Does anyone know of a FAR that prohibits removing fuel, avgas in this
case, and then putting it back into the same plane? The plane is flown for part 91 service only. Examples: 1.) The plane is 50 pounds overweight for conditions. 10 gallons is siphoned out into a clean, single-purpose, approved for gasoline container. The sealed container is stored in a safe place. 2-3 hours later, upon completing the trip and returning to the field, I pour it back into the tank. 2.) I want to calibrate a fuel dipstick, so I remove a gallon at a time while taking readings. After I read the tank, I return the fuel to the tank. I've been told this is a violation. The person who tells me this can't cite a FAR, and I can't find one in my own search. |
B A R R Y wrote:
Does anyone know of a FAR that prohibits removing fuel, avgas in this case, and then putting it back into the same plane? The plane is flown for part 91 service only. Examples: 1.) The plane is 50 pounds overweight for conditions. 10 gallons is siphoned out into a clean, single-purpose, approved for gasoline container. The sealed container is stored in a safe place. 2-3 hours later, upon completing the trip and returning to the field, I pour it back into the tank. 2.) I want to calibrate a fuel dipstick, so I remove a gallon at a time while taking readings. After I read the tank, I return the fuel to the tank. I've been told this is a violation. The person who tells me this can't cite a FAR, and I can't find one in my own search. I can't think of ant FAR that could even remotely make what you are wanting to do a violation. |
On Mon, 23 Jul 2007 13:33:28 -0400, B A R R Y
wrote: Does anyone know of a FAR that prohibits removing fuel, avgas in this case, and then putting it back into the same plane? The plane is flown for part 91 service only. Examples: 1.) The plane is 50 pounds overweight for conditions. 10 gallons is siphoned out into a clean, single-purpose, approved for gasoline container. The sealed container is stored in a safe place. 2-3 hours later, upon completing the trip and returning to the field, I pour it back into the tank. 2.) I want to calibrate a fuel dipstick, so I remove a gallon at a time while taking readings. After I read the tank, I return the fuel to the tank. I've been told this is a violation. The person who tells me this can't cite a FAR, and I can't find one in my own search. First Reaction: If it's okay to use a GATT jar, what would the cutoff be? Two ounces? A cup? 49 gallons? Second Reaction: A violation of the National Fire Code will get you thrown off the airport faster than a FAR violation will. The question about where the cutoff is can probably be found in the NFC. Third Reaction: If you're gonna do it anyway, common sense says don't release a lot of gasoline fumes in an enclosed place and if you don't KNOW that the transfer equipment is safe from a static electricity standpoint, DON'T do it. There are faster, less painful ways to die. Don |
Don Tuite wrote:
Second Reaction: A violation of the National Fire Code will get you thrown off the airport faster than a FAR violation will. The question about where the cutoff is can probably be found in the NFC. How much fuel is in your riding mower and other power equipment? Or the car(s) in your garage? Did I say store it on the airport? How many 5 gallon gas cans are on a typical landscaping or race car trailer? Third Reaction: If you're gonna do it anyway, common sense says don't release a lot of gasoline fumes in an enclosed place and if you don't KNOW that the transfer equipment is safe from a static electricity standpoint, DON'T do it. There are faster, less painful ways to die. Thanks. I didn't ask for knee-jerk, flame-war (pun intended) inducing, chicken little reactions. If someone can cite a part 43, 91, etc... rule that says fuel removed from an aircraft with safe and legal defueling methods can't be returned to the same tank, I'd be very much obliged! ;^) |
The FAA does not get into fueling/defueling. At all.
B A R R Y wrote: Don Tuite wrote: Second Reaction: A violation of the National Fire Code will get you thrown off the airport faster than a FAR violation will. The question about where the cutoff is can probably be found in the NFC. How much fuel is in your riding mower and other power equipment? Or the car(s) in your garage? Did I say store it on the airport? How many 5 gallon gas cans are on a typical landscaping or race car trailer? Third Reaction: If you're gonna do it anyway, common sense says don't release a lot of gasoline fumes in an enclosed place and if you don't KNOW that the transfer equipment is safe from a static electricity standpoint, DON'T do it. There are faster, less painful ways to die. Thanks. I didn't ask for knee-jerk, flame-war (pun intended) inducing, chicken little reactions. If someone can cite a part 43, 91, etc... rule that says fuel removed from an aircraft with safe and legal defueling methods can't be returned to the same tank, I'd be very much obliged! ;^) |
On Jul 23, 12:33 pm, B A R R Y wrote:
I've been told this is a violation. The person who tells me this can't cite a FAR, and I can't find one in my own search. The world is full of 'experts' who will tell you that something is against the FAR's. When pressed, they will tell you to call the FSDO if you don't believe them. Those experts can't ever seem to quote the relevant FAR. They are best ignored. There is no such regulation in the Part 91 world. Michael |
Michael wrote:
On Jul 23, 12:33 pm, B A R R Y wrote: I've been told this is a violation. The person who tells me this can't cite a FAR, and I can't find one in my own search. The world is full of 'experts' who will tell you that something is against the FAR's. When pressed, they will tell you to call the FSDO if you don't believe them. Those experts can't ever seem to quote the relevant FAR. They are best ignored. There is no such regulation in the Part 91 world. Thanks! I've been searching 91 and 43, both electronically and on paper, but my 43 experience is limited. The problem in this case, is that the "expert" is related to an airport manager. |
B A R R Y wrote:
Michael wrote: On Jul 23, 12:33 pm, B A R R Y wrote: I've been told this is a violation. The person who tells me this can't cite a FAR, and I can't find one in my own search. The world is full of 'experts' who will tell you that something is against the FAR's. When pressed, they will tell you to call the FSDO if you don't believe them. Those experts can't ever seem to quote the relevant FAR. They are best ignored. There is no such regulation in the Part 91 world. Thanks! I've been searching 91 and 43, both electronically and on paper, but my 43 experience is limited. The problem in this case, is that the "expert" is related to an airport manager. So what. If it is against FAA rules tell the manager that if he would kindly show you the rule you will be more than happy not to do it. If it is aganist an airport rule then he and you should do the same. |
Gig 601XL Builder wrote:
So what. If it is against FAA rules tell the manager that if he would kindly show you the rule you will be more than happy not to do it. If it is aganist an airport rule then he and you should do the same. That's the plan! If there is a FAR against returning the removed fuel to the aircraft, I'd gladly respect it, without having to be told. Since my own research turned up nothing, I pick the vast expertise of knowledge here. G I like to have my ducks in a row without causing a rub. The manager who works for the state agency that owns the airport doesn't have single problem with any of this. The "expert" is a self-employed mechanic, related to the manager of the FBO who runs the field, and I'd prefer to continue the good relationship I have with both of them. Airport rules prohibit storing fuel cans in hangars, so I wouldn't do that. There is no airport rule against gas cans in or on vehicles, or fuel transfer tanks, ala Jay's "Grape". Several local pilots are various sorts of contractors (landscape, tree surgeon, builders, heavy equipment repair...) and have had many gas and diesel cans in the parking lot, on business trucks and trailers. Thanks! |
On Jul 23, 12:46 pm, Michael
wrote: On Jul 23, 12:33 pm, B A R R Y wrote: I've been told this is a violation. The person who tells me this can't cite a FAR, and I can't find one in my own search. The world is full of 'experts' who will tell you that something is against the FAR's. When pressed, they will tell you to call the FSDO if you don't believe them. Those experts can't ever seem to quote the relevant FAR. They are best ignored. There is no such regulation in the Part 91 world. Michael I have to agree with Michael, there are a lot of experts who know rules that don't exist. FSDO's aren't the experts and are often the source of such myths. Locally we have had a FSDO inspector tell us we could not carry passengers while towing gliders. He reversed this after I inquired to he and is boss as to where this rule came from. Recently another FSDO inspector told a local 141 flight school that all the gas caps on their aircraft needed to be painted Red. I am still trying to figure out which hat or book he might have pulled that rule out of. Maybe someone here knows? Brian CFIIG/ASEL |
Temporarily removing fuel and replacing it into the same aircraft | B A R R Y[_2_] | Piloting | 39 | August 2nd 07 04:30 AM |
Removing 100LL Fuel Stain | Jeff | Home Built | 7 | September 20th 05 08:45 PM |
FOLO: Replacing fuel cut-off valve with non-a/c part??? | Michael Horowitz | Owning | 10 | February 23rd 05 04:35 AM |
Fuel quality control standards for aircraft rental/fuel sales... | [email protected] | Owning | 19 | January 19th 05 04:12 AM |
Replacing fuel cut-off valve with non-a/c part??? | Michael Horowitz | Owning | 46 | January 15th 05 10:20 PM |
