Temporarily removing fuel and replacing it into the same aircraft
Old July 23rd 07, 07:33 PM posted to rec.aviation.piloting,rec.aviation.owning
B A R R Y[_2_]
Default Temporarily removing fuel and replacing it into the same aircraft
Does anyone know of a FAR that prohibits removing fuel, avgas in this
case, and then putting it back into the same plane? The plane is flown
for part 91 service only.
Examples:
1.) The plane is 50 pounds overweight for conditions. 10 gallons is
siphoned out into a clean, single-purpose, approved for gasoline
container. The sealed container is stored in a safe place. 2-3 hours
later, upon completing the trip and returning to the field, I pour it
back into the tank.
2.) I want to calibrate a fuel dipstick, so I remove a gallon at a time
while taking readings. After I read the tank, I return the fuel to the
tank.
I've been told this is a violation. The person who tells me this can't
cite a FAR, and I can't find one in my own search.
Old July 23rd 07, 08:02 PM posted to rec.aviation.piloting,rec.aviation.owning
Gig 601XL Builder
flown for part 91 service only.
Examples:
hours later, upon completing the trip and returning to the field, I
pour it back into the tank.
time while taking readings. After I read the tank, I return the fuel
to the tank.
can't cite a FAR, and I can't find one in my own search.
I can't think of ant FAR that could even remotely make what you are wanting
to do a violation.
Old July 23rd 07, 08:07 PM posted to rec.aviation.piloting,rec.aviation.owning
Don Tuite
On Mon, 23 Jul 2007 13:33:28 -0400, B A R R Y
Examples:
back into the tank.
tank.
First Reaction: If it's okay to use a GATT jar, what would the cutoff
be? Two ounces? A cup? 49 gallons?
Second Reaction: A violation of the National Fire Code will get you
thrown off the airport faster than a FAR violation will. The question
about where the cutoff is can probably be found in the NFC.
Third Reaction: If you're gonna do it anyway, common sense says don't
release a lot of gasoline fumes in an enclosed place and if you don't
KNOW that the transfer equipment is safe from a static electricity
standpoint, DON'T do it. There are faster, less painful ways to die.
Don
Old July 23rd 07, 08:31 PM posted to rec.aviation.piloting,rec.aviation.owning
B A R R Y[_2_]
How much fuel is in your riding mower and other power equipment? Or the
car(s) in your garage? Did I say store it on the airport? How many 5
gallon gas cans are on a typical landscaping or race car trailer?
Thanks. I didn't ask for knee-jerk, flame-war (pun intended) inducing,
chicken little reactions.
If someone can cite a part 43, 91, etc... rule that says fuel removed
from an aircraft with safe and legal defueling methods can't be returned
to the same tank, I'd be very much obliged! ;^)
Old July 23rd 07, 08:46 PM posted to rec.aviation.piloting,rec.aviation.owning
Michael[_1_]
The world is full of 'experts' who will tell you that something is
against the FAR's. When pressed, they will tell you to call the FSDO
if you don't believe them. Those experts can't ever seem to quote the
relevant FAR. They are best ignored.
There is no such regulation in the Part 91 world.
Michael
Old July 23rd 07, 08:51 PM posted to rec.aviation.piloting,rec.aviation.owning
John Godwin
B A R R Y wrote in
. net:
this case, and then putting it back into the same plane? The
plane is flown for part 91 service only.
Nope. Maintenance shops do it all the time. The shop I'm familiar with
have special containers and procedures (comply with fire and other
safety codes).
Old July 23rd 07, 08:59 PM posted to rec.aviation.piloting,rec.aviation.owning
B A R R Y[_2_]
Thanks!
I've been searching 91 and 43, both electronically and on paper, but my
43 experience is limited.
The problem in this case, is that the "expert" is related to an airport
manager.
Old July 23rd 07, 09:05 PM posted to rec.aviation.piloting,rec.aviation.owning
Gig 601XL Builder
the relevant FAR. They are best ignored.
Thanks!
my 43 experience is limited.
airport manager.
So what. If it is against FAA rules tell the manager that if he would kindly
show you the rule you will be more than happy not to do it. If it is aganist
an airport rule then he and you should do the same.
Old July 23rd 07, 09:35 PM posted to rec.aviation.piloting,rec.aviation.owning
Maxwell
"B A R R Y" wrote in message
. net...
Examples:
later, upon completing the trip and returning to the field, I pour it back
into the tank.
tank.
Defueling is common practice in the airline business. We always defueled
before bringing in both narrow and wide body aircraft. I feel certain they
reused the same fuel.
Old July 23rd 07, 09:48 PM posted to rec.aviation.piloting,rec.aviation.owning
Newps
The FAA does not get into fueling/defueling. At all.
Replacing innertubes without replacing tires? Ben Jackson Owning 28 November 6th 06 05:54 PM
Removing 100LL Fuel Stain Jeff Home Built 7 September 20th 05 09:45 PM
FOLO: Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 10 February 23rd 05 05:35 AM
Fuel quality control standards for aircraft rental/fuel sales... [email protected] Owning 19 January 19th 05 05:12 AM
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 11:20 PM
