dirty oil
Definitely have an A&P borescope that engine. Broken ring maybe. Good
catch.
Regards,
Bud
September.
Dan
C172RG at BFM
Old January 29th 07, 07:49 PM posted to rec.aviation.owning
Dan Luke
Default dirty oil
Talked to my mechanic this morning. He said not to worry; the dirty oil is
from the oil cooler and its plumbing, which don't get drained when the oil is
changed.
He said I would have noticed this before if I had ever checked it two hours
after a change. Since I check the oil before every flight, it seems I would
have noticed the oil's turning black this soon before.
Should I pay to have the cylinders 'scoped?
Dan
C-172RG at BFM
Old January 29th 07, 07:53 PM posted to rec.aviation.owning
Nathan Young
Default dirty oil
On Mon, 29 Jan 2007 13:49:26 -0600, "Dan Luke"
changed.
Your mechanic's comment sounds unrealistic. I have a hard time
believing the 1/2 quart in the cooler & lines could add enough
coloration to the 7-8 quarts of new/clean oil.
Further, I don't notice my oil turning black until many hours after
the change. (Lyc O-360 using Aeroshell 15W50), and I never flush the
cooler during a change.
Is your oil a dark black? Or just a tinge of coloration?
Old January 29th 07, 10:16 PM posted to rec.aviation.owning
Ross
Default dirty oil
changed.
I have a Lyc O-360 on my Cessna and there is a oil cooler. I have never
had dirty oil after only a couple of hours of operation. I would keep
looking.
Regards, Ross
C-172F 180HP
KSWI
Old January 30th 07, 02:22 AM posted to rec.aviation.owning
A Lieberma
Default dirty oil
Nathan Young wrote in
For what it's worth.....
I have never had oil discolored significantly before 5 hours running time.
Right around 10 hours does the oil start to look like used oil in my
Lycoming AK4 360 engine.
Allen
Dirty Laundry [email protected] Piloting 6 October 18th 06 10:36 PM
"Dirty Tricks" and "Both Sides Do It" Leslie Swartz Military Aviation 19 March 29th 04 06:11 PM
