How come the wings bank when I use the rudder
Old October 21st 07, 01:42 AM posted to rec.aviation.piloting
Paul kgyy
Default How come the wings bank when I use the rudder
On a 3 hour cross country today I was amusing myself by flying with
rudder pedals only (all right, OK, a little yoke usage to maintain
altitude). But then I got to wondering why applying rudder pressure
causes the plane to bank. All I could think of was that rudder usage
produces asymmetric lift because one wing is somewhat blanked by the
sideways motion induced by the rudder? Also, the rudder surface is
above the plane's center of lift but I don't know how much of a factor
that is.
Old October 21st 07, 02:07 AM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
"Paul kgyy" wrote in message
that is.
As you yaw, the "outside" wing is flying faster than the "inside" wing and
generates more lift which gives you bank.
Geoff
Old October 21st 07, 02:16 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
that is.
It's called a yaw/roll couple. As you create yaw you acellerate the
outside wing which then has more lift. It raises coupling with roll and
you have turn.
Dudley Henriques
Old October 21st 07, 10:50 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Dudley Henriques wrote in
factor
that is.
and
you have turn.
Gotta disagree there Dudley. While it is true, and that's what happening
to some degree initially, the majority of the yaw roll couple in
lightplanes comes from the dihedral. the wing opposite the direction of
yaw has a higher angle of attack and generates more lift then the
opposite, which now has a lower alpha. Airplanes with no dihedral will
still roll slightly in the direction of yaw but it's nearly zilch.
can prove the first statement for yourself by introducing the yaw so
slowly as to make the diffrence in speeds insignificant. The airplane
will still roll in the direction of the yaw.
The V1 cruise missile had no dihedral and no ailerons and was easily
upset for this reason. Once it was off a wings level flight path it's
gyros had no chance of getting it back into straight and level.
Swept wing airplanes can have a huge yaw roll couple because as you yaw,
the forward moving wing's aspect ratio becomes massive just as the aft
moving's wing shrinks.(transonic ones have a reverse effect couple at
altitude, but that's another story)
Bertie
Old October 21st 07, 01:37 PM posted to rec.aviation.piloting
factor
that is.
and
you have turn.
Bertie
Not so much disagreement really. What you are saying is correct. All
these things happen. Technically however, the exact moment the yaw
induced higher angle of attack of the outside wing causes the excess
lift produced by the higher speed and alpha to introduce roll, a couple
has occurred and the aircraft is in an axis change from yaw only to
yaw/roll. It's a couple. Don't forget; there are complementary couplings
as well as adverse, and not all couplings result in divergence or departure.
It's really a matter of semantics and amplified explanation.
The dihedral actually stabilizes the airplane in roll and acts as you
have said.
A Cessna 195 would be one example of an airplane that will couple in yaw
without dihedral with no ill effect. A T38 however is an example of an
airplane that will couple in roll to departure if rolled at .9 mach with
a full lateral stick throw.
DH
Dudley Henriques
Old October 22nd 07, 02:55 AM posted to rec.aviation.piloting
pressure causes the plane to bank. All I could think of was that
rudder usage produces asymmetric lift because one wing is somewhat
blanked by the sideways motion induced by the rudder? Also, the
rudder surface is above the plane's center of lift but I don't know
how much of a
factor
that is.
and
you have turn.
happening to some degree initially, the majority of the yaw roll
couple in lightplanes comes from the dihedral. the wing opposite the
direction of yaw has a higher angle of attack and generates more lift
then the opposite, which now has a lower alpha. Airplanes with no
dihedral will still roll slightly in the direction of yaw but it's
nearly zilch. can prove the first statement for yourself by
introducing the yaw so slowly as to make the diffrence in speeds
insignificant. The airplane will still roll in the direction of the
yaw. The V1 cruise missile had no dihedral and no ailerons and was
easily upset for this reason. Once it was off a wings level flight
path it's gyros had no chance of getting it back into straight and
level. Swept wing airplanes can have a huge yaw roll couple because
as you yaw, the forward moving wing's aspect ratio becomes massive
just as the aft moving's wing shrinks.(transonic ones have a reverse
effect couple at altitude, but that's another story)
Bertie
Yep, but I think the airspeed portion is a minor one.
couple has occurred and the aircraft is in an axis change from yaw
only to yaw/roll. It's a couple. Don't forget; there are complementary
couplings as well as adverse, and not all couplings result in
Yep, agreed. I stil think the speed element is insignificant in
practice. As a means of demonstration, the student can take the 172 or
whatever,and introduce some yaw smoothely and slowly whilst stopping any
roll with the ailerons.Then, leave the rudder in and nuetralise the
ailerons. With the yaw stabilised, i.e., no differnece in the speed
between the two wings, the roll will be almost as quick as if it was
introduced from co-ordinated S&L flight.
have said.
Oh I know it's picking a nit and from a practical point of view is
nearly immaterial, but I'm a chronic nit-picker. Can't help it!
yaw without dihedral with no ill effect. A T38 however is an example
of an airplane that will couple in roll to departure if rolled at .9
mach with a full lateral stick throw.
OK, the 195 is a bad example because of it's parasol element and because
it's high wing and there are issues with blanketing and what not.
One of the midwing giant model airplanes they're flying aerobatics in
nowadays would be a better example.
Actually, are you sure the 195 is zero dihedral? Most high wing
airplanes that have zero dihedral look like they have anhedral. (Swick
T-cart, f'rinstance)
It's tapered as well. so even zero dihedral on top would still give some
below!
I've flown them, BTW Nice.
The T 38 example you're going to have to break down for me because:
a. I've not flown that class of airplane and
b. I'm full of whiskey.
Bertie
Old October 22nd 07, 03:31 AM posted to rec.aviation.piloting
how much of a
factor
that is.
and
you have turn.
Bertie
It is minor, especially for a light GA type airplane. High performance
airplanes get into a much more complicated dynamic concerning coupling.
As soon as you neutralize the aileron in this condition you are in
effect removing the opposing force preventing the coupling from
occurring . The airplane should instantly react to this by entering
into the couple which is consistent with your comment.
have said.
Don't think so. In fact, you're right on with this stuff.
Well, I would agree with this in that there are blanketing effects,
actually in high wings generally.
Could very well be.
below!
If I remember right, the 195 tapers all the way out and the wing's
thickness varies as well. I believe it is a 0 dihedral wing.
Never drink and fly the T38. Pull off to the side of the taxiway and
drink, then go fly.
The 38 has a high fuselage loaded mass IYMP (inertia yaw moment
parameter) which translated into normal language :-) means that at high
rates of roll, the airplane can actually suffer a divergence on the roll
axis as a coupling takes place with yaw and a new rolling axis is formed.
This can easily be visualized when you realize that at a speed around .9
mach, the roll rate of the airplane actually doubles with the last third
of a lateral stick throw. It's possible to get very close to 720 degrees
/sec roll rate out of a clean Talon.
The airplane is actually restricted to less than a full stick throw at
..9 for this reason.
When a coupling occurrs under these conditions, the 38 will depart, as
the offset roll axis produced by the coupling is unstable due to the
high mass loading of the fuselage vs the wing area.
It is however, a source of much amusement to bounce helmets off the real
canopy in this airplane even with a restricted roll rate.
Bertie
Dudley Henriques
Old October 25th 07, 08:40 PM posted to rec.aviation.piloting
Rich Ahrens[_2_]
below!
He's right, Bertie. Zero. Here's a copy of an old Cessna brochure which
states so explicitly:
http://cessna195.org/classic/brochur...chure=7&page=2
Old October 21st 07, 02:36 AM posted to rec.aviation.piloting
Andrew Sarangan
that is.
In addition to what others have said, another interesting question to
ponder is why the airplane yaws when you bank.
Old October 21st 07, 02:54 AM posted to rec.aviation.piloting
"Andrew Sarangan" wrote in message
'cause if it didn't, your feet would have nothing to do ;-)
Geoff
GPS instead of turn and bank Danny Deger Piloting 52 February 8th 07 02:03 PM
X-Wings and Canard Rotor Wings. Charles Gray Rotorcraft 1 March 22nd 05 12:26 AM
Bank Check Aviation Ron R Piloting 68 January 19th 05 01:30 AM
BREAKING THE BANK Cribsheet Piloting 0 December 22nd 04 06:27 PM
key bank CSA722 Piloting 0 July 14th 03 07:04 AM
