Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
Welding question -
Old April 30th 06, 11:52 PM posted to rec.aviation.restoration
Default Welding question -
In preparation for doing some simple OA welding on a rudder, I've been
practicing on some 4130 scrap. Since there is filler where it's not
structurally important, I"ve been filing the excess material. All
except one and it's as hard as if I were trying to file stainless.
Is this an indication that I was using an oxidizing flame on that
sample? - MIke
Old May 4th 06, 05:00 AM posted to rec.aviation.restoration
sample? - MIke
If you fill with 4130, the weld will be hard -- and brittle. That is why
you use regular welding rod on 4130 -- the thicker material in the weld
relieves stress and keeps things good.
Old May 4th 06, 02:27 PM posted to rec.aviation.restoration
'regular' welding rod?
What's that?
Not a 4130 rod for welding 4130? - Mike
Old May 5th 06, 06:38 PM posted to rec.aviation.restoration
In article .com,
What's that?
Nope
4130 rod for welding 4130 will require heat treat, or it will be brittle
and crack. Use standard, off-the-shelf welding rod from your local
welding supplier.
Old May 5th 06, 06:54 PM posted to rec.aviation.restoration
Hi Orval,
I think what the OP is trying to get at, is there is no standard
off the shelf welding rod.
The most sold is probably 6010/6011. It requires a stitch welding
technique, and tends to stick when starting. It makes strong deep
all position welds that tend to be ugly. Not for beginners.
The easiest to use is 6013, but it makes really pretty looking, flat
position, non xray quality welds, and has little penetration.
The most common low hydrogen rod is 7018, but it is tricky to use,
and must be stored in an oven. It is used almost exclusively for all
position, structural steel welding.
And then there is a host of SS rods that some people like because of
their easy welding characteristics, and the toughness of the weld.
So, what do you mean when you state off-the-shelf? I would recommend
7018, and a whole bunch of practice.
-Chuck
Orval Fairbairn wrote:
In article .com,
What's that?
Nope
welding supplier.
Old May 5th 06, 06:58 PM posted to rec.aviation.restoration
In article .com,
What's that?
Nope
welding supplier.
Oh, I forgot to mention, the welded material gets just as hot as the
weld, so if you have cracking problems that require heat treatment, you
are going to have problems regardless of the rod you use. Most of the
time, cracking problems are hydrogen embrittlement, and are prevented
by using a low hydrogen rod, such as the 7018,8018,9018... series of rods.
-Chuck
Old May 8th 06, 02:39 PM posted to rec.aviation.restoration
Chuck..
Decent advice for stick welding, but the question was about gas welding.
There are a number of good filler rods for steel, and for small puddles
with small tips, one of the best is ER70sXXX mig wire. This lets you
place filler rod in the weld without chilling the puddle too hard with a
larger diameter rod. 4130 rod in 4130 welds isn't the best idea
and a softer filler material is advised. Rods for mild steel are preferred.
Have a great day
Scott
"Chuck Harris" wrote in message
Hi Orval,
-Chuck
Old May 8th 06, 03:30 PM posted to rec.aviation.restoration
Hi Scott,
Now I understand the question. It is impossible to prevent
hydrogen embrittlement when gas welding. A natural byproduct
of the combustion of oxygen and acetylene is water vapor, which in
the flame shows up as H+ ions. These H+ ions get mixed in
with the molten steel, and form a mess. These H+ ions turn
good steels into something that is full of glass hard fissures,
and will always crack... sooner or later. Gas welding is really
only suitable for mild steels.
If all you have is a gas rig, and you need to connect good steels,
like 4130, you should be brazing... which essentially is what you
are doing when you use a mild steel filler (coat hanger wire).
(don't really use coat hanger wire. Its a mystery steel. Its only
operating requirement is the alloy must be cheap and soft)
If you are trying to make a joint that is as strong as the base 4130
steel, you should be using a stronger filler steel, and a shielded
arc process. The best would be TIG, or MIG.
-Chuck
pbc76049 wrote:
Chuck..
Have a great day
Scott
Hi Orval,
-Chuck
Old May 21st 06, 05:22 AM posted to rec.aviation.restoration
On Mon, 08 May 2006 10:30:28 -0400, Chuck Harris wrote:
big snip
Hi Scott,
-Chuck
The desire to use TIG with a higher end rod and post heat treat is the
best but the question is answered correctly for a repair in structural
aircraft members where heat treatment is not possible would be with an
ER70 rod and OA welding. It was only a few years ago that the FAA
even addressed TIG in the AC43.13.
Old May 21st 06, 03:39 PM posted to rec.aviation.restoration
Here is what Linde says in the "The Oxy-Acetylene Handbook", p233:
Talking of 4130 "chrome moly steel:
"One of the more familiar applications of this material is in structural
tubing for aircraft. In such structures the light gage base material is
welded using a slightly excess acetylene flame and the normal steel welding
technique. Although the strength of the weld metal in such a weld is
lower per unit area than that of the base metal, the weld is made to develop
the desired strength by increasing the normal reinforcement considerably.
By following such a procedure, this "Chrome-Moly" base metal can be successfully
welded. On the other hand, if a S.A.E. X-4130 rod were used in welding
such structures or if an attempt were made to follow a similar procedure
in X-4130 plate material 1/2 or 3/4 in. thick, the weld would not be at all
successful."
They then direct us on to Chapter 22 to discuss the correct welding technique
for 4130. There, they spell out in depth the problems with welding an air
hardening steel, such as 4130. They mention that most of these problems can
be handled by preheating welding areas to relieve hidden stresses, and using
a low carbon steel rod, similar to Norway iron. They specify Oxweld No. 7 as
being the desired rod for tubing of less than 0.1" thickness. They then go
on to say that for tubing greater than 0.1" thickness, you will need a stronger
steel in your rod, and suggest Oxweld No. 1 with a recommendation of heat treatment.
For more rigorous applications, they then recommend Oxweld No. 32 with a
requirement of heat treatment.
Going into Linde's appendixes, finds that the Oxweld No. 7 rod isn't even a
steel rod, but rather a pure iron rod with a 45KPSI tensile strength. The No. 1
rod is a High Test Steel (low carbon steel), and the No. 32 is Chrome Moly Steel
(eg. 4130).
The ER70 mig wire is a 70KPSI tensile strength mild steel. It is the same filler
steel as any of the E70xx rods.
Linde's book would be a very good place to go if one wanted to learn how to
properly OA weld 4130.
-Chuck
Aluminum welding Ernest Christley Home Built 5 April 24th 06 11:47 AM
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 09:32 PM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
TIG welding video? Russell Duffy Home Built 3 October 6th 03 05:55 AM
Partnership Question Harry Gordon Owning 4 August 16th 03 11:23 PM
