Does anyone have this setup where the 396/496 (particularly the 496) is
in their panel hooked up through an RS232 cable to a 430 or 530? I saw a post by Mikem with very good specifics on the pin-outs but I have a couple of questions: 1) Does the 496 pick up the inputted flight plan/route from the 430/530? 2) If yes, what's the procedure? Does it act like another IFR box where you need to use the cross-fill function or is it automatically filled? 3) Again, if yes, how critical is it to keep the 496 up to date with the same database? Will it behave badly if it is not in sync and there is a renamed fix in the active plan? I plan on updating the 496 only once or twice per year while I have the 430 on the IFR-mandated 28-day cycle (OK guys, don't get hung up on the term "mandated"--you know what I mean). One last question, has anyone done the panel mounting of the 396/496 themselves or is everyone going to an avionics shop? I may need to travel a bit to do this since the nearest [reasonably-priced] avionics shops are in Connecticut and the word that their local FSDO is very strict and does not approve of the Airgizmos installation on certified aircraft. The local FSDO at my location (Farmingdale) is OK with it and looks at it as an installation that does not require a 337 (although recommended). However, I will want to do the RS232 conx so doing it myself is out of the question. Marco |
Marco Leon wrote:
Does anyone have this setup where the 396/496 (particularly the 496) is in their panel hooked up through an RS232 cable to a 430 or 530? I have my crusty 195 attached to my 430. Should be simular. 1) Does the 496 pick up the inputted flight plan/route from the 430/530? Yes. Change the route on the 430 and it is automatically sent to the handheld. 2) If yes, what's the procedure? Does it act like another IFR box where you need to use the cross-fill function or is it automatically filled? No cross-fill necessary. 3) Again, if yes, how critical is it to keep the 496 up to date with the same database? Will it behave badly if it is not in sync and there is a renamed fix in the active plan? I plan on updating the 496 only once or twice per year while I have the 430 on the IFR-mandated 28-day cycle Don't know, never noticed, and my 195 hasn't been updated in a couple of years. On the other hand the airports or other way points don't move change much. One last question, has anyone done the panel mounting of the 396/496 themselves or is everyone going to an avionics shop? Someone else will have to address this question. My avionics shop was fine with giving me a unterminated serial cable. I put on the connector and finished the handheld mounting to my satisfaction. Probably would give some FSDO fits. -- Frank Stutzman Bonanza N494B "Hula Girl" Hood River, OR |
Frank Stutzman wrote:
I have my crusty 195 attached to my 430. Should be simular. Yes. Change the route on the 430 and it is automatically sent to the handheld. No cross-fill necessary. Don't know, never noticed, and my 195 hasn't been updated in a couple of years. On the other hand the airports or other way points don't move change much. Someone else will have to address this question. My avionics shop was fine with giving me a unterminated serial cable. I put on the connector and finished the handheld mounting to my satisfaction. Probably would give some FSDO fits. Thanks for your PIREP. If it plays nicely with the 195, sounds like it should be fine with the 496. When I called my local FSDO, they stressed that each FSDO was different in their point of view. I may take a look around for a local avionics shop since In know my local FSDO is mostly OK with it. Marco |
![]() Marco Leon wrote: 3) Again, if yes, how critical is it to keep the 496 up to date with the same database? Will it behave badly if it is not in sync and there is a renamed fix in the active plan? I plan on updating the 496 only once or twice per year while I have the 430 on the IFR-mandated 28-day cycle (OK guys, don't get hung up on the term "mandated"--you know what I mean). I have my 496 fed from either my KLN-94 or my KLN-90B, and the databases are way out of sync. It works fine. The 496 will create a fix if it has to, and it's position is different from that in the data from the IFR unit, you just end up with an aliased user waypoint, offset slightly from the 496's version. |
Mike Granby wrote:
I have my 496 fed from either my KLN-94 or my KLN-90B, and the databases are way out of sync. It works fine. The 496 will create a fix if it has to, and it's position is different from that in the data from the IFR unit, you just end up with an aliased user waypoint, offset slightly from the 496's version. Sounds like it plays nicely with a non-Garmin mate. Thanks. Marco |
Why not a hinged panel? | Jay Honeck | Owning | 22 | March 7th 05 11:15 PM |
Trying to find the Boeing 737-300 Photo Real Panel for FS98(antique;-) | Heiko Brandstaedter | Simulators | 0 | October 7th 04 02:42 PM |
C182 Glass Panel | Scott Schluer | Piloting | 15 | February 27th 04 03:52 PM |
Air Force Academy Review Panel Releases Report | Otis Willie | Military Aviation | 0 | September 19th 03 03:45 AM |
Air Force Museum forms review panel | Otis Willie | Military Aviation | 2 | August 29th 03 04:41 PM |
