I am thinking about buying a 1946 Taylorcraft that has NO gyros at all on
the panel. I really want at least a turn and bank so I want die if I loose reference to the horizon for any reason. I have been told that the heading information from a GPS is good enough to do the function of a turn and bank and allow emergency operations without having a visual horizon reference. Is this correct? Danny Deger |
How are you going to determine bank with a GPS?
On Feb 4, 5:24 pm, "Danny Deger" wrote: I am thinking about buying a 1946 Taylorcraft that has NO gyros at all on the panel. I really want at least a turn and bank so I want die if I loose reference to the horizon for any reason. I have been told that the heading information from a GPS is good enough to do the function of a turn and bank and allow emergency operations without having a visual horizon reference. Is this correct? Danny Deger |
Tony wrote:
How are you going to determine bank with a GPS? Indirectly. The same way you do with a needle-ball gauge. If you ain't turning, you ain't banked. It's actually a whole lot easier to track straight ahead with my GNS480 than with the turn coordinator when flying partial panel. |
"Tony" wrote in message ps.com... How are you going to determine bank with a GPS? On Feb 4, 5:24 pm, "Danny Deger" wrote: I am thinking about buying a 1946 Taylorcraft that has NO gyros at all on the panel. I really want at least a turn and bank so I want die if I loose reference to the horizon for any reason. I have been told that the heading information from a GPS is good enough to do the function of a turn and bank and allow emergency operations without having a visual horizon reference. Is this correct? Danny Deger Actually there are specialized GPS units that can determine attitude and they have been around for at least 10-12 years. Google the "Trimble TANS Vector" and you will see one of the earlier units. http://trl.trimble.com/docushare/dsw...20997-00-C.pdf They operate by using at least 3 antennae (usually four antennae) and directly determine roll, pitch and yaw using carrier phase differences from the GPS satellites. Of course this is not the way the portable units derive the HSI info. The carrier phase units are commonly used as either primary or secondary IMUs (with some other 3 axis gyro like a laser gyro) in high-end UAVs or other military type hardware. Regards, John Severyn |
"J. Severyn" wrote Actually there are specialized GPS units that can determine attitude and they have been around for at least 10-12 years. Google the "Trimble TANS Vector" and you will see one of the earlier units. http://trl.trimble.com/docushare/dsw...20997-00-C.pdf They operate by using at least 3 antennae (usually four antennae) and directly determine roll, pitch and yaw using carrier phase differences from the GPS satellites. Of course this is not the way the portable units derive the HSI info. That's some cool stuff. It seems as though I recall this subject coming up a few years ago in the homebuilt group, and nobody came forward with a system like this one. I didn't see a price associated with it anywhere. Is this a case of, "if you have to ask, you can't afford it?" g -- Jim in NC |
On Feb 4, 2:30 pm, "Tony" wrote:
How are you going to determine bank with a GPS? The Garmin handhelds show a mini panel complete with a turn corrdinator. The GPS knows your rate of turn. However, on the 296 there is enough delay that it isn't really simple to fly under the hood on. -Robert |
Robert M. Gary wrote: On Feb 4, 2:30 pm, "Tony" wrote: How are you going to determine bank with a GPS? The Garmin handhelds show a mini panel complete with a turn corrdinator. The GPS knows your rate of turn. However, on the 296 there is enough delay that it isn't really simple to fly under the hood on. I thought I heard that the new 296's had the better processor of the 396/496. Did that happen or not? |
Recently, Danny Deger posted:
I am thinking about buying a 1946 Taylorcraft that has NO gyros at all on the panel. I really want at least a turn and bank so I want die if I loose reference to the horizon for any reason. I have been told that the heading information from a GPS is good enough to do the function of a turn and bank and allow emergency operations without having a visual horizon reference. Is this correct? Aviation-oriented GPS units with moving map displays often have an HSI mode, so you may be able to eventually detect turn, but not bank. I would think it unwise to rely on that for orientation. Neil |
Danny Deger writes:
I am thinking about buying a 1946 Taylorcraft that has NO gyros at all on the panel. I really want at least a turn and bank so I want die if I loose reference to the horizon for any reason. I have been told that the heading information from a GPS is good enough to do the function of a turn and bank and allow emergency operations without having a visual horizon reference. Is this correct? A GPS can only determine your track over the ground, which may not be your heading. If there is no wind, both are the same, but if there is any wind, your heading could be significantly different from your ground track. GPS cannot determine your bank angle. In theory a GPS could determine if you appear to be making a standard turn, if there is no wind. I don't know of any actual GPS units that do this (?), and it becomes complicated if there is any wind. Remember, GPS units can only determine your location in space (longitude and latitude and, with somewhat less precision, altitude). Apart from that basic information, all other information they provide is derived from observing the changes in your location over time. They cannot provide any information that cannot be calculated from this data. They do not know the actual attitude or heading of the aircraft: a 45-degree bank and a 30-degree downward pitch angle look exactly the same as level flight to a GPS. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
A GPS can only determine your track over the ground, which may not be your heading. This is the only thing that you said in your three whole stupid ass paragraphs that was correct or the least bit relevent. Unless you actually learn something about flying IFR in reality rather than ****ing your life away in front of flight simulator you'll never have an understanding of flight. By the way, if you got your lard ass out of your chair and got some excercise, you wouldn't overgross the training ships you might be able to fly. |
| Thread Tools | |
| Display Modes | |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| WTB 2 1/4" Turn and Bank | Bill Batesole | Soaring | 3 | October 18th 05 03:43 AM |
| Turn & Bank Indicator and 2 gallons of poyester resin | [email protected] | Instrument Flight Rules | 0 | February 12th 05 08:52 PM |
| Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 06:14 AM |
| Turn and Bank - RC Allen vs Electrical Gyro Corp | Kevin Horton | Home Built | 0 | December 1st 03 01:46 AM |
