I was using Flight Following yesterday and was reminded of a problem that my
RV has displayed for a long time: The transponder and altimeter do not agree. In general, ATC sees my altitude as about 200' lower than what is shown on my altimeter. A couple of facts: - The transponder/encoder always pass their certification checks. - The pitot/static system is installed per plans. Any thoughts? KB |
Tell ATC that you aren't 200' low, they're 200' too high
(Actually, I've encountered 200' differences when switched to a new ATC sector - somebody's not calibrated.) Seriously, if you set your altimeter to the local AWOS/ATIS/ASOS does it read the published field elevation? If not, the altimeter needs calibration. If so, it's not the instrument. Presumably, it's not the encoder if it passes the bi-annual field check but do you know if your avionics shop has calibrated their transponder checking equipment? When was the last pitot/static check done? Do you have a leak in the static tubing? If there is a leak in the static system, the altimeter may be reading cabin pressure which 'could' be higher than a true static. Oh the fun of chasing gremlins... Bill Daniels "Kyle Boatright" wrote in message ... I was using Flight Following yesterday and was reminded of a problem that my RV has displayed for a long time: The transponder and altimeter do not agree. In general, ATC sees my altitude as about 200' lower than what is shown on my altimeter. A couple of facts: - The transponder/encoder always pass their certification checks. - The pitot/static system is installed per plans. Any thoughts? KB |
"Bill Daniels" bildan@comcast-dot-net wrote in message . .. Tell ATC that you aren't 200' low, they're 200' too high (Actually, I've encountered 200' differences when switched to a new ATC sector - somebody's not calibrated.) Seriously, if you set your altimeter to the local AWOS/ATIS/ASOS does it read the published field elevation? If not, the altimeter needs calibration. If so, it's not the instrument. The altimeter was reworked a couple of years ago because it got "sticky". It came back with a yellow tag and a test card indicating it was calibrated within VFR limits. Since the altitude discrepancy problem existed before the altimeter rebuild and has persisted since, I'm guessing the Altimeter is good. Presumably, it's not the encoder if it passes the bi-annual field check but do you know if your avionics shop has calibrated their transponder checking equipment? No idea, but doesn't the shop have to calibrate its equipment to remain a certified shop? When was the last pitot/static check done? Do you have a leak in the static tubing? If there is a leak in the static system, the altimeter may be reading cabin pressure which 'could' be higher than a true static. I've never done a pitot/static check. Is there a DIY procedure for that? Oh the fun of chasing gremlins... You got that right! Bill Daniels "Kyle Boatright" wrote in message ... I was using Flight Following yesterday and was reminded of a problem that my RV has displayed for a long time: The transponder and altimeter do not agree. In general, ATC sees my altitude as about 200' lower than what is shown on my altimeter. A couple of facts: - The transponder/encoder always pass their certification checks. - The pitot/static system is installed per plans. Any thoughts? KB |
"Kyle Boatright" wrote in message . .. "Bill Daniels" bildan@comcast-dot-net wrote in message . .. Tell ATC that you aren't 200' low, they're 200' too high (Actually, I've encountered 200' differences when switched to a new ATC sector - somebody's not calibrated.) Seriously, if you set your altimeter to the local AWOS/ATIS/ASOS does it read the published field elevation? If not, the altimeter needs calibration. If so, it's not the instrument. The altimeter was reworked a couple of years ago because it got "sticky". It came back with a yellow tag and a test card indicating it was calibrated within VFR limits. Since the altitude discrepancy problem existed before the altimeter rebuild and has persisted since, I'm guessing the Altimeter is good. It's a good bet that a yellow tagged altimeter is OK but I'd still check it against field elevation. In fact, it's a good idea to do it each time you do a pre-flight check. Just set the local altimeter pressure and see if the altimeter indicates field elevation. The most likely problem is a leak in the static system. If you're up to it there's a simple check. Get a large plastic hypo syringe and carefully "T" it into the static tubing behind the panel using a fish tank tubing "T" and Tygon tubing - make sure all fittings are leak free. Cover the static ports with electrical tape to seal them off. SLOWLY inject air with the syringe until the altimeter reads 1000 feet lower than field elevation. Stop injecting air and watch the altimeter. If there's a leak, the altimeter will slowly return to field elevation. The ROC will indicate the rate of the leak. Realize that the leak can be inside an instrument. I've seen several ROC instruments with internal leaks (Usually the glass gasket is bad which can be determined with a soap solution.) but the ASI or even the altimeter itself can be the culprit. If there is a leak, look for bubbles with soap solution until you find where it is. BTW, there's an old glider pilot trick to sealing Tygon tubing to instrument nipples. Go to a veternary supply store and buy a bag of the rubber bands(green O-rings) used to castrate sheep (I'm not kidding!) These are just the right size to slip over the outside of the Tygon after it is pushed onto the instrument nipple. Put the O-ring over the tubing before pushing it onto the instrument nipple then roll it over the nipple. It makes a reliable gas-tight fit even when the Tygon gets old and yellowed. Bill Daniels |
"Bill Daniels" bildan@comcast-dot-net wrote in message news ![]() "Kyle Boatright" wrote in message . .. "Bill Daniels" bildan@comcast-dot-net wrote in message . .. Tell ATC that you aren't 200' low, they're 200' too high (Actually, I've encountered 200' differences when switched to a new ATC sector - somebody's not calibrated.) Seriously, if you set your altimeter to the local AWOS/ATIS/ASOS does it read the published field elevation? If not, the altimeter needs calibration. If so, it's not the instrument. The altimeter was reworked a couple of years ago because it got "sticky". It came back with a yellow tag and a test card indicating it was calibrated within VFR limits. Since the altitude discrepancy problem existed before the altimeter rebuild and has persisted since, I'm guessing the Altimeter is good. It's a good bet that a yellow tagged altimeter is OK but I'd still check it against field elevation. In fact, it's a good idea to do it each time you do a pre-flight check. Just set the local altimeter pressure and see if the altimeter indicates field elevation. I should have mentioned before that the altimeter is close to the field elevation when on the ground. Well within VFR limits. One interesting test would be a low altitude pass down the runway at cruise power and speed. If I'm 50' above the field and the altimeter shows field level + 50' (or thereabouts) what would that tell me? A basic question: If there was a problem with the static system, wouldn't that cause the same discrepancy in both the altimeter and transponder? The most likely problem is a leak in the static system. If you're up to it there's a simple check. Get a large plastic hypo syringe and carefully "T" it into the static tubing behind the panel using a fish tank tubing "T" and Tygon tubing - make sure all fittings are leak free. Cover the static ports with electrical tape to seal them off. SLOWLY inject air with the syringe until the altimeter reads 1000 feet lower than field elevation. Stop injecting air and watch the altimeter. If there's a leak, the altimeter will slowly return to field elevation. The ROC will indicate the rate of the leak. I was trying to come up with a technique to do this, and this one sounds like a winner. There is a location in the baggage compartment where it is easy to get to the static tubing... Realize that the leak can be inside an instrument. I've seen several ROC instruments with internal leaks (Usually the glass gasket is bad which can be determined with a soap solution.) but the ASI or even the altimeter itself can be the culprit. If there is a leak, look for bubbles with soap solution until you find where it is. BTW, there's an old glider pilot trick to sealing Tygon tubing to instrument nipples. Go to a veternary supply store and buy a bag of the rubber bands(green O-rings) used to castrate sheep (I'm not kidding!) These are just the right size to slip over the outside of the Tygon after it is pushed onto the instrument nipple. Put the O-ring over the tubing before pushing it onto the instrument nipple then roll it over the nipple. It makes a reliable gas-tight fit even when the Tygon gets old and yellowed. Bill Daniels Thanks for the ideas. KB |
... ... I should have mentioned before that the altimeter is close to the field elevation when on the ground. Well within VFR limits. One interesting test would be a low altitude pass down the runway at cruise power and speed. If I'm 50' above the field and the altimeter shows field level + 50' (or thereabouts) what would that tell me? A basic question: If there was a problem with the static system, wouldn't that cause the same discrepancy in both the altimeter and transponder? ... That seems likely as far as static sytem design is concerned (e.g. static port location). If they differ only in flight, then they probably aren't seeing the same static source due to kinks and leaks. I assume that both are really connected to the static source (You have looked, right? No hose has fallen off?) Have the encoder output compared to the altimeter while sitting on the ground - if they are the same, you have a plumbing problem. If they are different, the problem is in the instruments, eh? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Building to the plans doesn't guarantee accurate static pressure
readings; the system is quite sensitive to tiny plane-to-plane variations. And the official calibration check with the airplane stationary wouldn't catch an in-flight static-pressure error. Have an observer watch the altimeter during takeoff and landing ground rolls: if it changes from a standstill to takeoff speed and then changes in the opposite sense during the landing roll (the VSI would also depart from zero at these times), then you'll know that there's a static-pressure measurement error built into your installation. The amount of the spurious altitude change would be about 200 ft times the ratio of takeoff/landing speed to cruise speed; e.g., if the speed ratio is about 1/3, then the change would be 60-70 ft. The static port(s) wouldn't necessarily have to be relocated if this error is present; you may be able to tweak the readings sufficiently with a wire-and-tape "trip strip" just ahead of the port (to lower the static reading) or behind it (to raise the reading). Even some store- bought airplanes have such cheap-and-easy fixes near their ports. Just keep experimenting with the height and position of the strip until the airplane doesn't "climb" or "descend" while trundling along a level runway. |
On Sun, 05 Aug 2007 10:27:25 -0700, quietguy wrote:
Building to the plans doesn't guarantee accurate static pressure readings; the system is quite sensitive to tiny plane-to-plane variations. And the official calibration check with the airplane stationary wouldn't catch an in-flight static-pressure error. Yes, but: If the encoder and the altimeter are using the same static source, both should be in error the same amount. Kyle's problem is a split indication; the encoder is sensing a different altitude than the altimeter. This tends to argue that the problem is a leak related to the altimeter itself, not in the static system. Perhaps the altimeter has a leak that only manifests itself when it's being vibrated (i.e., the engine running). My Microair transponder gives me a readout of the altitude that's being sent to ATC. I can set the A/C altimeter to 29.92 and compare. That's how I discovered my encoder had gone south two months back; the altitude readout wasn't matching the altimeter. Ron Wanttaja |
The encoder gives an uncorrected altitude. You altimeter is corrected when you set it for barometric pressure at the beginning of flight. ATC receives the signal from the encoder/transponder and corrects it for the local pressure. If you are some distance from their station, there could easily be a 0.2" Hg pressure differential that would result in a 200' differential (one inch Hg per 1000' of altitude). So even if you are using the altimeter setting they give you, I wouldn't expect perfect correlation if there's a pressure gradient beteen you and them. Dan |
wrote in message oups.com... The encoder gives an uncorrected altitude. You altimeter is corrected when you set it for barometric pressure at the beginning of flight. ATC receives the signal from the encoder/transponder and corrects it for the local pressure. If you are some distance from their station, there could easily be a 0.2" Hg pressure differential that would result in a 200' differential (one inch Hg per 1000' of altitude). So even if you are using the altimeter setting they give you, I wouldn't expect perfect correlation if there's a pressure gradient beteen you and them. Dan If it was an intermittent problem, your theory would be plausible, but since I see the same problem virtually every time I deal with ATC, I'm thinking it is a hardware problem. The only issue is which piece of hardware? ;-) KB |
| Connecting hoses to pitot/static tubes | Ernest Christley | Home Built | 9 | October 23rd 06 02:44 PM |
| Pitot Static 411 413 followup post | A Lieberman | Owning | 12 | June 18th 05 05:00 PM |
| Sharing static and pitot line | Istvan Csonka | Soaring | 13 | March 12th 05 04:00 AM |
| pitot/static location | Ray Toews | Home Built | 2 | December 30th 03 01:52 AM |
| Pitot and static couplings for a TTU-205 | B2431 | Home Built | 0 | August 15th 03 08:25 AM |
