Troubles with a Compaq 1550
Old August 29th 07, 04:20 PM posted to rec.aviation.soaring
Dick[_3_]
Default Troubles with a Compaq 1550
I have a backup 1550 that has just been sitting in it's cradle for at
least a couple of years. Recently the charge light went out and the
unit would not turn on. I switched the main battery with my other
1550 and the unit still would not turn on, nor would the charge light
come on??? Anyone have a suggestion? Dick
Old August 29th 07, 04:26 PM posted to rec.aviation.soaring
Jim Vincent
Replace the back up battery. Try a hard reset.
"Dick" wrote in message
ps.com...
Old August 30th 07, 12:13 AM posted to rec.aviation.soaring
Kloudy via AviationKB.com
hijack alert.
I have about 5 or 6 1520's on the shelf and they all seem to excessively
drain the lithium-coin-backup battery.
They'll sit on the shelf or charger for a coupla weeks, then when I start 'em
up, I get the low backup warning.
I realize I'm not helping out with your original inquiry...cuz I have nothing
more to offer than the hard reset suggestion.
Just wondering if anyone checking in here has seen similar probs to mine.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...aring/200708/1
Old August 31st 07, 01:29 AM posted to rec.aviation.soaring
HL Falbaum
"Kloudy via AviationKB.com" u33403@uwe wrote in message
news:7770c6e0bcccb@uwe...
hijack alert.
'em
nothing
I have had that , too. When I go to settings/system/power, it reads the
backup battery as "good". If I take the coin cell out and measure it, it is
good.
Beats me!
Hartley Falbaum
Old August 31st 07, 02:57 PM
TowPilot185 TowPilot185 is offline
Junior Member
First recorded activity by AviationBanter: Mar 2006
There was a document on the HP web site that addressed this situation. From memory, the solution was to remove the batter, Press the reset button 3 times, then replace the batter. That would usually wake the old iPaqs back up again.
Old August 31st 07, 11:56 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I recall a situation where the unit would power-up and show a big "Q" on the
screen but never get past it. I found a tip that a removing both batteries
and waiting about 10 minutes would cause a hard reset and it worked for me.
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"TowPilot185" wrote in message
TowPilot185
Compaq Aero 1550 question [email protected] Soaring 2 May 9th 07 09:32 PM
troubles with ATC john hawkins Piloting 3 May 6th 07 05:30 PM
troubles with ATC john hawkins Instrument Flight Rules 3 May 6th 07 05:30 PM
Compaq 1550 Aero -w- POCKET-NAV Software For Sale Guy Byars Soaring 0 September 19th 05 10:19 AM
USB to Compaq Aero 1550 Cable Ira Blieden Soaring 1 April 23rd 04 03:12 PM
