Compaq Aero 1550 question
Old May 9th 07, 03:13 PM posted to rec.aviation.soaring
Default Compaq Aero 1550 question
Hi,
Trying to run Glide Navigator II on an Aero 1550, and at the bottom of
the screen there's a bar showing program name, clock, and keyboard
button. This bar obscures a critical part of the screen showing wind
direction, etc. I can't find the way to hide this bar, but believe it
can be done. Anyone know how to hide it?
Many thanks,
Paul
Old May 9th 07, 03:46 PM posted to rec.aviation.soaring
5Z
Are you sure you are running the correct version of the program?
There is a different version for models prior to the 1550 such as 1530
and 1520.
If you are running the correct version, the status bar will be removed
on startup.
If, while running GNII, some other application is started by pressing
a function key, etc., the status bar will also display. To get rid of
this, just "restart" GNII by using the start menu.
-Tom
Old May 9th 07, 09:32 PM posted to rec.aviation.soaring
Paul Remde
Hi,
One additional suggestion.
If you are using the 1520 or 1530 version on a 1520 or 1530, you will also
need to enable the taskbar to "autohide". Go to Start/Settings/Taskbar and
check the "Auto hide" checkbox. The taskbar will then hide. The bring it
up you need to touch the very bottom edge of the screen with the stylus.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"5Z" wrote in message
and 1520.
on startup.
-Tom
Compaq aero question quietman Soaring 3 January 25th 06 03:47 PM
Compaq 1550 Aero -w- POCKET-NAV Software For Sale Guy Byars Soaring 0 September 19th 05 10:19 AM
FS: Aero 1550 GH Soaring 1 September 24th 04 02:59 AM
FS Aero 1550 Ed Hollestelle Soaring 0 July 12th 04 08:10 PM
USB to Compaq Aero 1550 Cable Ira Blieden Soaring 1 April 23rd 04 03:12 PM
