The logbooks for our newly purchased A36 Bonanza has an entry "E2 Heat
Engine Heater" installed. No other documentation on this AC powered heater (attached to oil sump) appears anywhere. Any ideas on who the manufacturer is? I want to get an owners manual and specs (e.g. current draw). Any help is appreciated. |
![]() "nick name" wrote in message oups.com... The logbooks for our newly purchased A36 Bonanza has an entry "E2 Heat Engine Heater" installed. No other documentation on this AC powered heater (attached to oil sump) appears anywhere. Any ideas on who the manufacturer is? I want to get an owners manual and specs (e.g. current draw). Any help is appreciated. Not E2, EZ, as in "easy". http://www.e-zheat.com/specs.htm |
You can't get a mirror and see the pad? There's nowhere on there that
says how many watts it is? Most of the heating pads on aircraft are bought at the Farm and Ranch store, that's where I got mine and everybody around here does the same thing. Why spend $200 when a $35 one works the same? nick name wrote: The logbooks for our newly purchased A36 Bonanza has an entry "E2 Heat Engine Heater" installed. No other documentation on this AC powered heater (attached to oil sump) appears anywhere. Any ideas on who the manufacturer is? I want to get an owners manual and specs (e.g. current draw). Any help is appreciated. |
Newps writes:
You can't get a mirror and see the pad? There's nowhere on there that says how many watts it is? Most of the heating pads on aircraft are bought at the Farm and Ranch store, that's where I got mine and everybody around here does the same thing. Why spend $200 when a $35 one works the same? nick name wrote: The logbooks for our newly purchased A36 Bonanza has an entry "E2 Heat Engine Heater" installed. No other documentation on this AC powered heater (attached to oil sump) appears anywhere. Any ideas on who the manufacturer is? I want to get an owners manual and specs (e.g. current draw). Any help is appreciated. You can buy a Kill-o-Watt for $25 or so; it will tell you how much power it's using. Then you can measure everything else in your house to find the energy hogs.. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
Cherokee Heater Controls? | Bob Chilcoat | Owning | 1 | July 9th 06 03:50 PM |
Heater Smell | O. Sami Saydjari | Owning | 4 | May 1st 05 04:21 AM |
Heater problem fixed! | Jim Burns | Owning | 14 | December 17th 04 10:38 PM |
Aztec heater update | Jim Burns | Owning | 0 | November 27th 04 03:28 PM |
Tanis Pre-heater with Engine Analyzer | O. Sami Saydjari | Owning | 12 | January 29th 04 12:50 PM |
