Welding question: joining an inner sleeve
Old September 19th 07, 09:47 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Welding question: joining an inner sleeve
Please see the sketch at http://members.cox.net/mhorowit/cluster/
Using Oxyacetylene, how do I get the base molten without burning the
two pieces that form the 1/8" gap? Are "chill bars" the only choice?
MikeH
Old September 20th 07, 01:25 AM posted to rec.aviation.homebuilt
J.Kahn
MikeH
If while playing with different heat settings you can't get the base
metal hot enough while not burning away the edges, you'll have to clamp
heat sinks to the upper parts.
However, you don't have to get the base completely molten to start a
weld. You get it just under molten, drop a molten bead on it, then heat
the bead itself until it fuses and blends with the underlying metal on
each surface, then start adding more rod to get the resulting puddle
nice and full with a nice fused feather edge all around, then start
moving. Putting down molten rod just before the base metal is molten
is the best way to weld exposed edges without burn back. You'll have to
carefully observe the edge of the puddle that is on the base material to
be sure it is blending and fusing.
The rod tip itself is key to controlling the amount of heat going into
the puddle. If an edge gets too hot and starts to burn away, don't back
right off, just back off a tiny bit while at the same time putting the
rod tip between the torch and the overheated edge and drop some rod
metal there. That gives a bit of breathing room while you adjust and go
back in. Mastering the technique of backing off just enough but not too
much makes a big difference because now you can stay in control while
doing a really tricky joint that is not tolerant of excess heat, and
when you get burn through's, you can pause to fill the hole and then
keep going without missing a beat.
John
Old September 20th 07, 02:47 AM posted to rec.aviation.homebuilt
clare at snyder.on.ca
On Wed, 19 Sep 2007 20:25:46 -0400, "J.Kahn"
MikeH
John
This is tubing, right? Drill a couple of holes and rosette weld, or
plug weld the sleave in place. It is now doing it's job Now weld the
ends of the tubes together. If the weld penetrates into the
re-enforcement sleave, good. If it doesn't the sleave is still in
there providing extra strength to the joint (done properly, the joint
is almost strong enough with just 4 plug welds per end)
Posted via a free Usenet account from http://www.teranews.com
Old September 20th 07, 05:46 AM posted to rec.aviation.homebuilt
Fortunat1
clare at snyder.on.ca wrote in news:r3k3f35vka26ss9jq6k80m2cr1ef67usun@
4ax.com:
This makes sense to me, however, looking in my books, it's stated pretty
clearly that the inner tube should be welded to the outers.
there's a copy of that text he
http://www2.tech.purdue.edu/at/cours...Ac43-13-1B/CH4
_5.pdf
Now, it would seem to me that penetration of the inner tube would add very
little strength at all, particularly if it was a good snug fit. Am I
reading this wrong?
Old September 20th 07, 10:45 AM posted to rec.aviation.homebuilt
Michael Horowitz
4ax.com:
_5.pdf
reading this wrong?
You're quoting a very general section. If you could cite the specific
sub-paragraph it might help - Mike
Old September 20th 07, 07:32 PM posted to rec.aviation.homebuilt
Fortunat1[_8_]
Michael Horowitz wrote in
news:r3k3f35vka26ss9jq6k80m2cr1ef67usun@ 4ax.com:
joint is almost strong enough with just 4 plug welds per end)
pretty clearly that the inner tube should be welded to the outers.
http://www2.tech.purdue.edu/at/cours...Links/Ac43-13-
1B
/CH4 _5.pdf
very little strength at all, particularly if it was a good snug fit.
Am I reading this wrong?
Sorry. Scroll down to 4-84.
There's a whole section on the type of repairs you're talking about.
4-84 specifically mentions including the innner tube into the weld. It
seems to me that the weld area would be at least as strong without
welding across the inner tube like that. If you weld a doubler on the
end of a strap, for instance, you don't lap weld across the widthe of
the strap where the thickness steps down, you only edge weld around the
outside perimeter. That would indicate to me that welding across a piece
of tubing, unneccesarily, only puts stress risers around the weld. If
it's a snug fit, you've got to have at least the same strength there you
had with the original tube.
Old September 21st 07, 02:45 AM posted to rec.aviation.homebuilt
J.Kahn
4ax.com:
_5.pdf
reading this wrong?
I believe that you have to effectively have a full lap joint weld
between each outer tube and inner tube, AND the joint must be a
truncated cut and not just straight across in order to have sufficient
weld cross section since it's essential that the weld zone be much
stronger than the virgin metal up the tube.
The rosette welds done further up don't contribute that much strength
and are mostly (I believe) to prevent the inner tube from having an
unsupported length that allows "wiggling" of the inner tube in the outer
tube under stress. possibly leading to cracks in the main weld.
John
Old September 21st 07, 06:49 AM posted to rec.aviation.homebuilt
Fortunat1
"J.Kahn" wrote in
1
B/CH4 _5.pdf
outer tube under stress. possibly leading to cracks in the main weld.
OK, I can buy all of that, but I don't know exactly what you mean by
truncated. Are you talking about the profile of the edges of the outer
tube, or do you mean the outer tube must be cut diaganally?
Old September 21st 07, 04:02 PM posted to rec.aviation.homebuilt
Michael Horowitz
On Thu, 20 Sep 2007 21:45:24 -0400, "J.Kahn"
John
John - please see http://members.cox.net/mhorowit/cluster/lapjoint/
I took your suggestion and treated each side of the "outer sleeve" and
the "inner sleeve" as the components of a lap joint; hence two beads.
That's what you were talking about instead of my trying to integrate
the outer and inner sleeves in one weld, correct? - Mike
PS - I don't think taking a shortcut by simply cutting a partial
slice in a larger diameter tube would make a difference in the
exercise;
Old September 20th 07, 05:53 AM posted to rec.aviation.homebuilt
Maxwell
"Michael Horowitz" wrote in message
MikeH
Will your situation allow you to increase the gap? Perhaps heating a little
slower and increasing the gap would work for you.
Welding question - Michael Horowitz Restoration 11 September 7th 06 03:52 PM
Welding question: reinforce by inner sleeve Michael Horowitz Home Built 7 June 12th 06 07:11 PM
Welding question: 43-13-1B, Fig.4-43 Mike Restoration 0 May 15th 06 02:36 PM
Welding question Mike Restoration 4 February 20th 06 02:23 PM
Welding question Michael Horowitz Home Built 1 October 13th 05 09:53 PM
