Connecting hoses to pitot/static tubes
Old October 22nd 06, 03:22 AM posted to rec.aviation.homebuilt
Ernest Christley
Default Connecting hoses to pitot/static tubes
What is the best way to secure plastic tubing to aluminum pitot tubes.
The plastic hose will slide over the aluminum tube, though it requires
quite a bit of push to get more than 1/2". Would a couple of spring
clamps work, or is something more significant called for?
Old October 22nd 06, 03:46 AM posted to rec.aviation.homebuilt
Hi,
Use a hair drier to warm the plastic tube and it will slide more
easily. While the tube is still warm use a small tie wrap. Voilą!
Regards,
S6
Old October 22nd 06, 03:59 AM posted to rec.aviation.homebuilt
Bill Daniels
Anything that might make the plastic tube "bunch up" so as to create a leak
path is a bad idea. Wire and clamps seem to do this. The solution is
"castrating rings" (No kidding).
See: http://www.agri-pro.com/Castrate.html#rings
Roll one of these over the plastic tube after you slip it over the aluminum
tube to get an air tight fit.
Bill Daniels
"Ernest Christley" wrote in message
Old October 22nd 06, 04:11 AM posted to rec.aviation.homebuilt
I put a twist of safety wire around it....
Old October 22nd 06, 04:24 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Do you go around it twice before twisting, to avoid "bunching" ?
Old October 22nd 06, 04:29 AM posted to rec.aviation.homebuilt
"You only go around once in life...."
....and so do my pitot/static safety wires. Maybe that explains my 150 knot
cruise. :-)
Old October 22nd 06, 05:00 AM posted to rec.aviation.homebuilt
Morgans[_2_]
cruise. :-)
Chuckle out loud
Perhaps you got one of those wires twisted tooo tightly in the wrong place.
Perhaps around your "truth tube", whatever that is!
(get your mind out of the gutter-it was not meant "that" way!)
Old October 22nd 06, 04:34 PM posted to rec.aviation.homebuilt
Ron Natalie
I've got these non reusable clamps that I have on my soda lines
(which are under pressure) in my kitchen. You have to have a little
tool (looks like a pair of end nippers) to squeeze them on.
Old October 23rd 06, 01:19 AM posted to rec.aviation.homebuilt
jerry wass
requires quite a bit of push to get more than 1/2". Would a couple
of spring clamps work, or is something more significant called for?
I hope your soda lines are of the type which is amenable with Scots
whisky--??
Old October 23rd 06, 01:44 PM posted to rec.aviation.homebuilt
Ron Natalie
whisky--??
Put fizzy stuff in the whiskey? Are you daft.
It does dispense tonic for the gin however.
Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gear for B-17 setup Juan Jimenez General Aviation 7 September 19th 06 10:20 PM
Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gear for B-17 setup Juan Jimenez Aviation Marketplace 7 September 19th 06 10:20 PM
Proposed AD ECi connecting rods Jim Burns Owning 8 October 8th 05 04:27 PM
Seeking US Source for Main Wheel Tubes Chris OCallaghan Soaring 7 August 28th 04 03:46 PM
Rockets used in al-Rashid hotel match "aluminum tubes" rockets Robb McLeod Military Aviation 7 October 28th 03 07:49 AM
