I am used to flying planes with KX-155/155a and/or G430/530. In either
case, your OBS and VOR indicator are separate from the frequency select unit. Add to this the fact that many panels are set up with the DME slaved only to the #2NAV, and you have ample room for error. It's just easy, in those situations where you're dialing through frequencies quickly, to find yourself following the wrong VOR, or not understanding why your DME is not doing what you expect. I recently flew an older Cessna, in which the NAV frequency select was directly ON the VOR indicator, as was the DME readout. This just seemed like good ergonomics to me - no way to make a mistake. Who makes these? Why do we see them so rarely? |
Airbus wrote:
I recently flew an older Cessna, in which the NAV frequency select was directly ON the VOR indicator, as was the DME readout. This just seemed like good ergonomics to me - no way to make a mistake. Who makes these? Why do we see them so rarely? NARCO. One of the few good things they ever did. It ought to be possible now to do that quite practically with the miniturization of components. |
On Mon, 10 Sep 2007 07:59:40 -0400, Ron Natalie
wrote: Airbus wrote: I recently flew an older Cessna, in which the NAV frequency select was directly ON the VOR indicator, as was the DME readout. This just seemed like good ergonomics to me - no way to make a mistake. Who makes these? Why do we see them so rarely? NARCO. One of the few good things they ever did. Yes & No! An excellent idea and saves panel space. We have one of these but also have a selector switch so the DME readout (on the VOR 1 Indicator) can be selected to either NAV 1 or NAV 2. Great when the VOR you're following does not have an associated DME or you are using a VOR too far away to read DME but a nearby LOC/DME can be used. Yes it's easy to make a mistake :-( It ought to be possible now to do that quite practically with the miniturization of components. |
quickly, to find yourself following the wrong VOR, or not understanding why your DME is not doing what you expect. In my case, my Nav 1 is below my Nav 2 in the panel and the VOR heads are the reverse of that (VOR 1 above VOR 2. I made the usual mistakes with this situation many times until I got used to it. The thing is, that I navigate with GPS during VFR operations and it's not really an issue. However, I use the Nav's and VOR's during IFR operations and that is when a mistake like that could be critical. My partner and I have discussed making the swap, but we've not done it yet. I think the next time it's in for anything else I'm going to authorize the switch. Kobra |
In-Panel 396/496 Setups with the 430/530? | Marco Leon | Owning | 4 | December 18th 06 06:45 PM |
Why not a hinged panel? | Jay Honeck | Owning | 22 | March 7th 05 11:15 PM |
IFR PANEL | Flyhighdave | Home Built | 4 | January 18th 05 04:24 AM |
IFR PANEL | Flyhighdave | Home Built | 4 | January 17th 05 07:15 PM |
182 panel | Jim | Owning | 2 | August 2nd 03 09:06 PM |
